05-02-2012, 01:13 AM | #111 |
83
Rep 954
No need to mess with any electrical stuff other than whats under the air bag. Do not forget to disconnect the battery before unplugging air bag!
05-02-2012, 02:30 AM | #112 |
Just a normal member.
171
Rep 3,404
TY SIR!
05-03-2012, 12:21 AM | #113 |
///M
162
Rep 1,867
I got my PSW today, the install took about 20-30mins had to be careful with the airbag plug, it was a pretty install
THANKS TO:~<RPM>~ ~<SONICMS>~ ~<MODECARBON>~ ~<McKennaPerformance>~
MODS: MODECARBON V2 GTS FRONT LIP & REAR DIFFUSER, AA GREEN FILTER, RPI SCOOPS, PSW, Verstraβe Extended DCT Shifter, ZCP WHEELS (SEMI-GLOSS), OHLINS R&T, Megan Exhaust, AKRA XPIPE, BMW LED INTERIOR, BLACKOUT W/ORION V4 LED AE, OSRAM CBI |
05-03-2012, 07:45 AM | #114 |
10878
Rep 27,645
^^I have the exact wheel, def one of the best mod for the car! congrats
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST! Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101 vipfinance@bmwofcamarillo.com for warranties! |
05-04-2012, 12:45 PM | #115 |
23
Rep 344
Well guys i need some serious help here. Everything went fine on this install until we went to put the new wheel on. Basically it would not just easily slide right on even though the spine in the wheel was lined up with the hole in the column. So we pushed the wheel on as far as we could and proceeded to tighten down the nut to get the wheel to go down. It did, but its not flush with the steering wheel column. There is probably a 1/8" gap. Upon reconnecting everything the wheel is off center and the DSC error came up when driving around. We took the airbag back off, took the 16mm bolt out and tried to pull the wheel off with no luck. That thing is stuck on there and just wont budge. Anything I can do here or am I going to have to make a trip to the shop to have the wheel removed? I honestly have no idea how the would even get it off....it won't budge at all.
05-04-2012, 01:27 PM | #116 |
///M
162
Rep 1,867
yeah the wheel feel so much better, now i just have to make sure to wash my hands before taking a drive!
07-26-2012, 10:28 AM | #117 | |
145
Rep 3,329
F80 ///M3 6MT Avus Blue ZCP |
08-03-2012, 11:45 PM | #118 | |
Track Addict
110
Rep 813
Drives: 2010 BMW M3 E92 | 2008 Z4M E86
BMW ///M3 Coupe
Completed November 16, 2009 Received December 29,2009 |
08-04-2012, 12:13 AM | #119 |
188
Rep 714
i installed my PSW V2 elec wheel myself and you can't even see that I inserted the screw driver in there to get the airbag out. Just be careful and take your time
09-19-2012, 10:04 AM | #120 |
Rep 7
All
Is anyone able to tell me what the part number of the Little 12 pin plug (A7) is my 2nd hand set up from BMW display does not have this plug and im stuck. BMW are trying to help, but no joy. Even the Tech guy in Germany doesnt know. As the main wiring loom has been discontuined. If some has one to hand that would be amazing. |
01-16-2013, 01:09 PM | #121 |
Rep 39
I'm having trouble removing the main steering wheel bolt, did you guys use a torque wrench if so how many pounds? No luck getting it off with a standard socket wrench.
01-16-2013, 08:18 PM | #122 |
Rep 39
03-04-2013, 09:19 AM | #123 |
302
Rep 133
Drives: 2022 G82X individual
What happened to the pictures? Was looking to use this excellent DIY...
03-21-2013, 06:10 PM | #124 | |
115
Rep 1,470
thanks for the DIY
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
03-28-2013, 06:39 PM | #126 |
168
Rep 1,792
As a public service: tighten your steering wheel to 46~47 ft lb, or 62.5 nm per the service manual. I saw 75ft lb posted somewhere in this thread, and that's too much torque!
03-31-2013, 09:58 AM | #129 | |
86
Rep 340
Agreed:
Helpful thread. rewiring on BMW is much easier than Audi, I'll say that =) Here's mine... nice mod.
'24 G80 Base in Dravit/Full-Kyalami, Allocated January 9th, delivered April 30th. Sandlapper CCA.
"Team 6SP/Moonroof" |
04-30-2013, 04:01 PM | #130 |
314
Rep 8,496
for those with 6MT, do you still have to route a plug to the center console (near the shifter)? I'm just curious why there's a need for one plug to go to the center console.
05-11-2013, 01:11 AM | #131 |
coupe la goon
373
Rep 1,645
Drives: green, black, white
Garage List 2011 BMW 1M Coupe [10.00]
2013 BMW M3 Coupe [10.00] 2010 BMW 535i xDriv ... [0.00] 2008 BMW M3 Coupe ( ... [0.00] |
I installed my performance II non-electric today, loving the end product. I am curious though, upon initial startup I was welcomed with the high battery discharge rate warning. Could I have buggered something up by disconnecting the negative terminal, or is the pure coincidence?
06-26-2013, 12:52 PM | #132 |
Rep 11
e90 330i with a tiny problem in BP Ele. Steering Wheel v1.
Good day!
My e90 330i just built this BP Ele.Steering Wheel, everything is going well, ONLY one tiny issue...No Oil Temp Show Up? Need Coding? Or Re-Connected Battery?(We did not do disconnect Battery in this time.) I just found two versions of Instruction of installation from BMW AG, I used the 2008 version. Any Suggestion? Many thanks! Tony |
