07-21-2022, 08:22 AM | #90 |
///M Powered for Life
11517
Rep 10,344
SS as far as I'm concerned
07-21-2022, 08:30 AM | #91 | |
11517
Rep 10,344
We have no brake cooling. To drive the car on the street with ducting is a huge pain. Once we do the GTMore suspension setup which includes steering limiters then we may look into it again. We did ample testing and the calipers/rotors do not reach temps out of range no matter how you beat on the car or who is driving it with zero cooling, so we are not in a hurry to add cooling. With the alcon system, you simply cannot overheat them on the track. Cooling will aid in pad wear only so it's not high on the list. Note that these statements don't apply to most BBKs. The Alcon has a 36mm 380mm front rotor that is a beast and is a huge heatsink. The CCBs work very well when paired with Giro rotors. So far our favorite pad compound is the GP40/20 combo, much better feel than RSL29s. There are two different oil sensor setups, one for the CS/GTS and one for the ZCP/Civic M3s. The first only requires a spacer change and the other requires a sensor+spacer/stud change. Within the ZCP/Civic setup, one kit uses a OEM sensor and the other uses an aftermarket sensor, that is the one that's out of stock. I'm not sure I understand your question about GT4. Are you asking why I didn't change to a dip stick like the GT4s? If so, I like the electronic measuring system and am not a fan of dipsticks, it seems like everyone has 'their' way to measure it and there's too much subjectivity. The M4 GT4 doesn't, as far as I know, have a different pan etc
clutchdj1909.00 |
07-21-2022, 08:37 AM | #92 | |
1040
Rep 927
07-22-2022, 04:18 AM | #93 |
576
Rep 685
Looks like Xmas comes early for The Twins. Can't wait to see them in person! Excited for the build and looking forward to more pics and reactions.
SYT_Shadow11517.00 |
07-25-2022, 07:30 PM | #94 | ||
705
Rep 871
07-27-2022, 11:56 AM | #96 |
11517
Rep 10,344
They do not.
So far I've had 3 BBKs, PFC, AP and Alcon. The only ones that had an antirattle option were the APs and they were if anything louder than the others. And remember you aren't supposed to run on track with the antirattle, so there's yet another thing to prep in the morning! None of the track BBKs are designed to use on the street. I haven't had issues in years of driving them on the street, but your experience may vary |
07-27-2022, 01:53 PM | #97 |
533
Rep 1,415
The Alcons come with some sort of anti rattle hardware for the rotors, or thats what one of the reps at Bimmerworld told me the hardware was for at least, and I think the product description also mentions this. When purchasing, however, another rep told there are no anti rattle clips.
I had occasional rattle on mine the first few months but its gone away. All I ever hear now is pad squeal. One trick when I did have rattle was to do a quick brake pedal application. I think that brought the pads closer to the rotor giving them less room to rattle. That's what I thought was happening anyway. |
07-27-2022, 02:03 PM | #98 | |
11517
Rep 10,344
Antirattle clips on the rotor/hat interface are an absolute must and all kits have them. It's the ones on the pads I referenced earlier |
07-27-2022, 10:30 PM | #99 |
4041
Rep 3,548
Drives: 328d Wagon, M2 Comp, i4 eD35
Essex says it's totally fine to run the anti-rattle/pad tension clips on track. I asked them about this last year.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
08-13-2022, 12:21 PM | #101 |
432
Rep 940
[QUOTE=D_SheerDrivingPleasure;28933518]
So if we are supposed to use 7.3L or 7.71 quarts, what happens if we just put in 8 quarts or 7.5L. Does the car give an error? Does it foam the oil? I'm going to be installing my sensor kit this week. I am excited as it will give me some peace of mind since i run takeoff DHs. I know stock was 6.5L or 6.8 quarts, but i would always do 7 quarts. I also always change my Redline 5w40 every track weekend (3days), usually right before the next one.
F80 M3-DCT MaxPSI CH, BM3 with F80 Paul E85 and Custom Rom track tune MCS 2Way Remotes
Signature SV104 E46 M3 F85 X5M https://www.instagram.com/fastmacm3/ |
08-14-2022, 04:43 PM | #102 | |
11517
Rep 10,344
[QUOTE=sly1types;29217837]
Here's the logic we use OEM M4 GT4 takes 8.4L OEM M4 GT4 has no oil pan changes to allow it to take more oil. It does have a dipstick to measure the level correctly. BW mod shows 'max' at 7.3L --> We fill to 7.3L so the oil shows it's full, then add a full quart. That gets us close to the OEM M4 GT4. --> If after tracking a few days the computer says the oil is full, that means it consumed one quart, so another full quart goes in. Said differently, the 'full' setting after the BW mod serves as a low engine oil warning for us. |
08-14-2022, 06:41 PM | #103 | ||
432
Rep 940
[QUOTE=SYT_Shadow;29221205]
I was just worried about foaming. I just over change it as I already went through a set of rod bearings, but I think most of it was from the low HTHS of liquiMolly and changing every 6 days. Now I only run redline5w40 every 3days as it has one of the highest HTHS ratings.
SYT_Shadow11517.00 FrankMstein1039.50 |
08-20-2022, 09:20 PM | #104 |
11517
Rep 10,344
Some people asked about the OEM GTS aero cracks, here are some pics This is what the other side looks like The OEM design has a T connection between the upper and lower foils. The Slonik piece, as expected, improves on the OEM design Two foils joined by flat areas vs a T
08-20-2022, 10:28 PM | #105 |
892
Rep 1,266
Drives: 2016 M4 GTS
Wow! That Slon GTS splitter looks amazing!
2021 X5M Comp Marina Bay Blue
2016 M4 GTS Alpine White 2005 M3 Comp Interlagos Blue Instagram: @JustAnothaM4 |
08-21-2022, 01:55 AM | #106 |
255
Rep 295
Thread is very inspiring and informative!! Thank you as usual!
Some questions about oil and fuel starvation For oil starvation, are you just getting an oil pressure light that comes on during turns? Or something worse? How do you know? For fuel starvation, other than loss of power how bad is this? And I read correctly that there's no fix for this yet? |
08-21-2022, 08:53 AM | #107 | |
11517
Rep 10,344
No oil pressure lights or anything of the sort. The first time the red oil light turns on in a regular car you're probably out an engine. The oil system in M cars is great, but it was slightly downgraded from the E9X to the F8X, going from 1.4g to 1.3g. Then BMW upped it again for the GTS and later for the CS back to 1.4g. 6.5L --> 1.3g civic & ZCP M 7L--> 1.4g GTS & CS 7.3L--> 1.46g what this kit reads 'full' at 8.3L--> 1.66g if you add another liter once the measuring system says it's full With this kit we can get a regular M and take it beyond the oiling capabilities of the GTS for almost no cost and retaining the electronic measuring system. Fuel starvation: you know if it happens, as it cuts power completely and sometimes will turn the car off. It is correlated to pace/grip and doesn't happen unless you're under half a tank regardless of pace. Once you're fast enough to trigger fuel starvation your only option is to start each session with a full tank and all that extra weight. Like the oiling system, this is another area where the F8X regressed vs the E9X. This kit will be coming out soon. |
08-21-2022, 09:06 AM | #108 | |
1040
Rep 927
[QUOTE=sly1types;29221509]
Redline = $/good |
sly1types431.50 |
08-21-2022, 10:04 AM | #109 |
255
Rep 295
Thanks, I understood the benefits of adding more oil, but was curious what the symptoms or experience is like when you exceed the limits of the G forces on a certain amount of oil.
I used to have a 350z back in the day. It would consume some oil and when the level got lower, the oil light would come on during heavy braking. It didn't kill the engine but that let me know it was time to add some or do an oil change. It's also crazy to me that you can fit so much more oil in there without messing something up and without upgrading oil pan lol |
08-21-2022, 11:40 AM | #110 | |
11517
Rep 10,344
And it finally validates why Steve Dinan repeatedly said we had to run 1L extra on the stroker engine. Sometimes things sound crazy until we finally come full circle |
Audioslave686165.00 |
