| 07-22-2019, 09:58 AM | #155 |
![]() 3770
Rep 3,164
Drives: 2020 M4 ZCP / 2023 X3 M40i
| 07-23-2019, 03:38 PM | #157 | |
102
Rep 252
The Canadian MY20 are getting new engines: B46B20O1 B58TUO1 The B58 code doesn't seem to match up normal naming conventions, but I would assume the O1 would mean 382hp We are also getting ID7 and Live Cockpit Pro as standard |
| 07-23-2019, 06:12 PM | #158 |
850
Rep 1,107
| 07-23-2019, 07:09 PM | #159 | |
102
Rep 252
I feel the chance of the M2 getting a bespoke manual and the M3/4 not getting it would be fairly low. Starting to wonder if there will be a M2, cause maybe the S58 will only be paired with xDrive. |
| 07-24-2019, 05:10 AM | #160 |
![]() 72
Rep 43
Relax lads, manual M3 and M4 are here to stay.
https://g20.bimmerpost.com/forums/sh....php?t=1636871 BB: The upcoming BMW M3 and M4 are some of the most highly anticipated M cars in a very long time. Will there be any surprises for BMW fans? MF: No, it’s a bit early to disclose all the details but something I want to highlight is that we will have a manual stick shift. We have already disclosed we will have the option of four-wheel drive. We’ve not decided which variant, which system, but everything that’s on our current lineup; think of the M5; can be made available. The M3 and M4, I’ve driven the pre-production cars already and they’re fantastic. |
| 07-24-2019, 08:17 AM | #161 | |
3502
Rep 4,542
Drives: 2022 F97 X3M Comp LCI
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE BMW MY08 E92 335XI - GONE BMW MY06 E46 325XI - GONE |
Waoudi26.50 |
| 07-25-2019, 09:45 PM | #162 | |
626
Rep 1,006
Drives: 2022 X4 M Competition F98 LCI
These engines are the same ones in the G20 3er and G29 Z4, so both the B46 and B58 are getting power bumps with the G01 X3. |
| 07-28-2019, 07:41 PM | #163 |
![]() 967
Rep 2,744
Does anyone know (SCOTT?) if it's finalized that the G22 4 Series Coupe will not be receiving a manual transmission in any trim level?
M240i Coupe (6MT) (2021: 6/2021 build )
Accord Coupe (6MT) (2017) 335i Coupe (6MT) (2007: 9/06 build SOLD 8/2016) Prelude (5MT) (1995) |
| 07-30-2019, 03:15 AM | #164 | |
![]() ![]() ![]() ![]() 832
Rep 800
| 08-04-2019, 01:13 PM | #166 |
![]() 10186
Rep 3,710
| 08-04-2019, 08:13 PM | #167 |
![]() 10186
Rep 3,710
I have figured out how to distinguish between automatic and manual G80s (hey BMW, kudos to whoever came up with that "X"). And yes, this means all the recent interviews and "leaks" are true, and G80 will offer a choice of transmissions.
| 08-04-2019, 10:29 PM | #168 | |
Moderator
7516
Rep 19,366
Do you think you will eventually be able to determine which combinations of transmission, drive wheels, and power output will be offered? Or will that have to wait until specs are made expressly public by BMW? |
| 08-05-2019, 12:25 AM | #169 | |
![]() 1344
Rep 2,363
I'm going to guess the 480ps spec engine will be the only option for the manual rwd car and the zf8at cars will be available as 480ps for the normal one, or 510ps for the comp pack. I'm going to say there is 0% chance that 6mt and awd will be a thing.
SCOTT26 "So as an admirer of the M5 and a potential customer of an M5 Touring. I would run naked around the streets of Garching if they were to offer one."
| 08-05-2019, 12:32 AM | #170 |
![]() 1344
Rep 2,363
replying to myself, so sad. I'm referencing this post
https://g20.bimmerpost.com/forums/sh...&postcount=296
| 08-05-2019, 08:47 AM | #171 | ||
Moderator
7516
Rep 19,366
https://g20.bimmerpost.com/forums/sh...1#post23905991 Still, the possibility that the manual transmission won't properly handle the torque produced by even the would-be baseline S58 as found in the standard X3/X4 M (and presumably the upcoming standard AWD M3/M4) has some merit. Factor in the likelihood that the S58+6MT combo will also be headed to the G87 M2 which will surely continue to be separated from the standard M3/M4 in part by having a lower engine output, and this idea has legs. Quote:
But, the reason I asked ynguldyn the question in my post wasn't because I don't think we have honed in on the likely specs with a high degree of certainty. On the contrary, I think that the community has collectively pieced things together what is probably a pretty accurate picture of the G80's mechanical specifications. Rather, I am looking for 100% confirmation. And while I personally think that the exact engine output of the expected RWD 6MT model - whether it be the same as the standard AWD model or slightly less - to be a minor point, there is a vocal fanbase who is very concerned about that number. |
| 08-05-2019, 01:28 PM | #172 | |
![]() 1344
Rep 2,363
The F10 M5 and F06/12/13 M6 were available with the 6MT with 575ps and 500ftlb, the S58 is going to be nowhere near those figures. I don't see why the 510ps and 442lbft in the Competition would be a problem other than marketing. I'd guess that at higher speeds the 6MT will have quite a bit less drag than the zf8at + awd combo and maybe BMW would be worried about the 6MT being better at higher speeds.
pyrat15247.00 |
| 08-05-2019, 05:51 PM | #174 | |
![]() 10186
Rep 3,710
If anything, I suspect my confusion and the resulting collective hair pulling on this site are partially to blame for the concrete info coming out of BMW executives' mouths and the weird photo "leak" from Madrid. So it seems like it ultimately worked to our benefit. Yes, it's coming. It's just too soon to give precise details. |
| 08-05-2019, 10:17 PM | #175 | |
Moderator
7516
Rep 19,366
Assuming that the three-model lineup is indeed correct, it would be a little surprising if the “middle” configuration ends up being RWD Competition instead of AWD non-Competition. However, I admit that the biggest reason I think that is that it’s easiest to simply assume the M3/M4 lineup will be a superset of the X3/X4 M, M5/M8, and (presumably) X5/X6 M lineups. Yet, that needn’t necessarily be the case. That being said, I feel like it would be a little weird if there’s just one G83 configuration. Either way, this is fun. I cant recall a future model release surrounded in so much mystery and intrigue. Not to mention the plot twists. I’m sure BMW is loving all the hype. ![]() |
JTO246935.00 |
| 08-06-2019, 12:24 AM | #176 |
![]() 1344
Rep 2,363
Or people not talking about the potential grill design
ZHPsedan151.50 |
| Bookmarks |
| Tags |
| future bmw, release date, upcoming bmw |
