The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > Official Bulb Code List (E90 sedan)
      04-03-2016, 09:05 AM   #133
prime300
Paul C
prime300's Avatar
88
Drives: E90 N55 M Sport
Originally Posted by e90Hero
What are the three bulbs for this?? Inner taillight right side for 2008 bmw e90 sedan pre lci
Back up light (on top)
Bulb for the 3lines that are on whenever your night light are On(middle bulb)
Rear fog light (small bulb)
      04-05-2016, 09:35 AM   #134
e90Hero
e90Hero's Avatar
15
Drives: 2008 BMW 328i & BMW 645ci
What are the Bulb numbers ???
      02-14-2017, 08:22 AM   #135
Gearhead43
Drives: 2011 E90 328ix
Originally Posted by wuufer001 View Post
im a little bit confused, i have the oem xenon headlight pkg and want to know what is the code for the xenon headlamps (not drl)? i'm assuming DS1 will work but is that a part# for a brand or the universal code meaning that when i want to change it has to say DS1.
1 more thing, what 'K' is the OEM denon bulb? and if i change to 8000K bulbs which is brighter and 'bluer'?
tnx in advan
K is color temperature in degrees Kelvin
Bluer lights are not brighter in terms of LUMEN.. it may LOOK cool.. But you are putting less light down on the road. If you want the brightest HID or LED its best to stay in the K color range of 4300K-5500K
      05-09-2017, 09:20 AM   #136
z3Ro
30
Drives: 2011 E90 335XI M-Sport
which one of the bulb number is for the adaptive headlight on a LCI or can that not be replaced? its so yellow and dull.
      11-17-2017, 05:04 PM   #137
K.Lang
Drives: 2011 BMW 335i xDrive
HELP PLEASE!!! What light is this, and how do I replace it??
Need help figuring out what light this is in the headlights.
      11-20-2017, 10:18 AM   #138
LuxAngelEyes
BimmerPost Supporting Vendor
LuxAngelEyes's Avatar
Drives: BMW
its an integrated LED module thats not replaceable
      01-18-2018, 12:43 PM   #139
Maniac0908
Maniac0908's Avatar
Drives: Alpine White 07 335xi Sedan
Has anyone changed the highbeam h7 to led? From what I'm told led can be brighter and shoot further than halogen, and since I'd like to black out the reflector I thought led might be a good idea. Any input?
      03-03-2018, 01:24 AM   #140
ItsGary
ItsGary's Avatar
1458
Drives: 2009 E90 M3
It’s illegal in most places to put LED lights in reflector housings since the light is thrown all over the place.
      03-15-2018, 01:49 PM   #141
cbouchez
Drives: 2009 328ix Touring
Any recommendations on a replacement bulb for 9006 Bulb - 55 Watt (fog light)
I'm looking for an LED bright white. Most the bulbs that I've seen the back of it is huge due tot he fan. I'm not sure if I will be able to fit it properly without modification of the housing.
      10-08-2018, 08:44 AM   #142
ViperZ
Drives: 2010 335ix M-Sport / 06 E46 M3
I just ordered these for my M-Sport Fogs. I'm hoping there is enough room in the front bumper for them. If not I'll find another use for them.
On another note, is the original list (first post) up to date?
      12-27-2018, 02:15 PM   #143
Professor B
Drives: 2013 BMW 135i MSport package
What is the bulb number for the daytime running lights and cornering lights on a 2013 135i?
      07-07-2019, 01:29 PM   #144
rubberneck7
Drives: 06 BMW 325i
I have an 06 e90 325i. I've dealt with the headlight issues and want to change away from halogen but now my issue is this: I thought I just needed new low beam bulbs but put them in and I've got nothing. Tried the more expensive halogens, tried cheap ones that always work, nothing. Fuses are all good. Someone said the FRM but wouldn't there be more lights out than just headlights? High beams are good, fog lights, all good except the f*%**!! low beams. Any ideas would be so greatly appreciated!!
      08-04-2019, 09:47 PM   #145
mikemasoner
Drives: 335i
perfect
      12-08-2022, 02:23 AM   #146
Shocked
Drives: E90
Originally Posted by noidea View Post
it is more easier for people thinking of changing aftermarket bulb so they know which type of bulb used.
cheers !
I dont know where are you now, but im replying 15 years later to say thanks, matter of fact just created the account to do so. Lmao. New E90 boi here.
      02-13-2023, 07:25 AM   #147
lordnikon
lordnikon's Avatar
395
Drives: Break My Wallet
Anyone know where you can purchase 7528 rear amber bulbs for the turn signal? Most are clear and I can't find the amber bulbs.
      02-23-2023, 03:09 PM   #148
DreierTouring
Drives: 2007 E91 328xi
7528 is incorrect. 7506 is what you want for all taillight bulbs (signal, brake and running lights). They are all white. Just replaced mine today.
There are no amber bulbs involved unless you have blackline taillights, pictured below. In that case, you will need 7507 amber for the turn signal only.
