11-03-2020, 12:13 PM | #89 |
849
Rep 3,274
I asked them that specifically and they said they checked the alignment and it was all good. So hopefully that is accurate
11-03-2020, 01:42 PM | #90 |
288
Rep 343
Kind of hard to believe that the alignment wouldn't shift, but its possible it is still within spec. I would ask for a print out of the results. Did they need to fix the front too?
11-03-2020, 02:46 PM | #91 | |
849
Rep 3,274
They said... "the instructions were vague" ... uh huh
11-03-2020, 04:03 PM | #92 |
858
Rep 1,566
But the one pictured in your rear spring is an MPHAS part.
11-03-2020, 06:38 PM | #93 |
849
Rep 3,274
I asked them to confirm with part numbers that the correct ones are on now, so we good now at least
11-03-2020, 06:43 PM | #94 |
858
Rep 1,566
11-04-2020, 03:15 PM | #95 |
849
Rep 3,274
Here are the four take offs. Am I good?? Thank you
11-04-2020, 05:12 PM | #97 |
5529
Rep 5,203
You are good. These are my take offs. Can see part numbers if needed.
Old OEM stops have the four dimples...new MP-HAS stops have a crisscross to hold the shaft.
'18 F80 Base 6MT | '19 F82 Exec DCT | '18 F82 Comp Exec DCT | '23 G80cx
11-04-2020, 06:56 PM | #98 |
849
Rep 3,274
Thanks for all your help in this thread. Happy to know now, everything is installed properly, and I am happy with the look and feel.
11-04-2020, 08:24 PM | #99 |
265
Rep 1,696
PKL: Please measure (in mm) your front and rear height. Measure from the bottom of the wheel straight up until the fender. I'm curious to see your measurements in relation to your photos.
RElias21570.00 |
11-05-2020, 09:08 AM | #100 | |
849
Rep 3,274
Bottom of the RIM? Not bottom of the tire/the ground?
11-05-2020, 09:14 AM | #101 | ||
570
Rep 896
That way we are all measuring it the same way in this thread.
Previously:
2010 E92 335 (6MT) 2011 E92 M3 ZCP (6MT) |
11-05-2020, 04:41 PM | #102 | |
849
Rep 3,274
641 mm rear 660 front that's very unscientific, not a very good measuring tape Also found a nail in my front tire
11-05-2020, 05:21 PM | #103 |
849
Rep 3,274
Based on others measurements mine don't make much sense, I'll have to try again with a much better measuring tape that has mm or at least cm
11-05-2020, 05:32 PM | #104 | |
570
Rep 896
With that said, I think your measurements make perfect sense because your car def doesn't look lower than that when comparing to others in this thread with lower heights. Does anyone know if the M4 doesn't go as low with the MPHAS? It's so interesting to me how your car is dialed all the way down, but is still sitting "relatively" on the high side. Here is my M3 for comparison. Def lower and I still have threads to go.
Previously:
11-05-2020, 07:01 PM | #105 |
858
Rep 1,566
Def. looks like something is off on the front, Scott13's M4 is maxed out front and rear (see few pages back on this thread) and his looks dumped compared to yours. If you can take some shots of the front strut setup (left and right) with the wheel off, and steering straight, including bumpstop. Looking at your initial pics you posted it almost appears the sleeve on one of the struts is lower than the one on the other side. But can't tell if it's an optical illusion due to your wheels being turned.
11-05-2020, 10:33 PM | #106 |
265
Rep 1,696
PKL: yeah, get a measuring tape with mm on it. I don't think you measured correctly because 641 mm rear and 660 mm front sounds waaaay too high.
And to answer your question, yes, measure starting from the bottom of the rim (which is the 0 mm mark) then go straight up until you touch the fender. This is the official method to measure per BMW install instructions. Doing it this way will not generate inconsistencies for people who have different profile tires and inflation specs. Here is the measuring tape combo I bought. I used the black retractable one...works well and very cheap! https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Last edited by frankzlin79; 11-05-2020 at 10:39 PM.. |
11-06-2020, 05:47 AM | #107 |
21132
Rep 20,742
Drives: 2021 911 turbo
Indeed, your measurements do not make sense, they fall outside of the HAS adjustment range.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
11-06-2020, 08:50 AM | #108 | |
849
Rep 3,274
Stupid nail in my tire grrrr
11-07-2020, 06:32 AM | #110 |
5529
Rep 5,203
@Megabass what color are the calipers? Very cool look.
