11-01-2021, 05:07 PM | #90 |
453
Rep 277
I doubt it'll make much of a difference. I could have left the AT cooler on and just pulled the trans lines to act as a second tiny cooler but I'd rather keep it tidy under there.
2009 Widebody 135i ///Build Thread
Instagram: ///TheAxisGarage If you ride like lightning, you're gonna crash like thunder. |
11-05-2021, 02:44 PM | #92 |
453
Rep 277
The beautiful GS6-53BZ MT showed up today. I've got almost everything I need to do the swap so I'm going to start removing the AT this weekend.
Decided to go with XClutch. Purchased the Chromoly Flywheel, 9 in. Twin Solid Organic Clutch Disc kit (XKBM23595-2G), good for 900ft-lb Still waiting for the Turner coolant relocation tank.....
Instagram: ///TheAxisGarage If you ride like lightning, you're gonna crash like thunder. Last edited by Dieselboy; 11-05-2021 at 03:18 PM.. |
houtan707.00 ResinThirteen190.50 |
11-06-2021, 06:55 PM | #93 |
453
Rep 277
Auto trans out, took about 6 hours. Getting to the trans/engine bolts was the hardest part. Just waiting on the clutch and flywheel now.
houtan707.00 |
11-09-2021, 04:03 PM | #94 |
453
Rep 277
Removing the AT wiring harness.
11-14-2021, 05:12 PM | #95 |
453
Rep 277
Still waiting on the clutch, shifter linkage and some brackets/misc parts.
houtan707.00 cerealwars87.00 |
11-14-2021, 10:58 PM | #96 |
Working towards usefulness
161
Rep 239
Usually a spectator while people build/solve given that everyone has their ideas that work for them, but ….if you’re waiting on shift linkage have you considered alternatives……such as:
https://coolerworx.com/shop/short-sh...r-bmw-gearbox/ or something similar? For me the difference in feel versus the stock linkage was literally night and day. Really appreciate your documentation.
09 128i Slicktop - Ohlins MI01S1, KMac Plates, M3 RSFB, M3 RSB, Hotchkis FSB/endlinks, 1M brace, Wavetrac, Coolerworx, JKVK headers, RPM Motorsport Tune, Yokohama A052 255/40/17s
Dieselboy453.00 |
11-15-2021, 06:47 AM | #97 | |
453
Rep 277
11-21-2021, 01:32 PM | #98 |
453
Rep 277
The 9" Solid Organic Twin Disc Clutch from XClutch showed up today. Most of the parts I need to finish up the trans swap and to get the motor started keep getting pushed out so may be a while before the next update..
houtan707.00 |
11-24-2021, 05:01 PM | #100 |
453
Rep 277
Bye bye torque converter, hello clutch. I can finish the catch can plumbing and figure out where I'm going to relocate the vacuum canisters while I wait for parts..
12-03-2021, 07:41 PM | #102 |
453
Rep 277
Turner expansion tank relocation kit arrived (ordered in Sept), and it looks like a few more parts shipped out. Hopefully I can make some decent progress this month.
Attempting to remove the pilot bearing using grease and Pascal's Law, haven't been able to get it to budge though. May need to get a lever actuated grease gun... Youtube made it look easy using this method...
Instagram: ///TheAxisGarage If you ride like lightning, you're gonna crash like thunder. Last edited by Dieselboy; 12-04-2021 at 02:29 PM.. |
12-06-2021, 10:17 AM | #103 | |
dances with roads
4763
Rep 4,100
12-06-2021, 11:35 AM | #104 | |
453
Rep 277
BMW PN: 21-20-7-536-792 - Clutch Pilot Bearing, Flywheel Bearing, Cylindrical Roller Bearing R 219900
12-06-2021, 05:39 PM | #106 |
453
Rep 277
It pilots into the shaft on the flywheel. You can see it in the second photo in post #100.
Ok, had to bust out the big guns. Couldn't have been easier, 3 pumps and it popped right out. Always use the right tool for the job! (You vs. the guy she tells you not to worry about)
Instagram: ///TheAxisGarage If you ride like lightning, you're gonna crash like thunder. Last edited by Dieselboy; 12-06-2021 at 05:45 PM.. |
ResinThirteen190.50 wdb4762.50 |
12-07-2021, 08:40 PM | #107 |
453
Rep 277
Random black friday purchase. I think they look good, and should make rev-matching downshifts easier.
12-07-2021, 08:55 PM | #108 |
Rep 3
Can you provide the part numbers used to convert from auto to manual? I’ve search the forums, but there isn’t any information in regards to the 1 series, specifically the 135i.
12-08-2021, 11:25 AM | #109 | |
453
Rep 277
I plan to put together a DIY once I finish the swap. I'm still waiting on a few things before I put the trans back in and do the coding. Here is a list of what I ordered, not all the PN's are listed though. I used https://www.realoem.com/bmw/enUS/select to figure out the parts I needed. Hope this helps.
