04-04-2018, 05:52 AM | #89 | |
10545
Rep 41,221
Drives: 2018 Alpina B6 650ix GC
2. No.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
04-10-2018, 11:47 PM | #91 |
10545
Rep 41,221
PM sent.
05-02-2018, 09:06 AM | #92 |
1394
Rep 2,130
Do you know what CAFD id need to replace this one?
HU_NBT2 [63] readCPS o.k. CAFD_00001EF6_006_031_018 Fehler: File for "cafd_00001ef6_006_031_018" not found! [C012] Also, would injecting a new CAFD lose the new sport displays when MPPSK was installed?
Previous: 2010 F01 740d M Sport | 2015 F36 420d M Sport
Current: 2018 F36 440i M Sport (Stage 1 BM3, xHP stage 3) |
05-04-2018, 09:35 AM | #94 |
10545
Rep 41,221
PM sent.
05-08-2018, 06:09 AM | #97 | |
10545
Rep 41,221
05-22-2018, 02:36 PM | #98 |
Rep 3
shawnsheridan
Hey Shawn, I am having some issues coding HU_CIC for my vehicle. here is some info that I have, can you help? the I-Step Current is : F020-13-03-503 The error message is : HU_CIC [63] [F978639] readCPS o.k. CAFD_000000F9_007_006_009 Fehler: File for "cafd_000000f9-007_006_009" not found! [C012] I am using E-Sys 3.28.1 The Psdzdata that I have is Extracted from ISTA-P version 63.3.003 The package contains cafd_000000f9-007_006_010 and cafd_000000f9-007_006_008 but not 009 Thanks! |
05-22-2018, 03:00 PM | #99 | |
10545
Rep 41,221
https://mega.nz/#!IpQ01AQR!jf-XLY3ce...ARyg4lpdkbtTJw Copy to C:\Data\psdzdata\swe\cafd.
06-01-2018, 03:19 PM | #100 |
Rep 7
Hi guys,
Newbie here! I have a F21 1 series. I recently had to buy a new head unit from ebay as mine stopped working (was restarting every couple of minutes). Unfortunately the new head is not allowing/giving me the option to use USB for music or even the bluetooth/telephone. I read up about coding and have installed Esys and been playing around with it, and got as far as activating the digital speed display! My head unit ECU shows up as "HU_ENTRY", however there is no CAFD file within this hence I am unable to edit this. I would greatly appreciate any help to help me make the USB and bluetooth function to work again please! Thanks a lot! |
06-01-2018, 03:23 PM | #101 | |
10545
Rep 41,221
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on HU_ENTRY => Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level shown (bottom one) => Select OK => Right-Click on HU_ENTRY (the ECU itself not the underlying CAFD) => Select CODE. I trust you have some plan to get your original 81 Media Player (USB) FSC Code Imported and Activated in replacement head unit.
06-01-2018, 03:31 PM | #102 | |
Rep 7
"I trust you have some plan to get your original 81 Media Player (USB) FSC Code Imported and Activated in replacement head unit" - excuse my ignorance Shawn! I dont know what this means |
06-01-2018, 03:40 PM | #103 | |
10545
Rep 41,221
As for FSC Code, Head Units can have what are called "FSC Enabling Codes", which are digital certificates signed with BMW AG's private Encryption Key to enable certain features such as Navigation, Voice Control, Sat Radio, CarPlay, USB, etc. I am pretty sure your old Head Unit had a 81 FSC Code to enable USB function, perhaps others. These need to be transferred (Imported and Activated) in replacement Head Unit.
06-01-2018, 03:46 PM | #104 | |
Rep 7
06-01-2018, 03:57 PM | #105 | |
10545
Rep 41,221
06-10-2018, 12:16 PM | #106 |
Rep 46
Hi,
I have flashed my FEM_GW on my F30 LCI with success from I-Step current F020-17-03-505 to F020-18-03-524. I have unchecked both VCM and MSM update options. No problem, it was success. Then I tried to flash my HU_ENTRYNAV, but it went wrong. all sw is updated, but I lost my CAFD file, and an unknown file is there. HU can not start, it has a blue screen saying: Maintenance Image Version I15411A_prod. I tried to insert an CAFD file, but got the error: Caf's suchen Tal wird generiert Abarbeitung wird gestartet TAL execution started. VCM Update: VCM-Update is deactivated. VCM will not be updated. [C197] ExecutionID=2018/06/10-17:15:28.562 [] prepareTALExecution started [] prepareTALExecution finished [] prepareVehicleForCoding started [] prepareVehicleForCoding finished [HU_ENTRYNAV - 63] prepareECUforCoding started [HU_ENTRYNAV - 63] prepareECUforCoding error [HU_ENTRYNAV - 63] There was an error during TAL execution, please check the log files. [HU_ENTRYNAV - 63] - [Exception - HU_ENTRYNAV - 63] SVK-Ist does not match expected SGBMIDs for ecu ECUId:HU_ENTRYNAV_0x63. Excpected (relevant process classes only): [ hwel_000019fa-004_003_003, btld_00001aba-130_020_001, swfl_00002250-130_020_001, swfl_00002251-130_020_001, swfl_0000225e-130_015_001, swfl_0000225f-130_015_001, swfl_000022c4-130_011_001, swfl_0000245b-130_020_001, swfl_0000245c-130_020_001, swfl_0000245d-130_020_001, swfl_0000245e-130_020_001, swfl_0000245f-130_020_001, swfl_00002460-130_020_001, swfl_00002461-130_020_001, swfl_00002462-130_020_001, swfl_00002465-130_020_002, swfl_0000246d-130_020_002, swfl_0000268d-130_011_001, ibad_0000246a-130_011_003, flsl_0000246e-130_020_002], Actual (relevant process classes only): [ hwel_000019fa-004_003_003, flsl_0000246e-130_020_002, btld_00001aba-130_020_001, swfl_0000245c-130_020_001, swfl_0000245d-130_020_001, swfl_0000245e-130_020_001, swfl_0000245b-130_020_001, swfl_0000245f-130_020_001, swfl_00002460-130_020_001, swfl_00002461-130_020_001, swfl_00002462-130_020_001, swfl_00002250-130_020_001, swfl_00002251-130_020_001, swfl_0000246d-130_020_002, swfl_00002465-130_020_002, unkn_46464646-070_070_070, swfl_0000225e-130_015_001, swfl_0000225f-130_015_001, swfl_000022c4-130_011_001, swfl_0000268d-130_011_001, ibad_0000246a-130_011_003], Missing SGBMID(s): [], Surplus SGBMID(s): [unkn_46464646-070_070_070] [HU_ENTRYNAV - 63] finalizeECUCoding started [HU_ENTRYNAV - 63] finalizeECUCoding finished [] finalizeVehicleCoding started [] finalizeVehicleCoding finished [] finalizeTALExecution started [] finalizeTALExecution finished TAL execution finished TAL-Execution finished with status: "FinishedWithError". [C207] TAL execution finished. Duration: "59s". [C206] Abarbeitung beendet How do I delete the unkn_46464646-070_070_070 so I can insert e nw CAFD file ? I really hope you can help me, thanks in advance. |
06-10-2018, 12:27 PM | #107 | |
10545
Rep 41,221
IN any event, in SVT Actual, Edit it in SVT-Editor, and delete "unkn_46464646-070_070_070", then try flash again.
06-10-2018, 01:10 PM | #109 |
10545
Rep 41,221
06-11-2018, 11:43 AM | #110 |
Rep 46
I tried that, but got a new error when i tried to flash:
TAL execution started. VCM Update: VCM-Update is deactivated. VCM will not be updated. [C197] Fatal error while executing tal! [] - [Exception - UNKNOWN] FA must not be null when trying to execute a TAL containing coding transactions Asynchrone programming failed! [C049] FA must not be null when trying to execute a TAL containing coding transactions [1358] |
