07-18-2015, 11:56 AM | #89 |
1596
Rep 3,945
Drives: 2015 M4 MG/SO
Too much
2 days old M4, it's like I have a dozen rattle snakes inside the car. Most annoying from the driver door, taking it it dealer and letting do the work. I expected some rattles here and there with our crappy roads here, but this is beyond acceptable and annoying.
07-18-2015, 04:01 PM | #90 |
344
Rep 573
I have gone through all of the rattle fixes (thanks Parky!) but still have one coming from the instrument cluster or HUD. I've placed felt tape on the plastic frame and rubber around the HUD but the rattle persists. Anyone else have this problem? Have a solution? :
"When you're racing, it's life. Anything that happens before or after is just waiting."
07-18-2015, 05:30 PM | #91 | |
1596
Rep 3,945
07-18-2015, 06:46 PM | #92 | |
573
Rep 1,990
Did you try driving the car with hud plastic frame removed? |
07-18-2015, 11:41 PM | #93 | ||
344
Rep 573
07-22-2015, 12:34 AM | #95 |
95
Rep 140
I consider myself very fortunate. I only have 1 very minor faint rattle coming from overhead light. Car 99% silent other than that 1 minor rattle.
Yep, if your car is under warranty I highly encourage everyone to just take your car back to the dealer and let them deal with it. That's what warranty is for. If you try and fix the rattle yourself and you start opening up panels and start breaking clips the dealership may blame it on you. |
07-23-2015, 10:35 AM | #96 | ||
344
Rep 573
07-23-2015, 10:42 AM | #97 | ||
344
Rep 573
07-23-2015, 12:03 PM | #98 | |
573
Rep 1,990
I haven't tried to take that piece apart yet. Do they come out easily without taking off steering wheel? |
07-23-2015, 12:51 PM | #99 | ||
344
Rep 573
07-23-2015, 12:55 PM | #100 |
Part Time Firetruck Crash Barrier
792
Rep 1,567
My car has recently become the creakiest SOB around. It all seems centered around my roof to be honest and not in any of the areas mentioned, though perhaps its traveling from those three rear clips on the back deck. I will check those after work. When it goes in for its 10k service I'm gonna put in a complaint for tons of interior rattle and have them batten down the hatches.
m340ix Mineral Grey/Tacora Red |
07-28-2015, 05:06 PM | #101 |
514
Rep 709
Just wanted to pass along this solution for anyone experiencing creaks coming from driving up or down uneven surfaces such as driveways or over speed bumps. What sounded like it was coming from the roof or b pillar around my ear was actually coming from the rubber door seals on the doors themselves "creaking" while rubbing against the door jamb. Gummi Pflege helped but it was very temporary - only lasting around 3-4 weeks.
This 3M "teflon" tape solution seems to be permanent. This post from another forum explains the fix and DIY with photos quite well, so I'll just refer to it here: http://www.bimmerfest.com/forums/sho...5&postcount=40 Long story short, the teflon tape (3M 5425) applied where shown in the photos (although I went with thicker tape and covered the areas where any of the door rubber seals met the paint on the door jamb) around the entire door frame solved my problem. It may help you as well. Note that the 3M tape is a BMW part that is quite expensive ($200). http://www.ecstuning.com/ES197360/ You can try to pawn some off of your dealer's service department as a roll would easily take care of several cars. Alternatively, you can try a different teflon tape. This works well, but you'll need 3/4 of a roll per door: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Last edited by TonySCV; 08-03-2015 at 04:45 PM.. |
07-28-2015, 05:25 PM | #102 | |
573
Rep 1,990
I used following felt tape instead of teflon tape. http://www.tintprotector.com/strips/ However, this only works on black car since felt tape itself is black. |
07-28-2015, 07:44 PM | #103 | |
514
Rep 709
07-28-2015, 11:13 PM | #104 | |
573
Rep 1,990
I had it for last few month, and it still looks as good as first day I applied. |
07-31-2015, 05:50 PM | #105 |
1596
Rep 3,945
Took it in, and after all the work they did, it is as rattly as before. But curious about what is crash pads in front doors (coupe)? The Buzz/rattles still coming from driver door...
This is what they did to no avail: - applied felt tape on crash pads on both front doors - applied felt tape on dash middle trim - installed missing clip in A pillar trim The master tech told me straight out that they will not gut out the car to take care of every rattle/squeak/buzz but what they did was useless... |
07-31-2015, 11:34 PM | #106 |
277
Rep 579
These rattles are a bit concerning especially on a brand new high end BMW in 2015. Anyone know if this only affects certain build dates. If I do decide to buy it will be the LCI post July build so any idea if BMW has done anything about this?
Rattles are a major issue for me and if I'm spending $150K aud on a car I'd expect better |
08-01-2015, 02:57 PM | #107 | |
1596
Rep 3,945
In the first week, I had all these rattles and still have them, cracked windshield, noise in steering/tire something, a dented door and a chipped wheel and today I noticed a 1" scratch in my clear coat just buy it and don't worry about all this, the car is amazing still |
08-01-2015, 11:10 PM | #108 | |
573
Rep 1,990
I took my car to dealership to have them fix rattle. I guess tech who drove the car has hearing issue because SA told me tech did not hear any rattle. There are few more things that I did to my car beside suggestions posted here. With so many hours spent on my car to fix rattle, noise level is now very acceptable. |
08-01-2015, 11:21 PM | #109 |
1596
Rep 3,945
I hear you... The most annoying for me is the driver' door buzz/rattle. I may probably do it when I order my speaker upgrade since that requires dismantling the doors. Thanks for the DIY. I am curious why some cars have these rattles and some owners say they don't ...
