03-01-2024, 06:08 AM | #67 |
156
Rep 422
I ended up buying the final version of the LG 10.25" screen for the G30/F90, part no, 65509826394. According to realoem.com, this is the final revision of this part. https://www.realoem.com/bmw/enUS/partxref?q=65509826394 I will post pictures of the installation once I have it all done.
Thanks again, WhiteFox, for all of your informative and helpful posts about this upgrade!
2016 BMW F83 ///M4 Tanzanite Blue Metallic/Silverstone Full Merino // NBTevo ID 6 retrofit // G3x/F90 10.25" MGU display retrofit // GTS flash // SmartTOP // 437M + Pilot Alpin PA4 (winter) // 359M + ContiSportContact 5P (summer)
Retired: 2013 E93 M3 | 2015 F22 M235i xDrive | 2012 E70 X5 xDrive 35d | 2010 E90 328i xDrive |
03-02-2024, 10:39 PM | #68 |
595
Rep 1,117
03-02-2024, 10:41 PM | #69 |
595
Rep 1,117
03-02-2024, 11:28 PM | #70 |
595
Rep 1,117
Judging from the previous posts in this thread, the screen part numbers 65508715339 and 65509825936 do work with the F8x NBT EVO units.
However, the new part number 65509826394 shows it is non-exchangable with the above units which are known to be compatible in the F8x platforms. Has anyone dug into these to determine why some of the screens are non-exchangeable (something is different about them from the other making them not exchangable) or is tgb1974 about to have an unpleasant experience? Hope not, but this does give me pause as to what the difference is. |
03-02-2024, 11:30 PM | #71 | |
462
Rep 2,093
Drives: 2017 F80 M3 ZCP BSM 2012 E82 1
2017 F80 ZCP BSM - Klein Innovation. ActiveAutowerkes. AR Design. BootMod3 Paul Johnson. EvRw. Project Gamma. RW Carbon. UCP. UUC. Hawk. Dinan. NGK. Macht Schnell. TMS. VR. aFe.
RIP - E82 135i - 7/7/2021 |
03-03-2024, 02:09 AM | #72 |
133
Rep 264
This screen should work but would stick with the one prior as would have been some minor change to firmware would be my thoughts. The wiring is the same for all those screens but might cause an impedance error which would only show up in error scanning.
03-03-2024, 02:13 AM | #73 | |
133
Rep 264
You need this adaptor to fit this screen else you will need to buy the F15 square one and cut some holes in trim to fit that which is not as good of a screen as they made via LG for the G series. |
03-03-2024, 01:02 PM | #74 | |
267
Rep 650
This screen is available, can you confirm it’ll work? Cheers |
03-03-2024, 01:56 PM | #76 |
267
Rep 650
03-03-2024, 03:55 PM | #77 |
156
Rep 422
Does the G30/F90 display have better resolution than the F15 display? Or is this just your impression? Thanks.
03-03-2024, 04:00 PM | #78 | |
156
Rep 422
By contrast, there was a known issue with an early version of the 8.8" touchscreen used in the F3x/F8x that would cause it to act like it was being touched constantly, especially when the sun was to rear of the vehicle. Later versions of the display corrected this problem. So, when I upgraded my head unit to ID 6 and got a touchscreen, I made sure to get the final revision of the display.
03-03-2024, 11:36 PM | #80 | |
133
Rep 264
03-04-2024, 06:18 AM | #81 |
156
Rep 422
It must be a better quality panel then, as both the F15 display and the G30/F90 display have the same resolution (1440x540).
03-05-2024, 09:02 AM | #82 | |
156
Rep 422
03-05-2024, 11:31 AM | #83 |
156
Rep 422
Question -- There is a small plastic post basically above the purple APIX video port. Did you have to cut that off for the Bimmertech adapter to work? If you closely watch the Bimmertech video about the adapter, they appear to have cut it off. What did you do with it? Thanks!
03-05-2024, 02:29 PM | #84 | |
133
Rep 264
03-05-2024, 02:30 PM | #85 | |
133
Rep 264
tgb1974155.50 |
03-05-2024, 08:27 PM | #86 |
156
Rep 422
Thanks very much for this information. The BimmerTech support people had no idea what I was talking about lol.
03-06-2024, 12:22 AM | #87 |
133
Rep 264
03-07-2024, 10:38 PM | #88 | |
462
Rep 2,093
