10-25-2021, 10:23 AM | #89 | |
2039
Rep 2,680
10-25-2021, 10:45 AM | #90 | ||
2039
Rep 2,680
There is a radical shift in car manuf. coming where h/w will not be as big of a differentiator as s/w in the coming years for ev and hybrid vehicles. |
Moflow2484.50 |
10-25-2021, 10:54 AM | #91 |
3666
Rep 2,060
Well i guess we have 1-2years left if we want new BMW with integrated dash display. My lease on X3 M40i is up late next year so hopefully the 2023 X3M or X5 still has old dash. I can’t see myself buying new M2 with new layout though.
10-25-2021, 11:38 AM | #93 | |
1289
Rep 1,675
AndyinHou479.00 |
10-25-2021, 03:29 PM | #94 |
6375
Rep 2,386
Drives: Z4 M40i
10-25-2021, 03:37 PM | #95 |
624
Rep 803
Although the new M2 will have 455 horsepower, it will also be bigger, longer in length and weigh 3,800 pounds plus.
tracer bullet2545.00 |
10-25-2021, 04:00 PM | #96 |
224
Rep 551
I am really hoping that the M2 smooths out all of the awful lines and shapes on the M240i’s super busy front and rear bumpers.
That alone will improve the look of the car. Right now the 230i sport pkg looks way better the the M240i. Also please make the lower side skirts body colored while you are at it. Thank you. |
10-25-2021, 04:18 PM | #97 |
1283
Rep 842
Looks like they're starting to reveal more body lines with this mule. The tacked on fender flares look like they're gone and the square openings down low are a little softer.
10-25-2021, 05:16 PM | #98 |
217
Rep 632
10-25-2021, 08:35 PM | #99 |
224
Rep 551
I was going to add that about the front fenders but I thought I might be seeing things. Your right and you can also see more of the front grill. No beaver teeth.
10-25-2021, 11:35 PM | #100 | |
1996
Rep 1,759
Ultimately, I believe the M Performance range will and should have the bucket seats option down the track as it aligns with the image and functionality demanded by a good portion of the G87 demographics |
10-25-2021, 11:41 PM | #101 | ||
19323
Rep 8,113
Drives: 2024 X5 M60i
Instagram: @Phxrisingphotography
Current - 2024 G05 X5 ///M60i in Java Green Past - 2005 E53 X5 3.0i in Titanium Silver; 2008 E92 335i in Montego Blue; 2019 G01 X3 M40i in Glacier Silver; 2022 G80 M3 Competition in Twilight Purple |
10-26-2021, 02:56 PM | #102 |
1319
Rep 2,352
I've checked through the press releases for the M4, M440i, M240i weights to see what the likely weight is of the M2 in 6MT and 8AT guises, analysis below:
M240i xdrive is 1690kg Adding xdrive to the M440i and M4 is 45kg and 50kg - I'm guessing the difference is due to rounding as they only go in 5kg increments. Changing from M440i to M4 for rwd and xdrive is 30kg and 35kg, again I'm guessing the difference is for the same rounding reason. M4 8at to 6mt is -25kg. So starting from the M240i xdrive weight of 1690kg, we should lose about 50kg for a RWD M2, gain about 35kg for the 'M' weight gain (extra coolers, bigger brakes etc) and if going with a 6MT lose another 25kg. G87 M2 6MT - 1650kg G87 M2 8AT - 1675kg From the same international press releases: M4 6MT - 1700kg M4 8AT rwd - 1725kg M4 8AT xdrive - 1775kg F87 M2 6MT - 1495kg F87 M2 Comp 6MT - 1550kg F87 M2 CS 6MT - 1550kg F87 M2 7DCT - 1520kg F87 M2 Comp 7DCT - 1575kg F87 M2 CS 7DCT - 1575kg So from an F87 Comp to G87 you're going to gain about 100kg, or 220lbs for the same configuration
SCOTT26 "So as an admirer of the M5 and a potential customer of an M5 Touring. I would run naked around the streets of Garching if they were to offer one."
10-26-2021, 05:23 PM | #103 | |
Plenipotentiary
2614
Rep 3,046
10-26-2021, 06:08 PM | #104 | |
7668
Rep 3,444
- at least 2.5x more expensive - dealers will mark it up even higher - you will not get it anyway unless you already own a Porsche and have an existing relationship with a dealer Or, put it another way: Your advice is no different from recommending an M2 to someone looking to buy a base 228i (the FWD one). |
7
PLF693771.50 tracer bullet2545.00 heavyD^23688.50 manuelf353.50 JustinHEMI7453.00 xlover2198.50 W///7532.00 |
10-26-2021, 06:09 PM | #105 |
7668
Rep 3,444
stein_325i25175.00 GrussGott18207.50 |
10-26-2021, 06:11 PM | #106 |
7668
Rep 3,444
X3 is not getting it (too close to G45). X5 will.
10-26-2021, 09:05 PM | #108 | |
Moderator
30014
Rep 13,167
///M is art ↔ Artemis
10-26-2021, 10:07 PM | #109 |
2983
Rep 1,623
