01-06-2022, 10:21 PM | #111 | |
632
Rep 1,234
All Fluid Change
In hindsight, I might have more seriously considered the Red Line oils for everything. At the time when I changed out all of my fluids, I was concerned about the warranty police and I heard that the OEM oils were good/great (Especially the Life Guard tranny oil) so I used them. Plus there was so much banter back and forth on here about which diff oils to use and all that, I stuck with what I could articulate to my indy. If I keep my M and make it to another future all-fluid change, it will be Red Line for sure. |
01-06-2022, 10:24 PM | #112 | |
632
Rep 1,234
Seriously...
The guy is amazing and he was the now retired shop foreman's right hand man/second in command. When I heard him say that, I was like okay... And of course I didn't have it in writing, so even though I figured he was correct it's my engine. Good chance I'll just stick with the Red Line 0W30 LL01-FE even in the warmer months. If I notice any issues with higher engine temps at a track day or something, maybe consider the Motul Sport 5W40. But despite all the banter about these engines needing thicker oil, I have a feeling that will not happen. We'll see... |
01-06-2022, 10:45 PM | #113 |
424
Rep 901
Wow, keen eye there! You're indeed correct. We were all saying BMW was bullshitting when they pointed out that the filter was after-market.
https://www.realoem.com/bmw/enUS/sho...diagId=11_4185 https://www.realoem.com/bmw/enUS/sho...diagId=11_5927 |
01-06-2022, 11:06 PM | #114 |
360
Rep 1,340
01-06-2022, 11:19 PM | #115 | |
1416
Rep 1,564
01-06-2022, 11:20 PM | #116 | |
2177
Rep 4,118
OX3537DECO BMW Engine Oil Filter Kit - Mahle OX353-7D 550i, 550i GT, 550i GT xDrive, 550i xDrive, & more |
01-06-2022, 11:21 PM | #117 | ||
360
Rep 1,340
01-06-2022, 11:25 PM | #118 | ||
360
Rep 1,340
The dealer is at fault for the oil, not the filter in this case. |
01-06-2022, 11:28 PM | #119 |
Rep 27
https://www.ecstuning.com/b-genuine-...iABEgKI0PD_BwE
I had both n63 and s63 the filter are not the same, if you look fitment under change to 50i it said does not fit |
01-07-2022, 12:17 AM | #120 | |
371
Rep 1,038
At that you point you can take it up with ECS/FCP as to why they falsely state that it is a suitable part, but good luck on getting a new engine out of them. That's probably what happened during the pre-purchase inspection, and now that dealer is on the hook. The //M p/n: 11427848321 only fits into M. BMW (not talking about fcp/ecs) don't list it as a compatible filter for 50i. Bottom line is, if you have warranty, don't fuck with it, just buy as per spec. Last edited by Chilled; 01-07-2022 at 03:15 AM.. |
01-07-2022, 01:24 AM | #121 |
1398
Rep 764
Drives: 2019 BMW X6M
The previous owner of my E70 X5M ran 10W-60 oil from about 45K-65K miles when I bought it. Two BMW reputable Independent shops I consulted had opposite opinions, one saying it's bad for the engine, the other saying nothing to worry about. I switched to OW-40 LL01 compatible since and it's been running like a champ for 20K miles since I got it. I also know the previous owner ran it hard that he got a new transmission and turbos on them before I purchased it.
My point being that even if 10W-60 is bad for the S63, there had to be other circumstances aside from the oil that caused this catastrophic failure. Best of Luck to the OP to resolving this.
2019 BMW X6M
2013 Lexus RX450H 2010 Nissan GTR AMS Omega 14 Last edited by Autobacs; 01-07-2022 at 11:24 AM.. |
01-07-2022, 07:37 AM | #122 | ||
360
Rep 1,340
https://www.autocare.org/government-...s-Warranty-Act FCP is not wrong. MAHLE lists this one as the OE replacement for both the 50i & M, plus several other cars. https://web.tecalliance.net/mahle-ca...%252F7D/detail |
Autobacs1397.50 |
01-07-2022, 11:25 AM | #123 | |
1398
Rep 764
2019 BMW X6M
2013 Lexus RX450H 2010 Nissan GTR AMS Omega 14 |
01-07-2022, 08:06 PM | #125 |
1522
Rep 1,494
OP, I am sorry what happened to you, but let me chime in here about oil.
BMW has every legal right to deny any cost sharing since 10W60 was used and not LL01 or LL01 FE (which I would avoid like a plague, but will come to that later as why). However, oil is not responsible. Any engine can run on thick oil. You cold start sometime has oil 200x thicker than at operating temperature. Yes, 10W60 is not optimal for various reasons (loss of performance, mpg, more heat) but unless you redline it for 20 minutes at 0 degrees after car spent two nights outside, it is not that. My take is that engine was neglected before, and BMW did not help by switching to LL01 FE oils. Rod bearings are an issue on some BMW's, especially N54/55 when oil pump is not primed after OFHG replacement. On top of that, there is evidence of rod bearings failing since introduction of LL01FE oils. BMW, like other companies, switched to lower HTHS oils to bump CAFE compliance. But these engines and others in BMW line up are really designed with minimum HTHS of 3.5cp. LL01 FE are usually around 3.1cp and IMO, for S63 HTHS of 3.6-4 is optimal. That is what matters (I wrote about this extensively in M2 and F80 forums). In S63 probably best oil one can use is Castrol Edge 0W40 (it doesn't have anymore LL01. Long story, again I explained in details in those subforums). As for some oils mentioned here, let me clarify some things. Motul 5W40 Sport is NOT LL01 compliant nor it is compliant to any other approval. It is track oil which means higher oxidation than what manufacturers like. Redline 0W30 is also not very good solution. It is also ester based oil and has high oxidation. If LL01 is imperative, Motul X-Cess 5W40 GEN2 is very good oil, Pennzoil Platinum Euro 5W40, etc. However, those out of warranty Castrol Edge 0W40 is best bet. I wouldn't be surprised this engine was either on LL01 FE or even on ILSAC GF oils and then was abused. 10W60 didn't kill this engine. It could be that it pushed it over the edge. There was already a problem and this oil was what it needed to die. |
01-07-2022, 10:43 PM | #126 | |
1398
Rep 764
I agree, use of the 10W-60 alone did NOT kill this engine. The use of a different filter also other than OEM, provided the oil was being filtered, is not going to kill an engine. Ridiculous for BMW to even imply so.
2019 BMW X6M
edycol1521.50 |
01-07-2022, 10:48 PM | #127 | ||
1522
Rep 1,494
If that was the case, it was just matter of time. |
sly1types431.50 |
01-07-2022, 10:59 PM | #128 | |
632
Rep 1,234
Weird...
Anyway, glad you mentioned it. Thank you. |
01-07-2022, 11:13 PM | #129 | ||
1522
Rep 1,494
BMW LL approvals have highest oxidation standards in industry. New 2018 update is so high that eliminated pretty much all 0WXX oils in LL01 and LL04 category. But, even before Sport was always oil between X-Cess (all necessary approvals) and 300V. 300V is your ultimate racing weapon. But not so good choice for daily driving. So Motul offered Sport as option for track and dropping kids to daycare. Still, ester based, high oxidation, loaded with track specific additives. Here is Sport pds from 2014. Only specification in meets is API SM. Excellent oil, but unless you see track on weekends, not best choice: http://webshop.swindonpowertrain.com...s/Sport_5W-40_(GB).pdf |
01-07-2022, 11:33 PM | #130 | |
632
Rep 1,234
LL01-FE
Motul makes their Specific which is compatible. Curious what you would recommend. Thanks |
01-08-2022, 12:09 AM | #131 | ||
1522
Rep 1,494
But, SAPS byproduct is, as far as I remember, 1.42%. That is ridiculous SAPS byproduct. More SAPS, more CBU. I personally think anything above 1.2% is too high for DI engines. BMW obviously thinks it is ok as it is approved oil, but still. If warranty is still on, yes. Otherwise, LL01 is what to go or pretty much any oil that has MB229.5 approval. IMO, Castrol Edge 0W40 is best bang for a buck. PAO based, stout HTHS, excellent cold pumpabilitiy, really good Noack for 0W40 oil. |
01-08-2022, 07:49 AM | #132 | |
109
Rep 175
