05-13-2009, 05:27 PM | #67 |
24
Rep 682
somone should make this a reasonably priced aftermarket kit... eg, I honestly dont care if its actual bmw, just something that hides away, and has audio integration into stereo etc...
05-28-2009, 05:56 PM | #68 |
Rep 30
1. The 2nd gen monitor and i-drive can be installed into 1er (at least instead of CCC)
2. To activate Navigation one's will need activation code linked to VIN... So until there is no official upgrade kit form BMW - it will work as a media-center but with no Navigation function.
Thank you for your answer.
09-12-2009, 09:49 AM | #69 |
Navy Chief
31
Rep 447
Drives: '14 CBM X6M
did anything ever happen with this?
09-26-2009, 09:32 AM | #71 |
2312
Rep 13,026
As stated above, a swap of components (HD screen and CIC computer) work 90% plug and play - the HD screen requires a completely different video cable and a power connector to be connected in the 1 Series, the CIC plugs right in the existing Quadralock- but requires a set of FSC codes from BMW to enable the Navigation and Voice Activation.
I will be doing an iDrive swap in my MY2008 E90 M3 once the MY2010 CIC is available to order from the dealer (the HD screen, the cables, connectors and controller are already acquired or found) and a DIY thread will be created then. It should be applicable to the 1-Series as the CIC P/N is the same as the 3-Series. |
09-26-2009, 04:56 PM | #72 | |
Super Couper
70
Rep 577
10-02-2009, 02:14 AM | #73 | |
30
Rep 86
also,I believe not only the FSC codes are needed,but you'll need to change the VO(vehicle order) of the vehicle for this to be recognized by the vehicle..for example ,opt code 609 needs added.. just like adding satellite radio (655) for example. Keep us posted ,I am planning myself to do this ..most likely will not be cheap , but it's a challenge Ray |
10-03-2009, 03:02 AM | #74 | |
2312
Rep 13,026
05-29-2010, 10:53 AM | #75 | |
129
Rep 1,347
please post in the 1 series forum too!!! I have been waiting for ages for someone to post something somewhat detailed so i can show it to a local shop. ROFL just realized i bumped an old thread....wow...
JRZ RS2 | Capristo | Eisenmann | Volk Racing TE37SL | Endless Brakes |
05-29-2010, 10:56 AM | #76 |
2312
Rep 13,026
08-11-2010, 10:46 AM | #77 | |
108
Rep 1,075
Controller 65-82-9-189-048 $246.12 Ventilation Tube 64-11-6-928-875 $14.50 Trip Panel 51-45-9-158-352 $587.81 Connecting Wiring 61-11-9-185-171 $42.88 Connecting Wiring 61-12-6-935-686 $35.02 HANDS FREE TELEPHONE MICROPHONE84-31-6-938-762 $30.85 LOUDSPEAKER 65-13-6-938-657 $18.95 CAR INFOTAINMENT COMPUTER 65-12-9-199-907 $1,161.95 Total: 2138.08 If you are going to do it now you will save about $600. However you still need to spend 2,000+ On any of the screens if you don't already have it. http://www.realoem.com/bmw/showparts...01&hg=65&fg=45 |
07-22-2014, 08:58 PM | #78 |
Rep 30
