European Auto Source (EAS)
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Cosmetic and Lighting Modifications
      09-22-2023, 09:50 PM   #89
NonspecificFindings
Drives: F80
Seems like Bayoptiks is now selling these.
https://bayoptiks.com/collections/f8...oding-solution
      09-23-2023, 05:11 AM   #90
F80manz
F80manz's Avatar
Drives: 19 M4 Comp 6MT
Originally Posted by wt2me View Post
Does Marius have another contact besides instagram?
He's on bimmerforum
      09-23-2023, 05:21 AM   #91
F80manz
F80manz's Avatar
Got them installed on my 2019. Was plug and play. Everything worked without coding but there were malfunctions thrown sporadically even though everything was working. Just no return signal basically from from the lights to the FEM. Marius was able to fix it with some fdl coding.
Below are pictures
One picture is next to a pre-lci White M4. You can see the DRL brightness difference pretty well here.
djpeetur175.00
      09-23-2023, 10:12 PM   #92
wt2me
Drives: BMW M3
Originally Posted by F80manz View Post
He's on bimmerforum
Thanks man. I tried to message him here but his account is set not to receive message. Maybe I’m too new n don’t have the privilege
      09-24-2023, 03:03 PM   #93
PCARBON32
PCARBON32's Avatar
110
Drives: F80, F25
I got no regrets, well worth the money. Headlight have held up great for almost a year already. Only thing is I wish I put on a clear bra on the headlight prior for rock chips
      10-29-2023, 09:50 AM   #94
GrigioM4
6MT Grigio Telesto/ Full Amaro Brown
Drives: F82 M4
Any update on the best place to purchase these and the final verdict for which model headlights require harness + coding vs. Which do not? Seems like F80manz was plug and play but there is conflicting information earlier in the thread
      11-05-2023, 01:18 AM   #95
Miyamodel
Miyamodel's Avatar
15
Drives: 2016 F82 M4
Anyone know if yellow DRL modules will work with these?
      11-13-2023, 06:24 AM   #96
F80manz
F80manz's Avatar
I used Luoma and they were great. But they did grossly underestimate shipping time.
As for which ones require a wiring harness, all pre-lci adaptive headlight cars require the extra wiring. The kits are plug and play for pre-lci and lci non adaptive lights. However, keep in mind that all retrofits will need coding in some capacity.
As far as the seller tells me, no you can not. But I haven't tried to take off any of the modules yet.
      11-18-2023, 07:14 PM   #97
YASBBYM3
YASBBYM3's Avatar
Drives: BMW M4 Cs Lamborghini Huracan
Originally Posted by PCARBON32 View Post
THE ONLY THING YOU WILL NOT HAVE IS ADAPTIVE HEADLIGHTS EVEN THO ON THE HEADLIGHT ITLL SAY BMW ADAPTIVE LED LIKE THE OEM ONES.
Dealbreaker
      11-28-2023, 04:10 PM   #98
patrickhanaway113
Drives: 2015 BMW M4
Did you end up getting them?
      11-28-2023, 04:11 PM   #99
patrickhanaway113
Drives: 2015 BMW M4
did you turn drl brightness all the way up on bimmercode? or is that even an option with these headlights.
Thanks
      11-28-2023, 05:53 PM   #100
patrickhanaway113
Drives: 2015 BMW M4
Any update?
      11-28-2023, 05:56 PM   #101
patrickhanaway113
Drives: 2015 BMW M4
did you end up buying them?
      12-01-2023, 11:49 PM   #102
chipper1
Drives: 2017 M4 zcp DCT Alpine tuned
Man this has me really wanting a set of these. coding is ok but why cant they just get the plugs and pins right so we don't need another harness? geez 2k and cant get the right plug on the head lights..... there has to be a new version by now?
      12-05-2023, 12:38 PM   #103
30FF
Slow Guy
30FF's Avatar
11
Drives: 16' M4
9 pin for adaptive xenons
6 pin for adaptive pre lci led's
8 pin for non adaptive xenons
Appreciate 2
      12-14-2023, 01:01 PM   #104
Bimmer.Plug
Bimmer.Plug's Avatar
136
Drives: BMW G82 M4 & F82 M4
Looks good! We also do IKON headlights.
      12-15-2023, 07:48 AM   #105
aa2033
aa2033's Avatar
379
Drives: 2018 BMW M3
I've read nothing but negative comments about bimmerplug in numerous threads. Also, your link says "designed by bimmerplug in california". I don't believe that for a second. Those are even the same pictures from Alibaba/aliexpress of the headlight housings. They're the same lights, marked up. Which is in line for most of what i've read about your products.
      12-19-2023, 12:49 AM   #106
M4rqu3z
Drives: BMW m4
I ordered a set on Aliexpress from AKD for 800usd during black friday, going to see in a few weeks how they are.
Update: Installed, look good. Don't overpay for these things they're all the same. (Ignore the hoodgap, ill fix it tomorrow
So I’m guessing the adaptive doesn’t work and did you need the wiring from Marius and also how long did shipping take
      12-19-2023, 03:05 PM   #107
M4rqu3z
Drives: BMW m4
[IMG]
View post on imgur.com
What seller did you get this from ?? And do the automatic high beams work stikk and welcome lights
      12-19-2023, 03:52 PM   #108
30FF
Slow Guy
30FF's Avatar
11
Drives: 16' M4
https://www.aliexpress.com/item/1005...1e8b1802XW2eaU
auto highbeams work? do you mean the low beams come on during night? if that's the case yes, welcome lights work fine as well.
      12-19-2023, 03:55 PM   #109
30FF
Slow Guy
30FF's Avatar
11
Drives: 16' M4
Did not need wiring for xenon everything worked straight away besides the adaptive fault, and yes adaptive does not work and needs to be coded out.
      12-19-2023, 04:05 PM   #110
M4rqu3z
Drives: BMW m4
What year is your car because I heard 18 or newer you don’t need the wiring and older
You do
I have a 15 with the pre LCI adaptative LED
f80post
