06-05-2014, 10:29 AM | #111 |
344
Rep 686
"Sure, the 18" 513M is 8.92 kg (front) and 9.44 kg (rear). The 19" 437M is 10.4 kg (front) and 10.6 kg (rear)."
Southlight posted this in the ETK thread, but I wanted to add it here for future reference 18" 513M front = 8.92kg (19.6lbs) rear = 9.44kg (20.8lbs) 19" 437M front = 10.4kg (22.9lbs) rear = 10.6kg (23.4lbs) |
06-09-2014, 11:45 AM | #112 |
112
Rep 969
In theory, E46 M3 Style 67s should work too for winter use.. I found a good deal on 'em on eBay so I'm bidding on them.
The fronts would use a 15mm spacer I presume.. And the rear should be fine. The rears will be slightly more aggressive and the fronts would be tucked in, so it'd look a little goofy but using them for winter use.. I guess I don't care. Fronts. Rears. |
06-20-2014, 06:04 PM | #113 |
BimmerPost Supporting Vendor
8301
Rep 18,872
Drives: BMW
Wheels: 19x9.0 Front (ET29) 19x10.0 Rear (ET40), Style 437M Tires: 19": Michelin Super Sport: 255/35-19, 275/35-19 Front: 45.90lb w/ tire Rear: 49.50lb w/ tire According to TireRack data, tires weigh in at 24lbs for 255s and 27lbs on 275s. Front: Style 437M, (no tire): 21.9lbs Rear: Style 437M, no tire: 22.5lbs
sly1types431.50 |
06-24-2014, 10:01 AM | #114 | |
Commander-In-Chief
2206
Rep 8,949
OEM wheel weights
06-25-2014, 03:39 PM | #115 |
Super modder
104
Rep 1,973
I am wondering the same thing or will re-barreling solve the issue???
SOLD - 2005 E46 M3 ZCP - I/B on black CURRENT - 2011 E90 M3 - meticulously modified 2015 X1 Xdrive 28i |
07-10-2014, 12:12 AM | #116 |
173
Rep 2,355
Thanks for the 1010 calculator. Very helpful.
I have read carefully and found out that there is no BBS LMR/LMS/RSGT wheel that can fit the vision of my car.. I was hoping to get something like 19x10/19x11 set up.. but dont think so... so.. im lookin at 19x9.5/19x10 set up? Looks weird ? or just square set up with spacers?... I dunno.. anyone with BBS and is an expert that can help me out or recommend the spec I should get? I'd like to get staggered look and I dont want 20s, as they are too big and too easy to break considering the road conditions in my area. I do plan to lower it with H&R first or wait for more info from KW. I also do have M adaptive suspension option. Not sure if it matters. PS. I have F80. Thanks
2015 F80 Fully loaded (minus the CCB) YMB M3 / Individual Amaro Brown
BBS | KW | Vorsteiner | IND | Akrapovic | BMW CF Performance Interior | Brembo | Eibach 2008 E92 335i (sold) |
07-11-2014, 05:28 PM | #117 |
Rep 32
07-22-2014, 09:52 AM | #118 | |
INSTAGRAM: @yaasplease
166
Rep 1,023
I entered stock rear 19s into the system and asked for 11inch wide with ET40 with 295/35/19, but the rolling diameter does not change anymore if I was to change the width of the rim again with the same 295mm wide tires. Any idea?
2015 ///M4: M/Vorsteiner Aero, P3Cars, HRE R101, Dinan S2, Coils & Intake; Eis/Akra Exhaust
2013 WRX Hatchback: LED Conversion, Blacked Out, Rally Armor 2015 Macan Turbo: Techart Exhaust, Cargraphics Lowering Module, Blacked Out |
07-22-2014, 09:53 AM | #119 |
166
Rep 1,023
Separate question, what's an acceptable level of difference for rolling diameter?
08-11-2014, 09:31 AM | #120 |
166
Rep 1,023
Anyone able to clarify the questions above? Thanks.
08-13-2014, 07:17 PM | #121 |
Commander-In-Chief
2206
Rep 8,949
OEM Manufacturer
Don't think this had been posted; the wheels (at least 19s) appear to be manufactured by Fuchs in Germany, as were the E92's, based on the hallmark on the back ("Fuchs" is German for Fox). Fuchs is a longtime OEM manufacturer for BMW and Porsche. They also market Porsche wheels directly. They appear to utilize an 8,000T forge which you can see on the second link.
http://www.fuchsfelge.com/index.php?id=135&L=1 http://www.fuchsperformance.com/wheels.cfm
08-13-2014, 09:10 PM | #122 | |
35
Rep 285
08-14-2014, 03:33 AM | #123 | |
European Editor
10633
Rep 22,992
^^That's pretty cool! FUCHS also makes a retro wheel for new 911's in very large diameter sizes. 19's, 20's and 21's. I remember seeing a set of these wheels(just the wheels) for something like 6K euros!! Dackel
09-04-2014, 03:42 PM | #125 |
22
Rep 210
So does anyone know why we were left with a "weak" / conservative offset in the rear for the new F8X cars? If anything that just tells me they really dumbed down the fender flares (I feel that's what made the e46 m3 so special, the delta between a regular 3 and m3 is so extreme on the road). Delta between 435i and M4 seems to be close to nill... but then again the 4 was a "widened" 3 coupe to begin with (following in Audi's footsteps w/o a doubt)... perhaps there was little more performance gains to be had by sticking a wider track with blistered fenders?
09-06-2014, 06:13 AM | #126 |
Gone Fishin’
7318
Rep 12,125
They are only like 1lb per wheel more than zcp in 19. I doubt you would notice that.
09-17-2014, 04:09 PM | #127 |
76
Rep 296
Forgive me if this has been answered already, but I'm new to the Bimmerverse, and I can't seem to find what the lug size is for the M4. I'm planning on ordering new extended lugs before my F82 arrives, and I want to make sure I order the correct size.
09-17-2014, 04:13 PM | #128 |
Commander-In-Chief
2206
Rep 8,949
Lug size
Lug diameter is 14mm. Vendors can supply the correct length based on spacer thickness.
09-17-2014, 04:16 PM | #129 | |
76
Rep 296
So what specifically is the size for the M4 lugs? 14x? Last edited by Revartr; 09-17-2014 at 04:35 PM.. |
09-17-2014, 04:46 PM | #130 | |
European Editor
10633
Rep 22,992
M14X1,25
