| 05-05-2021, 02:12 PM | #881 |
![]() 1344
Rep 2,363
An obvious cross-shop and potential for confusion
SCOTT26 "So as an admirer of the M5 and a potential customer of an M5 Touring. I would run naked around the streets of Garching if they were to offer one."
| 05-08-2021, 05:26 AM | #883 |
194
Rep 126
| 05-08-2021, 06:43 AM | #884 | |
Rep 6
Maybe eDrive40 also has a "boost" mode. Last edited by brainDotExe; 05-08-2021 at 10:22 AM.. |
| 05-09-2021, 07:42 PM | #885 |
Moderator
41807
Rep 14,314
As start of production of the G80 M3 LCI (facelift) and the G82 M4 CSL is scheduled for July 2022 (coinciding with the BMW M '50 Jahre' events), I guess that we may reasonably assume that SOP of the G80 M3 CS will not precede SOP of those two cars.
///M is art ↔ Artemis
| 05-11-2021, 09:47 AM | #886 | |
967
Rep 726
Depending on how drastically the LCI changes G80, the current version might end up becoming a real rarity down the line.
///Meant-to-be-sent
| 05-11-2021, 09:50 AM | #887 | ||
![]() ![]() 6805
Rep 5,728
2025 718 CGTS 4.0 6MT, 2025 G42 230i, 2024 Cayenne
M2C PCD M2C Mountain West Roadie M4 Cross Country Roadie 2017 230i ED 2023 G87 Nurburgring Trip |
| 05-11-2021, 11:25 AM | #888 | |
Moderator
7516
Rep 19,366
https://g80.bimmerpost.com/forums/sh....php?t=1781529 https://g80.bimmerpost.com/forums/sh....php?t=1808330 |
BMthusiast966.50 |
| 05-11-2021, 11:45 AM | #890 |
Moderator
7516
Rep 19,366
So, for those keeping score:
iX xDrive40 320hp iX xDrive50 515hp iX M60 560hp i4 eDrive35 300hp i4 eDrive40 335hp i4 M50 470hp I suspect we'll soon learn that the numeric value in the name is a reflection of battery capacity only. In other words, I don't think there is any attempt here to correlate the badge to power output like there is with the gasoline and diesel lineups. For example, a future i4 xDrive40 will not make 320hp like the iX xDrive40 does. I say this not least because that would nonsensically put its output below the RWD eDrive40 model's output. Furthermore, an iX M50 (which probably won't exist, but theoretically could) would obviously not have only 470hp like the i4 M50 model does. This is because, again, that would nonsensically place it below the non-M xDrive50 model in the lineup. TL;DR: when it comes to BMW EVs, don't try to guess motor output based on the badge. I was wondering that as well. As you suggest, that may be another model coming later. However, a mere 12% bump in power for the flagship M model over its lesser sibling would be a bit of an uncharacteristic move. Perhaps they intend to deliver even more power for said flagship? They could use the 560hp setup from the iX M60, for example. Though, it's not clear if the i4 will support the "60" battery which is probably paired with the higher output motors in order to yield a more reasonable EPA range. |
| 05-11-2021, 12:59 PM | #892 | |
![]() 1180
Rep 2,184
| 05-11-2021, 01:04 PM | #893 | |
Moderator
7516
Rep 19,366
Sure. By 2035-ish I would expect some sort of electric two door BMW. And I would not be surprised if it were the only coupe in the lineup by that time. I say that because I expect the 8er Coupe and Z4 to disappear after the current generation, while I could see the 2er and 4er coupes merge into a single model going by some new name.
Frosty966.50 |
| 05-11-2021, 08:26 PM | #894 |
711
Rep 1,523
Does anyone know if in fact the 2022 F90's which are supposedly starting to be built next month have any significant update from the 21's like Laser lights or anything to speak of? (Specifically for the US market). I know they've been available on Canadian cars as well as in the EU
2026 Individual M5
Frozen Pure Grey Metallic 2024 i4 M50 IG @FrozenG90M5 |
| 05-12-2021, 01:25 AM | #895 |
252
Rep 692
G30/31 Alpinas are already on the used-market in Europe.
I am not young enough to know everything - Oscar Wilde
| 05-12-2021, 05:30 AM | #896 | |
Rep 27
| 05-13-2021, 04:55 AM | #898 |
29
Rep 400
Drives: F30 LCI 330e M Sport
Any news / rumours on an electric 3 series for the UK?
Current- F30 330e M Sport
2016 - 2019 F30 LCI 330 M Sport 2012 - 2016 F30 320d ED 2008 - 2012 E90 320d SE |
xlover2343.50 |
| 05-13-2021, 08:52 AM | #900 |
![]() ![]() 6805
Rep 5,728
Mexico is the only plant scheduled to produce the G42. So, unless BMW plans to build an entirely separate factory elsewhere or adapt another factory to produce a very limited run variant of a volume car they are already producing in a factory built to produce said volume car, Mexico. Not thrilled about that, but it is what it is. S58 is all but certain. After the N55 in the OG M2, I doubt they'll deny the G87 the S58. Probably detuned in some way.
| 05-15-2021, 05:56 AM | #902 |
Rep 14
Drives: BMW x550e, i4M50, M2C, M235ix
The BMW Group Investor Presentation from May 2021 says again „UP TO 390 KW / 530 HP".
https://www.bmwgroup.com/content/dam...ation_2021.pdf I want these 530HP so bad ![]() |
| Bookmarks |
| Tags |
| future bmw, release date, upcoming bmw |
