Official APEX Wheels Showroom Gallery Thread
10-02-2013, 02:35 PM | #133 |
9
Rep 62
10-02-2013, 04:26 PM | #134 |
BimmerPost Supporting Vendor
3595
Rep 6,846
With the 9.5" wheel being much wider than the OEM wheels in the front, you would have issues with the wheels and tires not clearing the struts. To alleviate this issue, you would need at least a 5mm spacer, depending on the tire size, make and model that you would like to use, which in turn will require for you to need added negative camber for proper fender clearance. While it is definitely possible to do with work done to your car, the 17x9.0" ET30 ARC-8's or 18x9.0" ET31 EC-7's become a more popular squared fitment for the e9x chassis since it is a spacer free fitment.
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// Project ML-10 Survey |
10-02-2013, 05:17 PM | #135 | |
9
Rep 62
If i have dinan plates, m3 lower and upper control arms and pin taken out with TCKline S/A coils ....what is possibility to FIT 18x9.5 et35 without spacers? |
10-02-2013, 05:25 PM | #136 |
3595
Rep 6,846
The camber and alignment settings is not the issue as it does not change the clearance that you have between the wheel and the strut. Due to the wide width, the wheel interferes with the struts without the use of spacers.
10-02-2013, 10:22 PM | #137 | |
164
Rep 689
What's the recommend tire size for ec7 18x9 on an e90? 255/40?
Nick | 2011 Competition Package M3 Sedan | @Restoration_Motorsport on IG
10-03-2013, 12:18 PM | #138 | |
3595
Rep 6,846
10-31-2013, 11:03 AM | #139 |
101
Rep 1,179
Anyone selling their cars!? Sell me your ec-7!!
Check my for sale and wanted threads!!! If i didn't post sold then it's still available!!
http://www.e90post.com/forums/search...&starteronly=1 |
11-25-2013, 05:45 AM | #140 |
1254
Rep 4,088
Finally got my winter tires mounted up and installed the wheels yesterday - in time for some storms headed our way
ARC-8's, 17x9 et30 with Michelin xice3 235/45. no spacers. LCI. Also running 75mm wheel studs and nuts from Apex. Highly recommended mod for any car whose wheels come off and on often. |
11-25-2013, 12:56 PM | #141 |
3595
Rep 6,846
Awesome, thanks for sharing ashmostro! Looks like a great winter setup with the narrower winter tires!
12-08-2013, 06:15 PM | #144 |
228
Rep 457
Drives: '19 X3 M40i
EC-7 Race Silver on '06 330i ZHP
Apex EC-7 "Race Silver" f 8.5x18 et35 p1 r 9.5x18 et35 p2 Michelin A/S 3 f 235/40 r 265/35 2006 330i, stock ZSP suspension. No rolls, no spacers. The fit of these wheels on the car is phenomenal. Aggressive and classy, they look like a proper oem setup. I'm leaning BMW roundels to finish off the job. I intended to get the Anthracite finish but in person it was just close enough to the SGM of my car that you only really noticed that the grays were different. And there's the weight. This is a street car, a daily driver... but dropping nearly 50lbs of rotating weight is noticeable even around town. Assuming Apex' weights are reasonably accurate, the EC-7 are about 11lb each lighter than the stock ZSP rims. Thanks to David and Kyle @ Apex. I had a slight rub at the left rear on compression (dips in the road, with some load in the car). Apparently the left fender-well lining wasn't installed as snugly as on the right side. Sorted now... no rubbing.
2019 X3M40i DGM/black vernasca, 2T4, 2VF, ZPX, ZPP, ZDA, DWS06+, etc, etc. Since July'19.
2021 X540i MSport CBM/black merino, 337, ZMP, ZPP, ZPK, etc. Since Dec'20. 2006 330i SGM/black, ZSP, ZPP, 217, HuberOps, M Splits, K Lines, AS 3 on EC-7. Sep'08-July'19. Last edited by prototyp; 12-28-2013 at 04:09 PM.. |
12-08-2013, 07:52 PM | #145 |
19
Rep 260
EC7 18 9 front 31 offset and 18 9 1/5 in the rear with a 22 offset. running 225/40 and 255/35 PSS. I rubbed with the 265/35 in the rear without any camber adjustment and fender rolled. Not sure how good the roll was. With this setup no rubbing which I like.
12-09-2013, 02:02 PM | #147 |
3595
Rep 6,846
Looks great prototyp & Rickygst, thanks for sharing your photos with us! Prototyp, we hope your fender lining issue gets resolved soon so the tires don't chew away at it with the rubbing! We do agree that Michelin tires tend to be more squared off than most tires, especially with their large bead protector on their tires.
02-18-2014, 06:00 PM | #148 |
1445
Rep 2,673
Check out this photo from our last Wallpaper Wednesday:
It is our shop E90 M3 with ARC-8's in 18x10" ET25 square and 275/35/18 Hankook R-S3's. This is the ideal track setup for this platform and best of all, it's a direct fit! No spacers, camber, or fender rolling required; just plug and play! This car is lowered on B&G Sport Springs. Other modifications include an Akrapovic Exhaust and Mode Carbon GTS Variant 1 front lip.
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// ML-10 Survey |
PF49er0.00 |
02-18-2014, 08:19 PM | #149 |
48
Rep 1,010
Beautiful! Can't wait to get my EC-7's on once the Spring comes.
2008 335xi Jet Black//Coral Red VTT Stage 1+// Procede V5//VRSF DPs//AMS FMIC//KW V1//M3 Sways & Sub Bushings// Alpina AT flash Apex EC-7//Michelin PSS//Dinan CAI |
03-03-2014, 04:10 PM | #151 |
3595
Rep 6,846
The 265/40/17 tire size is not very common and are not widely available, but this tire can work with the 17x10" ET25 with rolled rear fenders. The 17x10" ET25 is an aggressive wheel for the rear and would not fit without fender modification from our experience.
03-05-2014, 11:37 PM | #152 |
pew pew
166
Rep 6,781
Square 18x9.5s with 265/35/18 Direzza ZIIs on E90. Real photos coming later, but just a quick snapshot to show that it can work.
CSL replicas are now CSL counterfeits. Jesus saves, like Valentine1.
03-06-2014, 12:26 AM | #153 |
OTCQX:ZERO
22
Rep 133
what offsets? spacers? camber settings?
03-06-2014, 12:39 AM | #154 |
1977
Rep 2,712
