Alpine Hifi upgrade
06-13-2015, 09:23 AM | #1035 | |
616
Rep 824
Drives: G80 M3CX (Oxide Grey)
I had a faulty coil in one of my subwoofer's and it would cause the amp to cut off whenever the sound dropped below a certain frequency. Fixed it by replacing the subwoofer. You should try disconnecting each speaker one by one to isolate the faulty one (if there is a faulty speaker). Otherwise your amp might be bust! But since you said it happens randomly, and driving over bumps sometimes helps. It could very well be loose wiring! Worthwhile to remove the door card and inspecting the wiring and also the connection from the subwoofer undearneath the seat flooring. |
06-20-2015, 01:36 AM | #1036 |
21
Rep 352
I was going to purchase this kit for my car but BMW say it's not compatible. Looking further into it, it seems they're right as the car has ccc with dab. Apparently the dab module sits where the amp would go. Any thoughts? Not interested in dab so happy to remove it if that's my only option.
06-22-2015, 04:54 PM | #1037 | |
Rep 26
Sbm007 thanks for your reply. I will investigate this further. Over the past week it has been working fine and only gone off a few times and then come back suddenly. I am not very clued up on the audio side of things so may have to seek help from a local audio guy if the issue persists. |
06-23-2015, 08:15 AM | #1038 | |
16
Rep 105
I do find it tricky to believe its simply about the location of the DAB module though, 20mins and a roll of velcro would sort that issue surely..? |
07-05-2015, 05:00 PM | #1040 | |
889
Rep 9,097
If you can work out that, you will be good to go.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
07-31-2015, 07:56 PM | #1042 |
Rep 44
Anyone who has recently installed the -268 Alpine kit (the PnP kit) who can verify whether or not the tweeter cable part is still mis-labeled?
I will be installing this on a lefthand drive model E91 shortly - are there any issues regarding running cables I should know about? Some forum members have reported interference from power cables (though it seems that most people have no issues) Cheers, H. |
08-11-2015, 08:20 AM | #1043 |
Rep 14
I have a pre 3/09 car. The Install Instructions says "This retrofit system does not require coding". Is this correct? I've finished installing and the sound is better than before.
The Hi-fi coding is possible to do also on a pre 3/09 car? |
08-11-2015, 11:07 AM | #1044 |
11
Rep 238
I don't see any need to recode mine either, the upgraded sound is perfectly acceptable to my ears.
08-16-2015, 02:58 PM | #1045 | |
889
Rep 9,097
Pre-LCI kit has lot of issues after hi-fi coding (to do with pdc sound) and bmw decided not to code the cars to avoid all those hassles. Now, corporate politics aside this is how I see it; 1- If you prefer to listen to your music highly equalized or at low volume then there is no need to code it to hi-fi. 2- If you prefer to listen to your music neutrally or at high volume then it is recommended to have it hi-fi coded.
09-08-2015, 06:04 AM | #1048 |
Rep 4
the Price has seemed to have gone up a fair bit on these the BMW website now saying £406.80 just for the kit.. hate to think what they would charge to fit it
09-11-2015, 11:32 AM | #1049 |
1100
Rep 2,598
Getting the best out of the Alpine upgrade?
Hi all,
Rather than start a new thread I thought I'd try this sticky first! I've just ordered the Alpine Kit from Germany (£280!) and also bought some L7 subs to go with it too. I had a E81 with the kit plus the L7 subs & I also replaced the Alpine mids for L7 variants instead. This set up sounded great and to my ears was BETTER than the £800 optional Harman / Kardon set up in my last car (F56 Cooper S) Anyway - this time round I plan to just use the supplied Alpine mids, but I was also wondering if I changed the rear door mids (it's a touring) to say the hifi mids - would the stock head unit actually be able to do anything with them? I know the Alpine only powers the front mids / tweeters / subs so I'm guessing the OEM head unit still powers the rears? Has anyone got any thoughts? |
09-19-2015, 07:10 AM | #1050 |
506
Rep 985
I've just finished installing the Alpine upgrade to my 2008 E92. Took me 2.5 hours thanks to the guides on here and I've had the door panels off before.
Well worth upgrading if anyone is considering it and doesn't want to spend too much. Total cost was £280 for the kit from germany and £28 for the grills off eBay. Sound quality and bass is so much better over stock I don't understand why this kit isn't fitted as standard. |
12-01-2015, 12:09 PM | #1051 |
Photographer
413
Rep 2,643
Okay I managed to find time to put the speakers in, already sounds a bit better.
I googled the numbers and I think the SA662 plug is only for the Business radio? I have Professional so put it in the plug with all the other numbers. Could find any clarification on that. Annoyingly my Alpine badges are slightly marked but not 100% sure I want to put them on anyway. |
12-22-2015, 05:48 PM | #1052 |
37
Rep 169
Drives: M140 LCI F21 and E92 M3 CS
Sorry if this has been covered a million times guys; but I'm just interested which subs people have used with the alpine upgrade? I've got the original 6.5" under-seat subs in place. Just ordered the Alpine retrofit kit and got my hands on a pair of HiFi subs.. Most people suggest the L7 subs but I wondered if anyone has first-hand experience of the 2 options?
Also, has anyone modified their own choice of subs into the OEM under-seat housing powered by the Alpine amp?
Daily: M140 LCI Stage 1 Track: E92 M3 Manual FOR SALE: 123D Track Car ready to go
12-23-2015, 03:14 PM | #1053 |
37
Rep 169
Sod it.... L7 subs ordered and retrofit kit. Door surrounds and that's the lot I think?
Anything else I need?
01-03-2016, 03:45 PM | #1054 |
61
Rep 207
right, so i installed the kit, got stuck a bit on the front passenger side with the wires.
thought I had them connected all properly, but there is no sound at all from the left side. I have not put in the Alpine tweeters or mids yet on either side as I wanted to make sure that the wiring was correct, but for sure there is no sound from the left. Strangely, when I tried moving between the radio and woofer wires on the passenger side, I managed to cut off the amp. Any ideas here ?? Thanks... |
01-03-2016, 05:36 PM | #1055 | |
37
Rep 169
01-04-2016, 12:20 AM | #1056 | |
61
Rep 207
So why would one side work with stock speakers with Alpine harness and not the other? Is it due to the fact that the speakers are wired in series? |
Tags |
alpine |
