M3 Steering Rack Swap
02-07-2015, 07:26 AM | #68 |
56
Rep 1,465
Drives: 2009 BMW 335xi
Not possible on an xi.
02-07-2015, 08:45 AM | #69 |
56
Rep 1,465
02-07-2015, 03:22 PM | #70 |
Freight Dawg
104
Rep 2,103
To the people who have done this mod: what effect has this had on your stability control? I recently quickened this steering ratio on another car I have and the stability control no longer works. The system compares speed, steering angle, and yaw rate. If you quicken the steering the steering angle sensor values will no longer match the programmed values in the stability control. The yaw rate will be faster for a given speed and steering angle making the car react as if it's oversteering. You would need to reprogram the DSC unit or somehow modify the signal from the steering angle sensor.
--Marcelo
'06 Arctic Metallic 325i | Sport Package | 6MT | Dinan Stage III suspension | Dinan exhaust | 330i manifold swap! Click here! | Active Autowerke tune | 135i Brake Calipers | Deiselboost caliper brackets | E46 M3 front rotors |
02-07-2015, 06:54 PM | #71 |
Mad Linux Guru On The Loose
1131
Rep 5,404
Drives: 2008 335i Sedan, 2023 M3
The only reason why anyone would want faster steering is so that they can drive the car more effectively on track and autox events. In both situations the traction control should be completely disabled any way. I fail to see the problem here...
02-07-2015, 06:59 PM | #72 |
DIYER
614
Rep 5,521
Didn't mess with my car, one of my favorite mods. Traction control is always off lol!
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
02-07-2015, 08:28 PM | #73 |
Freight Dawg
104
Rep 2,103
What about on the street? I'm just wondering if anyone got it to work again or at least found a way to have it disabled by default when the car starts.
--Marcelo
02-07-2015, 08:32 PM | #74 |
DIYER
614
Rep 5,521
Nothing plugs in, you leave servo unplugged. I didn't even have steering angle sensor recalibrated.
02-07-2015, 08:38 PM | #75 |
Freight Dawg
104
Rep 2,103
Interesting. I'm gonna try that with my other car so I don't have to keep pressing the button every time I start. With the BMW though you'll have to manually cancel the turn signals because BMW.
--Marcelo
02-08-2015, 09:58 AM | #76 | |
30
Rep 399
You will have these codes: Last edited by vwetish; 02-08-2015 at 10:23 AM.. |
02-08-2015, 10:02 AM | #77 |
30
Rep 399
plugged or not servo has nothing to do with the steering position sensor as that is mounted on the steering column slip ring
02-08-2015, 01:25 PM | #78 | |
Freight Dawg
104
Rep 2,103
--Marcelo
02-24-2015, 12:20 PM | #80 |
DIYER
614
Rep 5,521
awesome! How do you like it? I love mine!
03-11-2015, 11:03 AM | #81 |
94
Rep 1,184
I love it too !!!!!
on heavy track use (lot of turns) the oil can spill out of the reservoir. this is a common known M3 problem. we should upgrade to the bigger reservoir of the E92 with active steering. Any hope that BMS will include the control of the stiffness in a new release of the JB4? I actually control the stiffness by sending a PWM signal to the valve. but it is or too stiff for low speed or too light for high speed.... a variable PWM is needed |
04-27-2015, 10:16 PM | #82 |
59
Rep 235
Hope this helps guys....
I found that on a 1m the JBE controls the servotronic (pretty sure the dme does on a m3) Hopefully that means that we can make servotronic work on our cars by possibly programming/coding the jbe and wiring it up So the wires from servotronic go to the large connector on the back of the JBE/JB connector (X14270) Pin 5 (black wire with brown stripe) pin 6 (black wire with white stripe) These are not listed in ANY wiring diagram, with factory diagnostic software it says those pins are not used. I verified by checking continuity between the servotronic connector and the pins at the jbe. Its 100% accurate. The ZB number of the jbe that has working servotronic is 9264577 Remember this is on a 1M, im 80% sure this will work on a e90. It should work for sure on a 135i. GOOD LUCK! |
04-27-2015, 11:03 PM | #83 | |
DIYER
614
Rep 5,521
