10-15-2014, 04:21 AM | #948 | |
52
Rep 388
I went to BMS stage 2 right away, you can really feel the power difference and the great thing is that you can Turn it off using the steering wheel and then turn it on again as you see fit. My only issue is that I only use it on petrol RON 95 and when the temp is below 35 degrees so as not to take risks of any damage to the car. Now I am using RON 92 mostly I don't use it. Rustyminded Motaz uses it on RON92 with downpipe and FMIC cooler. So he could give more info there. Racechip I am not really aware of. Jb4 is for 320 ans 328 and 335 I think Racechip supports 316 Hope that helps a little
10-15-2014, 06:06 AM | #949 | ||
Rep 52
10-15-2014, 06:54 AM | #951 | |
248
Rep 1,436
I use it with RON92 but with Octance each fill up sometimes I use two cans. I take logs and see how the car responds if it's low octane I switch to map0 (stock) and No Ouzzo I don't have FMIC it will help in our situation, I have intake (no gain felt as more response), dp (huge gain) and exhaust (huge torque) so all work with each other to create a balance
F30 328i - 8 auto.. JB4-EWG harness, OCC, Injen Intake, AFE Scoop, AFE dp, AA axle-back - H&R springs, H&R Rear SB, Front Strut, F&R BMS spacers..
10-15-2014, 06:59 AM | #952 | ||
Rep 52
10-15-2014, 05:41 PM | #953 |
52
Rep 388
10-15-2014, 05:46 PM | #954 | |
Rep 52
I dont need to get that 30$ cable right ? So stage 2 is like and addon to stage one ? I cant just buy stage 2 alone disregarding stage one !! |
10-16-2014, 01:35 AM | #955 |
248
Rep 1,436
defiantly get the usb you'll need to put firmware out change maps or sometimes restore settings !
10-16-2014, 04:49 AM | #956 | |
52
Rep 388
The USB cable will enable you to update the firmware of the jb4 and get some logs from your car if you need to check a problem with the jb4 experts I would get it You can buy stage 2 directly without getting stage 1. That is what I did. They will send a stage 2 cable system if you choose stage two add on. It will cost 559 usd Before ordering chat with Mike from n54tuning at this thread http://f30.bimmerpost.com/forums/sho...d.php?t=903024 Make sure to tell him it's a 320i as it needs some extra cables I think and ask he for the best price as you are a forum member.
10-29-2014, 12:20 PM | #958 |
52
Rep 388
Ya reet it's been a long time
I am busy next week with Cairo ICT but can do after that in shaa Allah
11-04-2014, 01:49 PM | #961 |
52
Rep 388
Looking at the car from the front with the boot open the wires are on the right, they are next to the bataha for the mosa3ed. If you have the PDF from burger tuning it should point clearly which wires you should tap.
11-04-2014, 02:52 PM | #963 | |
Rep 52
11-12-2014, 01:57 PM | #964 |
Rep 3
Hello everybody iam Ahmed ,I'm new here. I own '13 320 exclusive .. Decided to start tunning with the exterior first ' I've to change my rims to 18s , some xenon lights ,carbon fiber spoiler and kidney grills. ... Any ideas of 18 rims ? (My car is Havana metallic)
11-16-2014, 03:08 AM | #965 | |
52
Rep 388
How about some pics of your baby I have a friend who speaks wonders of rims in arabcom Nasr city
11-16-2014, 03:10 AM | #966 |
52
Rep 388
Hi Yehia for some reason I did not get alert to your message.
Will PM you my number
11-18-2014, 02:31 AM | #967 |
15
Rep 152
11-18-2014, 02:32 AM | #968 |
52
Rep 388
Thanks ya pasha will try it
