Autotalent
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Engine / Drivetrain / Exhaust / Bolt-ons / Tuning
      10-24-2022, 08:38 PM   #89
CKP42027
Cayman Islands
Drives: BMW M4
any updates on this just hit 55k Miles squeaking started
? BMW F82
?? Cayman Islands
? Bootmod3
@eurogruppe.ky
      10-24-2022, 11:47 PM   #90
CKP42027
Cayman Islands
Drives: BMW M4
did you remove the springs inside ?
? BMW F82
?? Cayman Islands
? Bootmod3
@eurogruppe.ky
      11-29-2022, 02:30 PM   #91
F82keo
Drives: 2015 BMW M4
Originally Posted by chicken1 View Post
I am now getting a p112f code has anyone else gotten this?
hey, i’m also getting this code after the fix, did you resolve it? & if so, what did you do? I keep clearing it but it always comes back next drive
      12-11-2022, 03:34 PM   #92
chicken1
9
Drives: e92 m3
I ended up just replacing the valve cover
      12-13-2022, 12:30 PM   #93
slaughter.mode
slaughter.mode's Avatar
Drives: 2018 M4 Competition
2018 BMW M4 ZCP  [9.80]
I got this the first time I did the mod and it was due to a bad seal in my intake. I took it apart and put it back together and it went away. It could also be a vacuum line. This mod worked flawlessly for me until I blew the motor a few weeks ago (too much sauce on the stock internals).
      12-23-2022, 04:04 AM   #94
Dabeamerking
Dabeamerking's Avatar
119
Drives: m4
Valve cover squeal easy fix. Get the repair kit ebay Amazon $20. Get cutters and snap off carefully the old valve one side without interrupting the inner piece of the valve cover that holds the valve onto the valve cover. Use a screwdriver to pry it out. Remove spring permanently. Gut new valve orange all off so all you see is black. Drill a few holes and glue back on. Take off heat shield temporarily for a few days under the charge pipes between CP and valve cover so you can drill extra holes if need be. Congrats. You might get the code that’s everyone else is looking doeirencing above but it’s fine
      12-24-2022, 07:27 PM   #95
sul6anom3
Saudi Arabia
Drives: BMW M3 F80
I changed the valve cover and the other piece 7502023 , The whistling sound is gone, but when I open the oil cap, there is still a strong vacuum or SuctionHonestly, I was very disappointed after I changed the new cover and everything was new
      12-24-2022, 07:38 PM   #96
slaughter.mode
That’s supposed to happen. Working as intended.
Instagram: Slaughter.Mode
      12-26-2022, 05:49 PM   #97
sul6anom3
Saudi Arabia
Drives: BMW M3 F80
I compared it to two other cars, they do not have strong suction, and I returned the programming stock and checked with ista it twice, there is no error
      12-27-2022, 09:02 AM   #98
slaughter.mode
You could have a vacuum leak somewhere or an intake pipe not reinstalled properly. It's a pretty common thing when folks reassemble their cars after fixing their PCV. Unless you are getting a DME code or the car has a rough idle, I wouldn’t worry at all. What happens if someone hits the gas pedal while it’s open? Are you sure it’s actually suction? It sounds like a loud hissing noise but have you put a rag over it to validate it’s sucking vs blowing?
The stock PCV is designed to open and close but ultimately it’s protective core function is to vent excess pressure.
      01-01-2023, 05:05 AM   #99
BGut12
BGut12's Avatar
Drives: 2016 F80 M3
just started getting this squeal the other day and this thread is extremely helpful. my question though also like someone stated, is the removal process the same as some videos i’m seeing on the N55 in which they use a dremel to cut the top into 4 pieces and then heat and pry off the plastic carefully? just want to know if it’s the same way for the S55 before i destroy something.
other than that, the main question i have is how are you just popping this cap off whenever you want and adding extra holes here and there? isn’t it supposed to be glued back on or does it just stay on tightly itself?
thanks for any help!
Bart
      01-01-2023, 03:11 PM   #100
slaughter.mode
I used a dremel and cut one side (carefully) and then popped it off. If you do that method you need the aftermarket/Amazon replacement cap. You can use a sealant if you want but I didn't, it fits snug and never pops off. The trim underneath the valve cover should keep it seated.
BGut12100.50
      01-01-2023, 03:26 PM   #101
BGut12
BGut12's Avatar
Drives: 2016 F80 M3
ok thank you. i already ordered the replacement cap on amazon so i guess it doesn’t matter how i get it off. praying this method helps, but i also ordered a crankcase vent hose and the VAS to just do everything i can easily get my hands on at the same time.
Bart
      01-02-2023, 02:54 AM   #102
Dabeamerking
119
Drives: m4
Waste of money buying a crankcase hose. Might as well buy the oil catch can at that point
      01-03-2023, 10:47 PM   #103
BGut12
BGut12's Avatar
Drives: 2016 F80 M3
will probably do that thanks.
Bart
      01-03-2023, 10:52 PM   #104
BGut12
BGut12's Avatar
Drives: 2016 F80 M3
so update: took off old cover and drilled the holes the same way as OP. put it on and seals pretty damn tight with no silicone or anything. will do a final update tomorrow once everything’s put back together, waiting on parts right now.
in the meantime, is it normal for there to be this much buildup/residue under the cap? (pic attached) i’m at 60k miles if that makes a difference.
Bart
      01-04-2023, 01:38 AM   #105
Dabeamerking
119
Drives: m4
Yea everything is normal. Let us know what happens. But I end up just changing my valve cover regardless
      01-04-2023, 09:35 AM   #106
slaughter.mode
I personally didn't have this much buildup in mine but I also run a oil catch can which captures this gunk. It isn't anything to be worried about.
BGut12100.50
      01-04-2023, 10:54 AM   #107
Dabeamerking
119
Drives: m4
Changed 100+ s55 valve covers. This oil buildup is normal as the oil spits up towards the valve cover to get into the camshaft and valves. Oil catch can absolutely will help this.
BGut12100.50
      01-04-2023, 05:45 PM   #108
BGut12
BGut12's Avatar
Drives: 2016 F80 M3
so i drilled 8 1/16th holes like i showed in the pictures. i put everything back together, replaced the VAS and the CCV hose, and went on a drive. unfortunately, it’s still there and just as prominent as it was before. no change in sound. even when i open the oil cap and rev it’s still there. normally when you open the oil cap and it goes away that’s definitely the PCV right? so if it’s still there what can it be, or do i just drill more holes? let me know what you guys recommend now, thanks.
Bart
      01-04-2023, 05:51 PM   #109
slaughter.mode
Let’s back up. The first step you do to validate it is in fact the PCV that failed is open the oil filler cap while idling. If the loud squeal goes away it’s most likely the pcv that has failed and this fix will most likely do the trick. Did you do that before performing this fix?
      01-04-2023, 06:12 PM   #110
BGut12
BGut12's Avatar
Drives: 2016 F80 M3
i knew i should’ve just to check but i didn’t, just figured it sounds similar to everyone else’s and ran with it. i guess now i have that done in any case for the future. but anyways, now i really can’t figure it out. i looked around at all the hoses and connections and can’t find anything loose. i recorded another video to try and get exactly where the sounds coming from, which it seems like it’s coming from the front of the charge cooler and in between the valve cover, right in the middle. i also feel air pushing out at me from the front where i circled in the picture, is that normal? now i’m just thinking anything isn’t normal lol
the only other thing i noticed was one of my set screws that go into the meth bung in my charge pipe was gone, but is it possible that’s why it’s making that noise?
Bart
f80post
