01-25-2022, 06:44 PM | #67 | |
3383
Rep 1,833
Drives: 2022 X3 M40i
But the amp helped alot in sound quality to me, I wanted at first to do a full custom system but in the end deciding for something thats plug and play. |
01-25-2022, 07:10 PM | #68 |
673
Rep 492
Not that a recording on your phone is probably the most accurate sound, but those blinkers sound very loud to my ears. I don't think I could handle that.
Does this amp have a gain setting that can be turned down or something? I can't imagine why the gain would be so different on the blinkers versus stock.
2022 X3 M40i E46 330i ZHP, E90, E89 Z4, F30 320i "Jalopnik Edition", F80 Comp, F80 CS |
01-25-2022, 07:18 PM | #69 | |
506
Rep 358
01-25-2022, 07:32 PM | #70 | |
3383
Rep 1,833
But I think your asking if the amp can isolate that one sound ie turn signal, then turning the "gain" down will lower it will not work. The gain adjust is used to adjust the overall sound reproduction level of the output signal the amp produces. Not fine tuning a single sound note. The dsp or signal processor that comes with he amp will help fine tune certain frequencies. Unless there's a way to adjust the actual sound of the "turn signal " from the settings in idrive or code it like through bimmercode, any type of amplifier that you add to your system will always increase the sound of said turn signal. |
01-25-2022, 07:38 PM | #71 | |
3383
Rep 1,833
01-25-2022, 07:58 PM | #72 |
506
Rep 358
01-25-2022, 08:32 PM | #73 | |
800
Rep 1,961
Lossy, compressed satellite radio. Unknown quality mic. Probably recorded lossy. Uploaded to YouTube and goes through their compression. Played back on who knows what kind of speakers/video quality. |
01-25-2022, 08:45 PM | #75 |
3383
Rep 1,833
01-25-2022, 08:51 PM | #76 |
66
Rep 79
01-25-2022, 08:55 PM | #77 |
3383
Rep 1,833
The amp really took me 15 mins to install, its plug and play. and 2 10mm screws and a 10mm nut, to be honest I didnt unplug my ground or positive battery post either.
01-25-2022, 09:13 PM | #78 |
229
Rep 425
Thank you! It sounds like the blinker and parking sensors are pretty loud.i wonder if we could use a code reader to adjust the volume of the parking sensors and blinkers.
01-25-2022, 09:33 PM | #79 | |
3383
Rep 1,833
At the end of the day I don't think you will be driving with the blinkers on all day or taking 2 hrs to park. So the sound created won't drive you mad, unless your using a hearing aid. |
01-25-2022, 09:43 PM | #80 | |
673
Rep 492
A quality amp makes loud music better, it doesn't make loud music louder. At home, if I replace my $600 Denon receiver with a $20,000 McIntosh amp, music doesn't get any louder assuming the same gain on the amp (some of these amps have switchable gain). If I run at -20db I get the same SPL, but more accurate sound, clarity, dynamic headroom, etc. It's not louder - just better. I can also turn the music louder without the amp clipping and making square wave distortion. In this case, everything is louder, indicating that the the amp has a higher gain profile and/or you're just more inclined to crank the volume knob up with the new amp. Either this or the stock amp has some built in feature to normalize "system sounds" that this new amp is missing. Bimmer-Tech is also talking up their DSP, so perhaps they are processing audio in a way that makes these sounds louder. Our ears tend to interpret "louder" sounds as better because it gives us more dynamic frequencies - ie, there is more data between "dead silent" and "the loudest sound I can make". Either way, it seems like there is something going on here other than this just being a more capable amplifier.
2022 X3 M40i E46 330i ZHP, E90, E89 Z4, F30 320i "Jalopnik Edition", F80 Comp, F80 CS Last edited by jdhiro; 01-25-2022 at 09:52 PM.. |
01-25-2022, 09:58 PM | #81 | |
331
Rep 1,560
Drives: 2022 X4M40i, retired ‘11 X3
01-25-2022, 10:12 PM | #82 | |
673
Rep 492
I looked at the amp manual and there is an "input sensitivity" adjustment, which would be gain. It sounds like that needs to be turned down. I'll call Bimmertech to discuss this as soon as I have a VIN for my build. PS - Sorry, I'm not trying to challenge anyone on the amp. I'm interested in it very much, and trying to figure out how to make it a workable solution for me. Thank you for all the info!
01-25-2022, 10:21 PM | #83 | |
3383
Rep 1,833
"Not that a recording on your phone is probably the most accurate sound, but those blinkers sound very loud to my ears. I don't think I could handle that. Does this amp have a gain setting that can be turned down or something? I can't imagine why the gain would be so different on the blinkers versus stock." To clairfy i dont think you can lower the "gain" on just the "blinkers", you would be adjusting the entire amps output. Unless there was an adjustment like in the idrive ,the DSP or be able to code it solely to adjust the sound level of the "blinkers", then problem solved? |
01-25-2022, 10:27 PM | #84 |
673
Rep 492
That's not what I meant, but sorry that was my fail in the question. I just want to know if this amp is running a positive gain over the stock amp and if it can be turned down to the same level - and the evidence seems to indicate yes, if the manual is correct, you can turn-down the input sensitivity.
01-25-2022, 10:32 PM | #85 | |
3383
Rep 1,833
Ill also contact Bimmertech when i have a chance tommorow to see if there is an adjustment within the factory radio or their amp to lower just factory "blinker" sounds. I dunno what would you say the input of the blinker or parking sound is called? Factory notifications signal? |
01-25-2022, 10:34 PM | #86 | |
3383
Rep 1,833
01-25-2022, 10:36 PM | #87 | |
331
Rep 1,560
tallslenderguy39.00 |
01-25-2022, 11:19 PM | #88 | |
673
Rep 492
The source, the head unit, would have both a "pot" that adjusts the voltage for volume, and an op-amp which is a low-voltage amplifier that outputs the line-level signal. The amplifier, in this case the Bimmer-Tech, has a gain structure that adds X decibels to the signal. If you turn down the gain on the amplifier, than you have to crank the volume up more on the stereo, but it might not mess up the blinker sound. It's possible, and seems likely, that Bimmer-Tech thought they got more "wow" results depending less on the op-amp and more on the amp. However, the sound quality should be improved either way, and I'd prefer to run more at the standard gain and not have unusually loud blinkers. However, the reality is also that these car stereos are super integrated and do weird things I might not know about. For example, the HK system doesn't have the op-amp in the head-unit, because it moves the DAC and DSP into the trunk, which is actually pretty cool because it lets them get rid of the analog volume pot and move the volume control into the digital domain in the DAC by selectively dropping bits.
