03-03-2024, 05:05 AM | #859 |
45
Rep 587
I thought it would be helpful to outline my experience with software updates since I got the car, as I think I've experienced every single issue people complain about.
I got the car a year or so ago and it was still on 2021 software and claimed there was no newer software update available. In June I had the dealer update the software to the latest version which they did under warranty for me. This time around I did get the notification that the software update was available and the car downloaded it. Initially, it sat for a few days saying it was waiting for the right conditions. After a 100 mile round trip, the update installed fine.
Current: 2021 M340i xDrive, 2001 530i Sport
Previous: 2015 530d M Sport, 2010 530d SE, 2008 335i M Sport |
Bianchi Dave343.00 |
03-06-2024, 04:30 AM | #860 |
Rep 7
Hi all.
Recently bought a 200 330e (last month). Have tried to update the software, but it appears nothing is happening? The App states “New Remote Software Upgrade”, and doesn’t seem to go away. When I follow the notification, it states “Follow instructions in your BMW”, but no “instructions” appear? Anyone seen this before / no what to do? Software version to update to is 03/2023.50 |
03-06-2024, 06:53 AM | #861 |
63
Rep 179
03-06-2024, 02:30 PM | #864 | |
Rep 7
Actually have a question on that - would it degrade the battery if I have it charged to 100% most the time, or should I only charge it to, say, 80%? |
03-06-2024, 03:46 PM | #865 |
586
Rep 1,235
It’s the 12V battery that needs to be well charged, not the hybrid one.
On the latter there’s a good warranty, so I don’t worry about charging to 100%. |
03-06-2024, 04:39 PM | #866 | |
124
Rep 497
I obvioulsy don't have a 330e, but I take it (perhaps very) a long run is required to get the 12v battery up to the required SoC on the 330e? I'm glad a bought that CTek 25A charger for my 340i MHT, I do have other uses for it, thankfully, as a PSU, but it was not a cheap investment at Ł290 if I was only using it to carry out ID7 updates, but it has proved usefull so far. There is no way I'd be willing to part with Ł250 or there abouts to have a main dealer carry out an update by simply plugging the car into ISTA and forcing the update. that's daylight robbery IMHO. |
03-06-2024, 04:50 PM | #867 | |
Rep 7
Crazy long check list for a simple update, if you ask me Ya, the warranty is nice to have.. until it runs out |
03-07-2024, 01:17 AM | #869 |
586
Rep 1,235
I find my 330e is usually good at keeping the 12V battery topped up so the updates install pretty much instantly. But others have reported different - I wonder whether they don’t plug in? I know some PHEV owners don’t, and just treat the car as a self charging hybrid.
03-08-2024, 10:06 AM | #870 |
Rep 7
I'm another that has had problems with car not being ready to install the update even though it transfers fine from phone to car.
I also have tried used battery tenders to no luck as car isn't used that frequently. I thought it could have been the battery needing replacement, since car doesn't get driven much, and the battery was a few years old, so swapped out for a new battery. Registered it using OBDeleven app+dongle, but still no luck - even after using a battery tender to ensure it was fully charged. Then tried reading codes using ISTA and discovered the 038400 code that blocks the software upgrade. Even clearing with ISTA, this code keeps coming back. Then I checked the battery registration, and it hadn't noted the km when battery was changed so thought perhaps battery registration using OBDeleven wasn't done properly. I registered battery replacement with ISTA, shutdown the car, and next time I got in the car, update was ready to install! Therefore, seems like doing a battery replacement resets the IBS which may have been providing wrong values to the DME ultimately stopping the car from installing?? I've now been stuck for almost a month again with the 11/2023 update not ready to install even after using a battery tender just in case. I wonder if I should try a battery replacement in ISTA again to see if this allows the car to install? The only downside I can see is that it gets registered to the car like the battery has been changed again. |
buzzwauld0.00 |
03-08-2024, 12:51 PM | #871 |
Rep 3
I've had the same problems as a lot of other folk with the latest update being stuck and not installing. So yesterday I hooked the battery up to my ctek stop/start and let it do it's thing. Once the ctek went into care mode (green light) I attempted to start the install but it wouldn't. This happened around 3 times as I'd unhooked the ctek. Eventually after around 7hrs from first connecting the ctek the software was ready for install. So the battery needed 'more' than the minimum level that ctek says is care mode. I don't know how many volts this equates too but from what I can work out it needs to be more than 12.6v. I also left the ctek connected during the install.
03-08-2024, 02:31 PM | #872 |
Rep 19
Earlier in this thread I posted how I picked up a second hand 3 series which was still showing as having 2019 software on Idrive.
I ended up going to my local BMW service centre today to talk about servicing but also to ask about the option of manually upgrading my software, the service rep guy asked what was the reason I was wanting an update and I said mainly for Android Auto but also for any improvements that I am not aware of, he then went on to ask if my car was specced for Android Auto, I actually thought no older G20 was but as long as your car had apple carplay then it would appear in a future update, he went away to talk to somebody and came back saying the car can't get Android Auto. After this he then went on to say that they only normally offer updates if there is an issue with the current software and if manual updates are carried out it sometimes causes other issues...I get that might happen but are you honestly telling me that my 2020 G20 with 2019 software has had no other updates in the past 4 years, he's either talking utter bollocks or I'm totally wrong in my thinking. Last edited by Brisy; 03-08-2024 at 03:25 PM.. |
03-08-2024, 02:59 PM | #873 | |
124
Rep 497
I must note though that it was rather cold up here in Scotland at the time (still is), and so my batteries were getting a bit of a beating i.e. lights, AC, heated drivers seat, heated steering wheel were all on regularly for a little while anyway, and my commute to work is only around 15 mins, sometimes less depending on the traffic. |
03-08-2024, 03:03 PM | #874 | |
124
Rep 497
03-08-2024, 04:32 PM | #875 | |
197
Rep 481
Not sure if an earlier version added it but I remember it appearing when I downloaded this version. There are loads of improvements to the driver assistance as well so I’d be pushing them to force the latest update through ISTA in the workshop. |
03-08-2024, 04:41 PM | #876 | |
Rep 19
Out of curiosity what were the driving assistance improvements for you? |
03-09-2024, 03:15 AM | #877 |
13
Rep 50
Drives: BMW G20 330e M Sport
In case it helps anyone
I had the same issue with my 330e from 2019, here is what I did Called to BMW to check in their system, person from BMW told me that it appears in their system that the car has the updates blocked, he told me that this can be because at some point the update did not installed right and this might happen, he suggested to go to a BMW service and check it Went to BMW (in Netherlands) and they updated manually (unfortunately I had to pay for this around 250€) Since then I alteady received 2 updates and installed without any problem |
03-09-2024, 05:39 AM | #878 | |
714
Rep 1,244
Brisy The early G20s shipped without Android Auto. You definitely need the 07/2020 software update or later to get Android Auto - this is confirmed here https://www.bmwblog.com/2021/02/01/b...compatibility/
Current: Portimao Blue G21 330i
Previous: EB F30 340i Shadow Edition Previous: EB F30 330d xdrive Last edited by Rhino at Work; 03-09-2024 at 05:48 AM.. |
03-09-2024, 08:11 AM | #879 | |
Rep 19
I have another BMW dealership a few miles away from me that I can try, that or I hold off in the hope that an update comes through on the car or on the app, not holding my breath for that though. |
03-09-2024, 03:04 PM | #880 | |
Rep 7
https://static.nhtsa.gov/odi/tsbs/2022/MC-10214254-9999.pdf |
