12-17-2020, 12:24 PM | #89 |
463
Rep 524
Great results for 23psi. Good stuff.
12-18-2020, 06:57 PM | #90 |
1105
Rep 1,607
Drives: 2020 M8 Comp First Edition
So figured out the LC issue. It's the tcu tune. I flashed the stock tcu back n no launch issue but 3rd gear onwards car is slower than evolve tcu tune. I have requested evolve to keep stock parameters for 1st and 2nd gear and 3rd gear onwards there tcu tune is perfect. Let's see what they say Monday? Thx
GT
2020 BMW M8 Comp First Edition 2019 Panamera Turbo 2021 BMW X6M Comp 2019 BMW M5 2018 Maserati Ghibli SQ4 GranSport |
12-19-2020, 05:56 AM | #91 | |
1416
Rep 1,564
For example, on my E70, I can run 4 gallons with 18 gallons of 91, this will max out the fuel trims and air fuel ratio will go up to around 13.1 from 12.7 but timing increases with E85 so it's a net gain, I don't feel safe adding anymore however as it's starting to get on the lean side. With the 5k fuel pressure the S63TU3 runs at in your M, there should be more headroom for a higher E85 mix so seeing the logs would be very interesting. |
12-19-2020, 10:37 AM | #92 | ||
1105
Rep 1,607
GT
12-19-2020, 10:40 AM | #93 | ||
1105
Rep 1,607
GT
12-19-2020, 07:13 PM | #94 |
1105
Rep 1,607
Finally able to do a better launch and also changed air filter from KNN to Injen. This with Evolve TCU tune
GT
12-20-2020, 07:21 AM | #95 |
3620
Rep 4,532
12-20-2020, 08:46 AM | #96 |
1416
Rep 1,564
Impressive numbers GTATX, wasn't that long ago numbers like they were reserved for full blown dragstrip beasts that barely idled and most likely didn't even have an interior
I don't use fusion but below is a link I found for enabling logging. Grab rpm, throttle, pedal, air/fuel ratio, timing (timing for each cylinder if possible), fuel trims, boost and boost target, knock sensor data (if possible)and air intake temps to start off with. Look for timing corrections, you will start to see a pattern with how the DME adjusts timing depending on load and throttle position, what you are looking for are sudden drops in timing at wide open throttle in the middle of a gear (timing changes during gear changes are normal). |
GTATX1105.00 |
12-20-2020, 10:05 AM | #97 |
1105
Rep 1,607
I'm sure if I do 3rd gear 40 mph start it would be better but from dig this was good as well.
GT
12-20-2020, 11:42 AM | #98 |
3620
Rep 4,532
12-24-2020, 04:21 PM | #100 |
1105
Rep 1,607
I was able to do this today I wish I could share in dragy but it's invalid. It's the same road I use and some how slope is less some days n then higher others in same spot but regardless good times.
GT
2020 BMW M8 Comp First Edition 2019 Panamera Turbo 2021 BMW X6M Comp 2019 BMW M5 2018 Maserati Ghibli SQ4 GranSport Last edited by GTATX; 12-24-2020 at 04:44 PM.. |
YanoM5507.50 |
01-15-2021, 07:21 PM | #101 |
1105
Rep 1,607
New 1/4 mile personal best.
Project gamma intake with AFE filter.
GT
FloridaM5462.50 |
01-16-2021, 09:31 AM | #102 |
240
Rep 978
Tuning
Excellent times and work. Keep it up. Evolve will now be my tune of choice.
2021 M340i
2020 X3 M40i - her car 2019 M5, AW, DP's, MSR CAI, BM3, SOLD 2020 Chev. ZR2 Bison truck, Daily Driver |
