11-02-2016, 07:22 PM | #89 | |
21132
Rep 20,742
Drives: 2021 911 turbo
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
11-08-2016, 08:00 PM | #90 | |
38
Rep 123
I have done this conversion. I have roughly 4k miles on the car with the RB street pads with the rotors and have found this to be a good alternative for me as compared to paying another 10k+ for new rotors. I have been using it on track as well with roughly six 2-3 hr track days on the car (Barber MSP and Road Atlanta) although with a track pad and have been pleased there as well. I have appreciated no significant difference in handling with the added unsprung weight. I am pleased so far with the switch. Yes, there is a difference in feel for the street pad with iron disc in comparison to the CCB set up which took some getting used to. But, within a week I was used to the new setup. There is of course more brake dust than before. But, on the flip side I did lose that lack of brake scary moment when the rotors are cold and wet. I would certainly recommend this as an alternative to buying new CCB rotors. Yes, the cost of the conversion is expensive but much cheaper than the OEM alternative. |
11-09-2016, 05:11 AM | #91 | ||
Plenipotentiary
2614
Rep 3,046
11-09-2016, 07:17 AM | #92 | ||
640
Rep 3,039
11-09-2016, 08:22 PM | #93 |
38
Rep 123
11-09-2016, 08:23 PM | #94 |
38
Rep 123
I have had no brake noise whatsoever with the street pads. The track pads, of course, is a different story. The track pads are not loud on track but they are noisy on the street as is the case with all track pads on iron
11-09-2016, 08:26 PM | #95 | |
Plenipotentiary
2614
Rep 3,046
11-09-2016, 08:49 PM | #96 |
38
Rep 123
You can certainly recode your car however you desire. I can personally attest that there is only a difference in pedal feel and performance as would be expected when changing pads between a street and track compound with a standard iron setup. I find no necessity in doing this if there is in fact a coding option to change. I have no knowledge of BMW coding a brake pedal setup differently between a blue and gold caliper setup. But, again it is all drive by wire these days and there may be a difference in the coding that I am unaware of. Certainly, no problem with feel or performance that would make me seek out someone to do some coding on my car to change anything however. The brakes are still phenomenal with my setup even t without the CCB rotor. I have appreciated no difference in feel with the DSC (in euro MDM mode) as well as with ABS (and yes I do get into threshold braking on track). My 0.02
11-10-2016, 12:05 PM | #97 | |
Plenipotentiary
2614
Rep 3,046
ISTA-P/+ makes this very easy on the M5/6 for CCB to Iron as its the same process...just reversed. The calipers are 99% identical and brake servo is compatible to the settings. No FDL adjustment necessary. The F8x won't be as straight forward due to the significant differences between MCompound and MCCB, but it's not impossible or overly complex. Hell, just FDL coding the 29lb weight increase to the front axle will change the behavior of MDM Mode by a decent amount. No ones twist your arm and if you're ok with it that's all that matters. If you'd like to go to Barber and try a session with it done, I'd be more than happy to do if for you. Several dozen people, including myself, have spent a significant amount of time trying to sort this out and provide factual information for those who don't have the personal knowledge or resources of their own. I even went as far as putting an F80 front corner on our test rig and ran it until it was dead. That along with all the others who have contributed so far is allowing what may be the most comprehensive enthusiast and HPDE guide ever created. There are still a few more people I will be communicating with and willl start getting the docs up in the forum ASAP. |
12-14-2016, 09:29 AM | #98 |
1117
Rep 1,904
I finally got my Carboteq instrument and the first thing I wanted to do was to compare the findings/estimates from weighing the rotors (as previously posted) to the precise measurements as obtained from the Carboteq.
Note that these are the front Rotors which were originally removed based on the state of the "wear indicators". It also appears that the wear indicators might change appearance as they come off the track (from hot/heavy use) and then after running up some local neighborhood miles (general use). I'm wondering if we will actually pick up some more pad transfer material in the wear indicators as the rotors/pads see less stressful use. (IOW - My wear indicators seem to look better after the rotors were removed (after driving around town a bit) than when I was watching them at the track). Anyway, the Carboteq instrument is supposed to be the definitive measurement. At the price for the tool ($6500.00), it better be! It should also be noted, for folks not familiar with the Carboteq or the info stamped on the rotors, that there are three pairs of measurement points stamped onto each rotor. Each of these measurement points contains an upper value (new), and a lower value (done). These Max/Min numbers are separated by a line which is used to align the laser on the Carboteq instrument for a precise measurement at each designated point. These min/max numbers and the Carboteq instrument are all calibrated to work together for precise measurements. The Carboteq can also be used without having to remove the rotors from the vehicle (although the ones I have on hand had already been removed and preserved) The Carboteq instrument is very quick and easy to use and it should be quite precise. *** The first table is the rotor usage as calculated/estimated by the weight of each rotor. *** The second table is the rotor usage as calculated by the values as indicated by the Carbgoteq.
The Jiggery-Pokery is Strong with this One
https://f80.bimmerpost.com/forums/sh....php?t=1645366 https://f80.bimmerpost.com/forums/sh....php?t=1197553 https://f80.bimmerpost.com/forums/sh...4&postcount=35 |
02-04-2017, 05:57 PM | #99 |
Rep 29
Apologies for hijacking this thread but it would not let me post a new thread!
I'm about to pull the trigger on a year old M4. I've wanted this car since I first saw one a couple of years ago so I'm excited to say the least! I've now found the perfect one at the perfect price but my only concern is that it is specced with CCB. Before I sign the paperwork I'm going to have them check the wear of the pads and rotors as I do not want to be bitten with a large bill down the road! My questions are, if the fronts or rears needed replacing, how much would it be? Also if necessary could I retrofit the steel brakes and how much would this save me? I am not planning to track the car and it has done approx 7000 miles, I have no idea if it was tracked. Thanks for your help! |
02-04-2017, 08:38 PM | #100 | |
Bored at work....
893
Rep 5,396
Here's a good price guide for the conversion: http://f80.bimmerpost.com/forums/sho....php?t=1257330 At 7k I highly doubt the CCBs are anywhere near gone. Good luck and don't let a car with CCBs deter you. I love mine ✔️
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD! Anti Matter :2016 F82 M4 GTS What next?!? A 2022 M235i GC- I must be getting old |
02-04-2017, 09:40 PM | #101 |
2792
Rep 4,252
Drives: 2017 M3 MG/SO ZCP DCT
After cleaning my wheels three times in car's first 1200 miles I wish I had CCBs.
schnell325892.50 |
02-06-2017, 02:53 PM | #102 |
1117
Rep 1,904
If the car was NOT used for track events then the CCB's should virtually last forever (almost).
The irony is that they burn off pretty fast if used on a track car, but seemingly last forever on a street car. I purchased a Carboteq instrument ($6000.00!) to monitor the wear on my CCB rotors. Let me know if you want to RENT it! ;-)
IB M2791.50 |
01-18-2018, 12:30 PM | #103 | |
4992
Rep 11,891
I think the CCBs are the same rotors for all BMW, correct?
22 Phytonic/Coffee X5 45e (CoVID-free)
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) |
01-18-2018, 03:02 PM | #104 |
1117
Rep 1,904
Yes but No...
Yes - I believe the M5 and M6 use the same rotors/calipers/pads. Might want to make sure the M5/M6 are the same model years or generation though... No - Not all BMW's use the same CCB hardware. My M4 is different than my M6. All the numbers you see in my posts are for M4 CCB hardware. The M4 is my track car so those are the brakes I need to keep an eye on. I have not weighed the rotors on my M6 or used the Carboteq on them. I don't specifically know what their min weight range is or how much "meat" is on them when new. (I don't track the M6 so there is little worry that they will ever wear out). Again, you don't typically have to worry about CCB Brake wear UNLESS you track the car. They last virtually forever on the street.
https://f80.bimmerpost.com/forums/sh....php?t=1645366 https://f80.bimmerpost.com/forums/sh....php?t=1197553 https://f80.bimmerpost.com/forums/sh...4&postcount=35 Last edited by evanevery; 01-18-2018 at 03:08 PM.. |
01-21-2018, 08:44 AM | #105 | |
405
Rep 589
02-01-2018, 08:23 PM | #107 | |
307
Rep 608
rotors and pads from the factory i don't use cark on the track, but i drive fast (250km/h+ every trip), car is tuned (700hp) If i would go to track - i would change the brakes to AP racing and tires to 18, it much cheaper kill CCB on the track |
IB M2791.50 |
02-24-2018, 11:04 AM | #108 | |
101
Rep 1,086
2016 Z06 current
2013 M3 gone 2011 M3 gone 2007 335i gone |
02-26-2018, 10:04 PM | #109 |
Salty Middle Aged Dog
142
Rep 165
I have a Porsche with PCCB carbon brakes. The shop has a Carboteq.
They tell me not to weigh the rotors, not to Carboteq the rotors. Their considerable advice is to track the rotors until they really begin to visibly look bad, meaning no longer glossy looking. Until then, as long as they have good brake feel, they are fine. At the markups Porsche and BMW are putting on these rotors, it's just morally corrupt. Corvette ceramic rotors are also made by Brembo, and they only cost $1200 each, versus $7000 to $9000 each for Porsche and BMW.
2018 Porsche GT2 RS, Black
2018 Mercedes GLS63 AMG, Black, DD and TV 1997 BMW E31 840i, Black (fully restored!!) |
11-18-2018, 12:24 AM | #110 | |
2792
Rep 4,252
In order to avoid a total failure at speed, which would be dangerous on track or street, you'd have to be confident in the combination of pedal feel and visual inspection. Also keep the data coming - any one have a high mileage street CCB car at this point? |
