BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
      06-11-2014, 12:48 PM   #67
leo95se
Drives: '09 e92 M3, '15 F15 X5d
I used the home made kit and it leaked. It also seemed to build up additional pressure since there wasn't anywhere for the fluid to go. Back to a rag. Works like a charm.
      06-12-2014, 04:48 AM   #68
r1762
r1762's Avatar
40
Drives: 2010 E90 M3
Originally Posted by kaiv View Post
Well here's what I did.
Parts:
* Rear brake fluid reservoir from the BMW F650GS PN# 34 21 7 706 055
* 2 feet of vaccum line (Napa)
* 90° fitting is a 5/32" elbow connector PN#9873 (Napa)
* 1 M6 bolt (+ M6 washer)
Total cost: less than $40.
Notice the logo on the cap? Yup, Brembo!
Also notice the nipple on the cap is angled so it fits perfectly bolted to the ground bolt thingy on the side of the engine bay without bending the line.
I used a little under 2 feet of line just so I can unscrew/screw the cap without disconnecting anything.
I'll find out next weekend if this setup works as expected.
Thank you for the part numbers and sharing. I needed this after coming from the track and saw all the fluid splashed for the first time.
      06-15-2014, 08:34 PM   #69
jolette
Hammer_Down!!
jolette's Avatar
Drives: e92 M3 6MT
This is my setup.
      06-17-2014, 01:43 PM   #70
stubble88
9
Drives: 2013 e92 ZCP blue
i read through this, maybe I missed it
but
Do the 2013 M3's have this issue?
thanks
      06-17-2014, 02:06 PM   #71
d0o0fy
d0o0fy's Avatar
Drives: 2013 E92 M3 ZCP
2013 BMW M3  [0.00]
but
thanks
Yes it does. The reservoir and cap are still the same design and allow for the power steering fluid to spill. I'm having the issue on my 2013 and will go with kaiv's solution as soon as I receive all the parts.
      06-27-2014, 10:27 AM   #72
Longbow64
_______
Longbow64's Avatar
171
Drives: 15 M3, 13 X3 35i MSport
Originally Posted by tom @ eas View Post
#1 is what's needed. M3 still uses old style, all other current production models use the revised reservoir.
There is an adapter that is needed for the bottom nozzle since it is slightly larger (about 1 size) than the M3 hose. This can be purchased at any auto parts store.
Tom,
Just want to make sure I get the right adapter so I don't get stuck at the house with a car that can't go anywhere. Can you list the specific adapter or sizes. Thanks.
      06-27-2014, 12:18 PM   #73
Crimson92
Smiling Politely
Crimson92's Avatar
Drives: Like a boss
Originally Posted by jolette View Post
This is my setup.
I did this as well.
My last run at Fontana I found PS fluid in the little reservoir....it worked!
Some people are like slinkies...not really good for much but you can't help but smile when you see one tumble down the stairs"
      08-06-2014, 10:29 AM   #74
jvitas
10
Drives: 2009 M3 Coupe
I tried the PS reservoir from the 1M in my E92 M3 track car and it doesn't work much better than the M3 reservoir. Still looking for a better solution.
      08-06-2014, 12:41 PM   #75
E90M3velocity
Philippines
339
Drives: Manual-Slicktop E90 M3
If your willing to spend some money for an easy fix-
http://ind-distribution.com/ind/bran...ring-reservoir
      08-06-2014, 04:30 PM   #76
bkrM3
bkrM3's Avatar
Drives: E90 M3
2009 BMW M3  [9.50]
SIX HUNDRED and SIXTY-FIVE DOLLARS!??
Are they got damn joking?
E90 M3 Space/Fox/6MT
E92 335i BSM/Saddle/6MT - Sold
      08-06-2014, 06:57 PM   #77
OC3
Havin' a blast!
OC3's Avatar
Drives: 2013 M3 E92 Jerez Blk DCT ZCP
I have the following on my car and it works great. Cost me only a few Hamilton's.
Parts:
BRP 1:56 | CVR 2:01 | ACS 1:53 | WSIR 1:34
      08-07-2014, 08:43 AM   #78
bkrM3
bkrM3's Avatar
Drives: E90 M3
2009 BMW M3  [9.50]
Yeah, I've considered doing that but one of our local dealers does our tech forms for free. Every few events I have them check & top off the reservoir. Given those circumstances, the black sweatband ziptie approach has been adequate.
I'd love that reservoir extension piece - but jesus tapdancing christ, six hundred sixty freaking dollars? Like.....WHY?
      08-07-2014, 12:48 PM   #79
OC3
Havin' a blast!
OC3's Avatar
Ya, used sweatband/rag with zip ties for a couple years and those r fine too.
As for 660, cuz 660 is like 6.60 for ballers? Similar to spending over a grand for those thin side view GTS mirrors...
      08-11-2014, 09:32 AM   #80
bkrM3
bkrM3's Avatar
Drives: E90 M3
2009 BMW M3  [9.50]
One thing I never get used to is the M-tax, which takes the BMW tax and cranks it up to 11. It's the cross we must all bear.
      08-13-2014, 10:09 AM   #81
MasterP
722
Drives: All the M's
Black Wristbands 2 for $5.99 @ Academy. I go through one a season. Good enough for me.
      08-13-2014, 10:40 AM   #82
slicer
slicer's Avatar
2748
Drives: 'E46 M3 Race Car, '23 X7
I find that mine is saturated after one track event... I replace it each time. My thinking is that a fluid saturated sweat band is not the best thing to have hanging around my hot engine compartment.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc.
INSTAGRAM - @Slicer_M
      04-20-2015, 12:47 AM   #83
roastbeef
roastbeef's Avatar
Drives: E92 M3
Originally Posted by surlynkid View Post
Like I said earlier, the right way is the BMW Motorsports GT4 Power Steering Cooler. No leaks......
where could one of these be purchased? i'm not finding it online.
Instagram; @roastbeefmike
      04-20-2015, 07:04 AM   #84
surlynkid
surlynkid's Avatar
115
Drives: 2013 E92 M3
Atlanta BMW parts Dept.
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
      04-20-2015, 07:08 AM   #85
SYT_Shadow
///M Powered for Life
SYT_Shadow's Avatar
11517
Drives: E90M/E92M/M4GTS/M4GT4/X5M
I got the BW reservoir. Under 200.
      04-20-2015, 10:35 AM   #86
pstockley
Drives: N/A
Anyone tried this
http://store.bimmerworld.com/bimmerw...oir-p2245.aspx
      04-20-2015, 10:51 AM   #87
///S65
43
Drives: E92 M3 SSII DCT
was thinking about getting that but someone said it doesn't have a filter inside like the OEM one. Have you encountered any issue with this setup?
2010 E92 SSII DCT, Akra Evo, ESS Tune, Performance Spolier &Splitter, Edition Side Markers, AD08R
      04-23-2015, 08:23 PM   #88
surlynkid
surlynkid's Avatar
115
Drives: 2013 E92 M3
I had an M6 bolt laying around to do this but it was the wrong pitch. What is the correct thread pitch?
Got it. M6x1.0 which is what I had. I just had to chase the threads with a tap first to clean out funk.
m3post
