08-19-2016, 11:22 AM | #67 |
<(O0=[][]=0O)>
764
Rep 1,199
And a lot more Toe - could be causing it?
2012 E88 M-Sport 135i DSB Metallic
COBB CP, ZHP Knob, E60 SSK Lever, E92 M3 FSB, RSFB inserts, Koni Sport, Eibach Pro, UCP, MPSS, AP axle-back, MHD Stage1+ 91 <(O0=[][]=0O)> |
08-19-2016, 05:53 PM | #68 |
19
Rep 91
Toe is almost the same on the "after" measurements. You might have been looking st the top. I ended up doing the front struts today and found a cracked passenger side mount and a pretty slow drivers side strut. It's back at the alignment shop now so hopefully this will be the end of it.
08-19-2016, 06:36 PM | #69 | |
1Addict
3246
Rep 7,913
12-23-2016, 08:46 AM | #71 |
<(O0=[][]=0O)>
764
Rep 1,199
I think I'd get camber plates and/or M3 control arms.
Wouldn't want to weaken the mounting area. Plus - that's a little much for the street. |
desertman1232215.50 dzid_6.00 |
12-23-2016, 07:13 PM | #72 |
1Addict
3246
Rep 7,913
1.5 - 2.5 is good for street. Not sure id want more than that.
05-13-2017, 06:21 PM | #73 |
245
Rep 616
Does anybody know if the bolts that are "fixed" on the Dinan plates are interchangeable with the ones that are on the stock shock mounts?
Reason I'm asking is I have gotten DInan plates as part of a deal from here in the forums, but they are "only" the plates, no bolts on them. I bought the other set of bolts and nuts that originally came with the Dinan plates but the plates, themselves, are bare. I hope that makes sense. Seems like the plates I have are useless then... |
09-03-2017, 05:02 PM | #74 |
Supreme Galactic Commander (one galaxy over...)
676
Rep 1,778
Just did it. Was as easy as advertised using the hammer and chisel on the top, then drilling out the remainder. Not sure how much more camber I got (amount moved at the top was small). I was -1.1 and -0.8 before I started. I got more movement out of the passenger side so I hope I am closer to -1.3 or so on each side. My rears are -1.5 and eyeballing it they look very close to them now. Car drives straight and still wants to stay centered so toe is still in. This will have to do until I budget for some Vorshlags!
Best,
Andy '12 E82-PS2,Stoptechs,Clubsports+M3 bits,Accusump,Wagner DP+EVO III FMIC,ERCP,BMS Intake,Mason Strut Bar,Wedge Tune |
02-04-2018, 12:28 PM | #76 |
24
Rep 115
Just checked and mine still seem to be in place. Should be removing them this week. Anyone have working pics for this procedure ?
02-15-2018, 08:21 PM | #77 |
Loves me some MHD!
1866
Rep 1,726
There are extensions for both firefox and chrome that will get the pics back. I've been using Photobucket Hotlink Fix since The Change, and it's been perfect.
https://addons.mozilla.org/en-US/fir...hotobucket-fix https://chrome.google.com/webstore/d...alioapbifiaedg
1and1
135i - E82.N54 2009 BSM - MHD / xHP / DCI, PR CP & 7.5" Race IC / N55 mid & Borla . . WL RSFI, Koni, Eibach & Dinan CP's, M3 CA's / EBC Red's & Firehawk 500's X1 - E84.N20 2013 MGM - JB4 - The Wife's, now with new turbo & ewg |
desertman1232215.50 Cpt.K24.00 |
02-28-2018, 08:27 PM | #78 | |
1545
Rep 3,071
Not sure what you are saying here. The bolts on the Dinan plates are specic too the their design.
2011 135i w/ DCT | ZSP Sport Pkg | PPK | Ohlins R
05-28-2018, 12:14 PM | #79 | |
104
Rep 486
I haven't gotten a definitive yes or no, and Dinan is reluctant to respond to any inquiry for replacement hardware. |
05-28-2018, 03:12 PM | #80 |
1545
Rep 3,071
Are you talking about the flat headed hex screws? Those come with the kit. Those screw it down. You can source some at Lowe's Depot or Fastenall most likely. . Let me know if you need to know the specs.
Have you tried just calling the customer service line? |
10-07-2018, 10:57 PM | #81 |
30
Rep 285
Hey guys, I just installed ST V1 coilovers.
Front left camber = -.9*. Front right camber = -1.2*.(homemade camber gauge with Craftsman digital level). Then I drilled out the alignment PIN and pushed it inward all the way. Buttoned up and lowered car. Drive it back and forth several times in the garage. My problem is camber didn't change after pin taken off. It remained the same. And now steering wheel is bit off to the right. I'd like to get the fronts to -1.5*. And ST suspension dropped to 1.5" in the front too. Anyone know why the pin delete didn't do squat? |
10-21-2018, 06:40 PM | #83 |
34
Rep 91
Removing the pin doesn't add much camber if any noticeable camber but it can throw your alignment off.
So I found some bootleg SPC camber kit that looks like it uses the same parts at the SPC kit for $150 I was going to try it but it's really overkill for me and I hear the legit Ground Control and SPC kits can be noisy. Someone with a better garage should test these out... [IMG]http://www.**********s.com/zoom_img/_1491914711.jpg[/IMG] |
04-06-2020, 07:22 PM | #84 |
154
Rep 2,757
Drives: 2017 Audi A4
Bumping an old thread is something I'm def enjoying lately!
So I just popped out to look at mine and it appears the passenger side has had the pin popped, drivers side is intact. I'm guessing a previous owner had an alignment and the shop did so to achieve the correct numbers? Though this would surprise me as I'd figure if the car is stock, the pins shouldn't need to be popped unless you're physically looking for more camber or adding for performance sake. Also, when you loosen the bolts and pop the pins with the wheels off the ground, do you move the strut by pushing on the three bolts or actually reach your hand thru and try and push the top of the mount?? I figure it's not done by pushing the wheels itself so.. I'm a suspension dumbass with this one so I'm learning |
05-16-2023, 07:16 PM | #86 | |
2547
Rep 3,651
