01-08-2022, 09:03 AM | #133 |
405
Rep 163
Drives: 23 X5MC, 21 M8CGC, 19 X7 M50
Well another week has gone by and nothing has happened, and our X5M continues to sit at the back of the service lot!.
Now the warranty company is refusing to pay for the labor and also the turbo's that the dealer says needs to be replaced due to oil starvation. The warranty company will only pay $15k for the used engine. We received the history of the used engine and it came out a X5M that was in a major accident where it rolled several times and sustained $90k of damage! (any thoughts on this?) The dealer has dug their heels in and are refusing to take any responsibility and have been clear that they have no desire to attempt to make things right. They have agreed to take the vehicle back in on trade once the repairs are complete. They will not provide a loaner, or do anything else to help with our situation. I have spoken with several individuals who have expressed emphatically that the dealer's insurance company should be paying every dime of this repair. The cause of the failure has been verified by BMWNA and also an Independent service center and we have documents proving the dealer performed this service with the wrong oil. The dealer is refusing to file a claim. My wife and I are at a complete loss of words here, I have never experienced such BS and lack integrity or service in my life. My wife has been crying, and can't understand why it's so hard for any company to do the right thing! We have lost all faith in this bullsh*t world! No matter what decision we may make we are going to be stuck with at least a $10k+ bill and at the very least a used engine that was pulled out of a vehicle with over $90k in damage! I've already paid a $600 service bill and will need to rent a car again for probably the next couple of weeks. I think our only option left is to seek legal action against the dealership, which really would have been our last resort. What a sad pathetic set of circumstances. Sorry to vent guys! Last edited by Bankerbry; 01-08-2022 at 11:24 AM.. |
01-08-2022, 09:20 AM | #134 |
360
Rep 1,340
This is ugly and frankly quite pathetic from the selling dealer. Time to lawyer up and threaten to share your experience in social media. Someone earlier suggested going to an influential local media person - is that an option? I'm sorry that you're going through this.
9vapors653.50 |
01-08-2022, 09:36 AM | #135 | |
632
Rep 1,234
Castrol
As far as I can tell, the Castrol 0W40 has a flash point of 408F which is extremely low/no good according to one of my indies who recommends a high flash point (I've seen 440-464 from the oils I've recommended or used). And it has a Noack value of 9.1 from what I gleaned in a few posts floating around, which is good/no better than for instance the Red Line 0W30 (which has an HTHS of 3.4, Noack value of 9, flash point of 446 even back in 2018 - can't find what it is today, and is beyond the MB approval you recommended) Castrol Edge 0W40 spec sheet from 2019 - https://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/7B9337CEA39CEBFB802584C6007D7CE6/$File/bpxe-bjlw36.pdf I realize there are so many thoughts and opinions of oils. But based on what I read the Red Line and Motul Specific do seem to be on par with each other when it comes to specs for FE oils. (My M specifies FE and that's what I have been using thus far. If tuned and/or doing some track days this year, maybe bump it to the Motul Sport 5W40 or something like it.) Not to change your opinion about the Red Line, but maybe it has changed since you last evaluated it - here is the latest spec sheet from Red Line if you're interested. https://www.redlineoil.com/Content/f..._INFO_2020.pdf |
01-08-2022, 09:44 AM | #136 | |
632
Rep 1,234
Legal Representation
Time to send a Priority Mail package to the pertinent executives at BMW NA as well as the executives at your dealership and the servicing dealership. Because everyone should be bowing at your feet and offering whatever they can do to help you. I don't understand $90K worth of damage, because the vehicle should have been totaled even if it was brand new and worth all the money. So can you explain that? Will the dealer credit your full purchase price and expenses toward a new F95? Just a thought. |
edycol1521.50 |
01-08-2022, 10:27 AM | #137 | ||
1522
Rep 1,494
Flash point is nit that important. It varies based on additives. Most LL04 oils will have higher flash point bcs. less metallic additives. As for Noack, 9% for 0W40 is exceptional value. Think about it like this: if you have two oils from same base stock (good example are Castrol 0W30 and 0W40), one with less spread between XW and XX will have lower Noack. So 0W30 (which I think is still best European oil, just expensive) is 8.1%. 0W40 is 9.1%. Both values are excellent. Now, Redline 0W30 is again, high oxidation oil. You really have to keep OCI in check. It is semi racing oil. Don't get me wrong, I like their products. I have their D4 in my manual gearbox in E90, I have their 75W90 in my minivan's transfer case and rear differential. But, their performance series has specific use. Also, your manual says both LL01 and LL01 FE. Redline is not approved oil for any manufacturer (their professional series is, but that is repackaged Kendall). So not sure why you going Redline 0W30? What really, really matters in an engine with such hot turbos is High Temperature-High Shear (HTHS). It is resistance of oil to temporary or permanent loss of viscosity. Perfect HTHS for S63 would be 3.6-4. HTHS is all about keeping your bearings away from other stuff, having enough viscosity to lubricate pistons rings, turbo bearings etc. You don't want to go too crazy on this too. So, if you want Redline, go 5W30. Low KV100, HTHS of 3.7. Just changed at 5k at most. Again, about flash point. Here is my UOA of Castrol 0W40 (with 47 laps at High Plains Raceway) and on the right side Castrol 0W30 during winter use. Look flash point after 5k. |
01-08-2022, 10:36 AM | #138 | ||
1522
Rep 1,494
Legally, dealership screwed up using wrong oil. It doesn't matter that I highly doubt that is the cause, legally they messed up. And lawyers will cling on that same like BMW NA is. |
01-08-2022, 10:38 AM | #139 | ||
1522
Rep 1,494
IMO Valvoline European Vehicle 5W40 that is approved for LL01 is better stuff and goes $22 in your local Wal Mart. Actually that Valvoline is stout thing. I used their MST version in my X5 35d. Fairly high HTHS of 3.7 and low KV100 of 13.1 indicates very good base stocks. |
01-08-2022, 10:49 AM | #140 | |
632
Rep 1,234
Manual
My manual only specifies LL01-FE, not LL01. Not in the on board computer and not in the paperback manual. And not in the online users manual when I type in my VIN. No idea why, but it only says when necessary that I can add up to 1 quart of certain kinds with LL01 being one of the options. It's an FE engine and I wish it wasn't even for the psychological value of using other oils... Funny you mention the Red Line 5W30, I was checking that out because of the 3.7 HTHS which might better especially during the warmer months. |
01-08-2022, 10:56 AM | #141 | ||
1522
Rep 1,494
Another reason why BMW uses FE is that many owners of these SUV's are using it to get groceries, take kids to daycare. That means a lot of short trips where oil cannot reach operating temperature. In that case, thinner stuff is better! Rule about engines and oils is: as thin as possible and as thick as necessary! If you are driving 5mls to work and back, yeah FE stuff is probably better. But if you are driving like S63 should be, forget FE. If you are under warranty, Redline won't cut it. It is not approved. Motul specific is way to go IMO. |
sly1types431.50 |
01-08-2022, 11:18 AM | #142 | |
109
Rep 175
01-08-2022, 11:26 AM | #143 | |
405
Rep 163
I also think the social media and use of an influencer is a great idea. Regardless of my thoughts on this, it is a way to gets thing moving these days. Thank you for the suggestion. |
01-08-2022, 11:28 AM | #144 | ||
1522
Rep 1,494
01-08-2022, 11:44 AM | #145 | ||
73
Rep 144
Bankerbry I totally understand why you would be uneasy about getting a replacement engine from a wreck like that as well. Even if they offered a warranty on it-doubtful in my opinion, your best bet would be to get rid of the car but at the same time not take on any additional cost. That dealership's credibility is crap now and like many have said you need to lawyer up. Negligence on their part is valid and they provided the evidence themselves. |
01-08-2022, 12:10 PM | #146 |
405
Rep 163
I completely agree! The dealership was very quick to cast blame away from them, and actually provided us with all of the documentation that proved their negligence caused the engine failure.
Initially we were hopeful that they would do the right thing, and take care of their customer. Unfortunately they have decided the customer is not more important than their dollar. No, they have refused to give us credit for the purchase price and now are back tracking away from doing anything for us. It looks like they are now taking the stance of buyer beware. Extremely disappointing, and as an owner of 2 businesses I can't understand their position. There are decent dealerships out there who believe in taking care of their customers. Sill-Terhar is not one of them. |
9vapors653.50 |
01-08-2022, 02:51 PM | #147 |
351
Rep 385
@Bankerbry I feel your anger and disappointment. Sounds like seeking legal action is only hope to get fairness in this situation. Anytime getting lawyer involved, you are looking at additional expenses, time, energy and emotional investment without knowing what will the outcome be in the end. That being said, I'm not discouraging, I think you should seek for a lawyer who is willing to agree on terms that you will guaranteed financially not be impacted negatively than you had already. Meaning that if you don't win the lawyer doesn't get paid. The settlement will cover your loss and his fees. Sorry that you have to deal with this F up situation.
01-08-2022, 02:53 PM | #148 | |
351
Rep 385
9vapors653.50 Blue By You632.00 |
01-08-2022, 03:39 PM | #149 |
109
Rep 175
Typical stealership tactics to intimidate and bully you into a settlement. Given the trail of evidence and paperwork, I would just lawyer up at this point and make sure you get every penny possible for time, headache, legal fees and full purchase price of the vehicle. Good luck Bankerbry
01-08-2022, 03:54 PM | #150 | |
405
Rep 163
01-08-2022, 04:43 PM | #151 | |
632
Rep 1,234
$90K
Surgx572.50 |
01-08-2022, 04:45 PM | #152 | |
632
Rep 1,234
Warranty
I take care of my M but I drive it (after a full warmup to operating temp). And I'll be doing some track days in the nicer weather. That's why I liked the idea of the Motul Sport. What is your silver bullet recommendation for me? Curious to know if you haven't already mentioned it, and if you did I apologize. I also found the Motul 8100 X-MAX 0W-40 which seems great with LL01 approval and an HTHS of 3.6, seems like a silver bullet what do you think? Last edited by Blue By You; 01-08-2022 at 05:22 PM.. |
01-08-2022, 06:36 PM | #153 | ||
1522
Rep 1,494
Silver bullet with LL01 approval?in this order: Motul X-Cess 5W40 GEN2 Pennzoil Platinum Euro 5W40 Valvoline European Vehicle 5W40 Without LL01: Castrol Edge 0W40. Mobil1 0W40FS. |
01-08-2022, 06:55 PM | #154 | |
632
Rep 1,234
I like that X-Cess 5W40 Gen2! You posted that up before, but I hadn't looked into it that deeply. That might have to be the go-to starting next oil change. Thanks! |
edycol1521.50 |
