Official e90post 60-130 Times List!
05-24-2011, 10:51 PM | #89 |
Work Smarter!
15
Rep 105
11.6 60-130 V Box
335xi Coupe 6speed Stick 1 shift JB4 map 7 HPF FMIC, Full Custom Exhaust, aFe Intake with scoops, 104oct --------------- Best results --------------- Time 03:05 Date 25/05/2011 Speed(mph) Time(s) 0-60 11.1 0-100 178.0 60-130 11.6 50-70 ---- 0-100-0 ---- i hope that i did this right.... Last edited by 39nas-t; 05-24-2011 at 11:08 PM.. |
05-24-2011, 11:29 PM | #90 | |
Modder Raider
762
Rep 8,633
Drives: M3
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
05-26-2011, 10:54 PM | #91 | |
Modder Raider
762
Rep 8,633
Drives: M3
Thanks.
05-27-2011, 08:05 AM | #92 | |
158
Rep 1,288
Drives: 2014 435iX, FBO
1) There is an error somewhere or 2) your mom was driving 3) you started in 4th, while eating a pizza and texting your sister....
2020 M2 Competition HS, DCT, 763s, Carbon: splitter, side skirt, grill, diffuser, wing
Previous: 2014 BMW F32 435iX - JB4, MHD Flash, BMS Meth Kit, ER Intercooler, intake, catless DPs, KW Streets, 437M Reps with 245/35 and 275/30 Michelin PSS 4S |
05-27-2011, 08:22 AM | #93 |
829
Rep 3,982
Since it is a 60-130 run, he probably isn't interested in getting the best launch, or wasting the run up to 60mph heating up the intercooler, etc on full boost. Or he may have just been cruising making sure everything was set in the right gear, etc, to mash the throttle right before 60mph.
2011 Alpine 335d M-Sport 12.34 @ 110.48mph
2019 i3s Terra, 2008 Black 335i Sedan. 11.11@ 129.47 mph 2008 Monaco Blue JB3 2.0 335i Coupe. 11.33 @ 132.77 mph, 60-130mph: 6.95 seconds 2023 i4 M50 11.48 @ 121.56mph, 3.43 0-60 (dragy) |
05-27-2011, 01:17 PM | #94 | |
Work Smarter!
15
Rep 105
this is what I was doing? ahahhhahhaha at lunch i shot up to the local choke and puke and ate a burger and fries then on the way back with 3 people in the car i went 0-60 in 4.5X on the v box not sure if that is good or not but it was fun. launched it pretty light like around 3 grand ish stock clutch hooked right up and away we went. Hotrod I am logging the car today and then shooting the logs over to terry for some tweaking! VERRRRRY EXCITE!!!!! |
06-05-2011, 10:56 AM | #95 |
829
Rep 3,982
I did a 7.28 second 60-130 today. Took a 131.8mph qtr mile trap to achieve this!
2019 i3s Terra, 2008 Black 335i Sedan. 11.11@ 129.47 mph 2008 Monaco Blue JB3 2.0 335i Coupe. 11.33 @ 132.77 mph, 60-130mph: 6.95 seconds 2023 i4 M50 11.48 @ 121.56mph, 3.43 0-60 (dragy) Last edited by hotrod182; 06-06-2011 at 01:32 AM.. |
07-10-2011, 03:36 AM | #96 |
15
Rep 88
guys is it safe to assume between 11s-12s for a 6MT e92 with these mods:
JB4 map2 FMIC DP DCI 93 octane could it be less than 11s? anyone tried it with the same mods? |
07-11-2011, 10:59 PM | #97 | |
30
Rep 1,041
I have improved my time to 11.71 the other day after adjusting my tune a bit, but I know it can improve a bit more more, so I'll wait before I send in a new file, but I'm expecting to hit ~11.5s. With the JB4, you may be able to go a little faster.
E92 335i 2008 Space Grey 6MT | Pure Stage 2 turbos | Motiv PI | Trueform Tech Intake | Quaife LSD | M3 Suspension kit | Öhlins Road & Track Coilover | DEFIVfab N54 diff lockdown kit | COBB PTF E85 Map | Fuel-It Stage 3 LPFP | NGK 5992 plugs | Wagner FMIC | Wagner 3" DP | Milltek exhaust | Tial BOV | SPEC Stage 3+ clutch | SPEC Steel SM Flywheel |
07-16-2011, 10:48 PM | #98 |
30
Rep 1,041
Well. I finally found the time and place to test again after I adjusted the performance on the Steinbauer box. It had been turned down to ~80% before I installed FMIC and DP's and I never got around to adjusting it afterwards. Well, I did now. I don't know how much more I can turn it up (it can be adjusted from 50%-130% and it's now at 100% (pot).
Exactly the same mods as in post #73, I will repeat here anyway: My car is a E92, 335i MT. Time was done in 3rd and 4th gear (1 shift) The mods of my car are: Steinbauer ECU Tuning (piggy bag), Wagner Tuning FMIC, Wagner Tuning 3" catless DPs, BMS DP fix, AFE DCI Stage 2 air intake, Forge DV's (green springs, yellow are going in tomorrow) Quaife ATB LSD, BMS speed delimiter (not that it matters for a 60-130 time...) I run on pump Shell V-power 99 octane (in Denmark), it's the same as 93 in the US afaik. The time was 11.33 seconds, with somewhere between 0.1 and 0.2 sec worth of wheelslip @ ~93 mph Screenshot below, file sent to Mr.5
07-17-2011, 08:52 PM | #99 |
Modder Raider
762
Rep 8,633
Drives: M3
Congrats GI Joe!
File is legit and the list has been updated.
07-18-2011, 12:27 AM | #100 |
30
Rep 1,041
Thanks, I wasn't expecting to get below 11.5 actually, so I was quite exited when I saw the result myself
I'm putting the yellow springs in the Forge DV's this evening to see if I can up the performance just a little bit more on pump gas.
09-02-2011, 01:36 PM | #101 |
30
Rep 1,041
Well. I just picked up the car from the dealer today after having 5 out of 6 injectors replaced (free of charge, service bulletin)
I have also added som Cyba Scoops since my last post, and this time I found hill with a little more slope (still within 3%), however this time I had a full tank of gas and some luggage on board. My car is a E92, 335i MT. Time was done in 3rd and 4th gear (1 shift). I think installing the M shift knob in stead of the regular one (since the 11.33 sec time) has helped me shave at least 0.1 sec of the gear change. The Cyba Scoops definately helped as well. The mods of my car are: Steinbauer ECU Tuning (piggy bag), Wagner Tuning FMIC, Wagner Tuning 3" catless DPs, BMS DP fix, AFE DCI Stage 2 air intake, Forge DV's (yellow springs), Cyba Scoops, Quaife ATB LSD, BMS speed delimiter This run was done on pump Shell V-power Racing 100 octane (in Germany), it's the same as 94 in the US afaik. The time was 10.83 seconds. Vbox .dbn file sent to MR.5 Now I am waiting for my catback exhaust to arrive next week
09-08-2011, 05:04 AM | #102 |
30
Rep 1,041
I guess Mr.5 is busy racing his car somewhere, or maybe I'm the only one still active in this thread...
09-16-2011, 01:51 AM | #104 |
30
Rep 1,041
Cool, them I'm not the only one still trying
09-21-2011, 10:33 AM | #105 |
Work Smarter!
15
Rep 105
How many other XI guys are trying to do this...?
I am putting in my new High Pressure Fuel Pump tomorrow and then I am going to try to do a few more pulls and see what i can get her down to. Last edited by 39nas-t; 09-21-2011 at 10:57 AM.. |
09-21-2011, 12:36 PM | #106 |
65
Rep 1,708
09-21-2011, 12:38 PM | #107 |
Work Smarter!
15
Rep 105
We need to keep this going it is a fun thread and gives us something to shoot for......we need more people that are willing to put up their times too
09-24-2011, 11:33 PM | #108 | ||
Modder Raider
762
Rep 8,633
Drives: M3
I'm still going to verify the times, but I haven't been around in a while. I would love to do more 60-130 times but if I would try it in my e36, I'd be lucky to hit 20 seconds. lol! I'll be first on the list for the F80 M3 though. List is updated.
09-25-2011, 12:02 AM | #109 | |
30
Rep 1,041
09-28-2011, 10:27 PM | #110 |
273
Rep 5,876
mr. 5, sent you a file for verification
8.9sec 60-130mph Pump gas + 70/30 meth COBB stockish custom map (stock timing, stock boost, 12 AFR) JB4 progressive meth upping boost to 18.5-19psi (too aggressive for pump gas and some timing was pulled) FBO Wavetrac LSD Race Weight of car: 3540lbs + 225lbs driver = 3765lbs 19" wheels 245 tires front, 17" wheels and MT ET DRs on the back Dual CM7 nozzles Next time out it'll be on full weight again but on race gas instead of pump and I'll have my street tires on the back as DRs might be a tad slower at a low psi for 60-130 runs...i'll also try going down to a single CM10 nozzle for a bit less flow FWIW, my best on stock turbos with weight reduction (seats out) 20psi and race gas+meth was 10.5secs Last edited by dzenno; 09-28-2011 at 10:58 PM.. |
