05-08-2018, 01:42 PM | #89 | |
84
Rep 399
-David
Zap35.00 |
05-09-2018, 09:19 AM | #90 | |
35
Rep 199
05-09-2018, 11:34 AM | #91 |
84
Rep 399
I did front and rear retrofit. Rears were flush with the double-sided tape that comes on the brackets. Same issue as OP with fronts. With the double-sided tape the front sensors weren't flush so I removed the tape and used epoxy.
-David
06-13-2018, 10:32 PM | #92 | |
690
Rep 2,719
Drives: M3
Garage List 2016 BMW X5M [0.00]
08 BMW M3 [0.00] 14 BMW X5 50i - sold [0.00] 09 BMW 335i - Sold [0.00] 09 BMW 328i - Sold [0.00] 07 BMW 328i - Sold [0.00] |
I'm not sure if you noticed after coding the front PDC that it beeps slower than the rear PDC... it was bothering me and I read through TRC and found the solution to make them beep at the same rate. The sounds are different so no confusion whether it's front or rear.... front PDC frequency: FREQUENZ_TONGEBER_VORNE - code from: wert_02 to wert_01 and if for any reason someone wants a slower beep in front and rear PDC same token code: rear PDC frequency: FREQUENZ_TONGEBER_HINTEN code from: wert_01 to wert_02 hope that helps!
Evolve, Eisenmann, Strasse, StopTech, Active Autowerke
08-12-2019, 04:54 PM | #93 |
35
Rep 199
Random question - I am planning to do the front retrofit at some point. I recently did a rear view camera installation, and I figured it would be nice to have the PDC button since I'll eventually put the front sensors in.
Does anyone know how the PDC button is coded? (I'm guessing it gets enabled by default coding if you swap $507 for $508). UPDATE: I poked around in the PDC module, changed pdc_schalter (PDC Switch) to aktiv. When I am in reverse the button now toggles PDC and camera on and off, but it doesn't work when the shifter is in any other position. So the switch is good, and the car sees it. I'd be curious if anyone has a dump of their PDC's coding data after $508 - left to wonder if there's another setting to change or if it will only work once the retrofit is complete.
F30 (2017 340xi): 6MT Mineral Grey - CWP, DAP+, Lighting, M Sport, Tech, Track, M Rockers, MPPSK CF
E93 (2009 M3): 6MT Jerez Black - Ext Leather, CWP, Prem, Tech, Rear PDC, Premium Sound M3 Retrofits [Alarm (w/ door sensors), FLA Mirror (Auto High Beams), Dyn RVC, Front PDC] Past (6MT) 2007 E92 SG - 2007 E92 MB - 2014 F30 335xi EB II Last edited by Zap; 08-12-2019 at 08:02 PM.. |
08-12-2019, 10:12 PM | #94 | |
690
Rep 2,719
Drives: M3
You don't need to code the button, once you code the front and read pdc the button will work! At least it did for me..
11-21-2019, 06:19 AM | #95 |
35
Rep 199
I've been slowly buying components to do the Front retrofit on my E93 M3. I have a curious question though - it looks like some sellers have a revised kit for the front PDC retrofit that no longer includes the white sensor brackets.
Is there possibly a new set of kit instructions, or are they just requiring them to be purchased separately? I see two photo versions of the kit online at various sources, so I don't know if some kits are old stock or what the full story might be. The photo at ECS for 66200418637 doesn't show the brackets anymore, so maybe this is a legitimate change by BMW? Any information is appreciated.
E93 (2009 M3): 6MT Jerez Black - Ext Leather, CWP, Prem, Tech, Rear PDC, Premium Sound M3 Retrofits [Alarm (w/ door sensors), FLA Mirror (Auto High Beams), Dyn RVC, Front PDC] Past (6MT) 2007 E92 SG - 2007 E92 MB - 2014 F30 335xi EB II |
11-25-2019, 09:33 AM | #96 | |
84
Rep 399
-David
02-13-2020, 08:33 PM | #97 |
35
Rep 199
A small update, I ordered the Front PDC kit and it did still come with the white sensor brackets. Shipping from Europe took forever (almost 2 months!). So now I have all the parts ready to go and hoping to start on it in the near future.
Doing a little more research I got one of the punch style tools similar to what BMW actually uses to do the installation. It is supposed to create a cleaner hole than the stepped drill bit. I'll update once I get to that stage.
02-21-2020, 08:34 AM | #98 | |
84
Rep 399
-David
03-01-2020, 10:03 PM | #99 |
997
Rep 1,353
Thank you buddy, Your post helped me a lot to complete my Full PDC retrofit among with Rear camera Setup on my CIC+Combox retrofit.
Only one thing I wish it was possible that to code the CIC or PDC somehow to deactivate parking screen after disengaging from Reverse!
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit |
03-21-2020, 05:50 AM | #100 |
17
Rep 80
Thanks for the great DIY writeup.
Few quick questions (the firewall access DIY in the main post link is not clear as photos were linked to Photobucket) 1. To run then PDC harness thru firewall is it the small hole shown in my pic below, that I should be using? Do I need to make a hole thru that rubber? 2. How did you route the wire out of the DME box, i read that we need to seal the DME cover properly to avoid any moisture etc. and I dont see any other place to route the harness out of this white box! Sorry for stupid asks?
Y
04-19-2020, 05:47 PM | #101 |
35
Rep 199
I could use a few tips here - I'm waist deep in this project now. I have the bumper removed and holes cut using the punch. That went smoothly and they look excellent.
Are there any tricks to mounting the sensors to the bumper itself? For those of you that have done this - did you mount them while in the brackets? I have some concern that the gaskets will properly land in the holes as test fitting them on sensors without the brackets resulted in a fit that was a bit tight to get the rubber portion to engage fully. Also, I already have the harness routed to the outside of the DME box. I've removed the DME and carrier, but I'm trying to figure out if there is a way to route the harness through the rubber grommet so I don't compromise the seal of the box itself, or if there needs to be another method employed. Also, once the cable is safely inside the box, will it cleanly feed through to the footwell or do I need to use something to fish it in? Any pointers are appreciated. I'm eagerly looking forward to having the front end and engine bay back together. Then I can tackle routing the wire to the rear of the car, which should be simple as I've done that before when I installed my rear view camera. I updated the switch panel at that time, as well, so once I get the wiring run inside it should mostly be downhill from here!
05-01-2020, 07:10 PM | #102 | |
35
Rep 199
I'll try to report back once I have my M3 back together and I can speak directly about it. (Also, in response to my own thread, I haven't found a way to route the wiring into the cabin without modifying something, so I was going to make a hole in the rubber grommet and then seal it back up so the cable goes in with other wiring and doesn't create a spot for moisture to enter the box!)
05-04-2020, 02:32 AM | #103 |
35
Rep 199
Got everything put back together today - it worked out great once I coded the PDC and CIC modules.
Looks great along with my retrofit rear view camera!
05-21-2020, 05:25 PM | #104 |
Rep 39
Can you list what you coded? And in what module? I can’t get mine to pull up the screen. And my backup camera doesn’t work.
06-03-2020, 01:07 PM | #105 | |
35
Rep 199
I modified the VO to remove $507 (Rear PDC) and add $508 (Full PDC). I then default coded both modules. Before doing this I made a backup of the existing coding, as the camera emulator had specific coding that varied from what would default, and I had changed a few CIC values, such as to enable weatherband. I used a Diff utility that displays the changes side by size in the coding files to see exactly what items were modified, and then returned those back to what they were, and the camera worked again. What is it doing instead of displaying the backup camera? One of the values I had to change for my camera (it may vary by emulator) was to set the PDC Direction to vertical in order for the camera to display. It originally displayed two PDC images instead of the camera. If you default coded and had to have the video input set differently that will also need to be fixed based on what pin your video input hooks to.
06-05-2020, 12:22 AM | #106 |
23
Rep 75
For those that have done the front PDC retrofit with a MT, does the front PDC automatically display when moving forward below a certain speed (my wife's i3 does this), or do you have to press the PDC button? And does the PDC continue to display if you shift into neutral and continue to roll forward (e.g.; on a slight downhill slope)?
The reason I ask is that I currently have rear PDC, and when I shift into reverse to back out of my garage, the PDC comes on as expected. But since my driveway is a slight downhill to the street, I typically just shift to neutral and roll down the rest of the way to the street. Of course when I do this, I loose rear PDC. But what I don't know is if the front PDC works simply by forward motion, or if the transmission must also be in a forward gear. AFAIK, there is only a reverse switch on the transmission (I just replaced it), not a switch for the forward gears, so I don't think there is a way for the front PDC to know. |
10-29-2020, 08:55 AM | #107 |
Rep 2
Thank's for sharing this project with us and i've done everything like u said. Everything is fine exclude of pdc showing thinks reverse. For example a wall being in font of ne but my cic showing this wall is behind me and cic shows thinks front which one actually being behind the car...can anyone help me to solution?
01-20-2022, 08:59 PM | #108 |
86
Rep 374
I have followed all the steps but the module doesnt communicate. it shows red on ISTA. I have checked it has power and CANBUS is properly connected. I am using K-CAN cable. Do I need ICOM cable for coding?
02-22-2022, 11:55 PM | #109 |
Rep 9
Hello, I'm trying to add a front Pdc to my e90, I did them in order.
1. In the FA - Removed $507 and added $508 2. FA_WRITE - CAS 3. FA_WRITE - NFRM 4. SG_Coderien - PDC 5. SG_Coderien -CIC. but the pdc image does not appear on the cic screen, the pdc and the sounds are working, I could not bring the image to the screen, where am I doing wrong? |
Tags |
do it yourself, euro, front & rear pdc, park distance control, retrofit coding |
