05-08-2019, 10:56 AM | #67 |
1093
Rep 950
CHE///MIST3372.00 |
05-13-2019, 10:47 PM | #68 |
BimmerPost Supporting Vendor
1446
Rep 1,614
Finally, I've got an update from Bert on his S65 Flat Plane Crank project.
Click on any of the photos to see full-sized images. The photo blog URL's contain dozens of extra pictures. Block Preparation and Main Bearing Clearance Before installing the crankshaft, the bedplate must be prepared. The main bearings are installed, and the clearances are calculated. Installing Main Bearings Photo Blog URL: http://www.rcollins-home.org/photobu....php?album=280 Main Bearing Clearance Photo Blog URL: http://www.rcollins-home.org/photobu....php?album=283 Installing Crankshaft, Seals, Measuring Endplay Installing Crankshaft Photo Blog URL: http://www.rcollins-home.org/photobu....php?album=282 Measuring Endplay Photo Blog URL: http://www.rcollins-home.org/photobu....php?album=284 Installing Crankshaft Seals Photo Blog URL: http://www.rcollins-home.org/photobu....php?album=281 Last edited by Green-Eggs; 05-14-2019 at 10:04 PM.. |
05-13-2019, 10:55 PM | #69 |
1446
Rep 1,614
Before I post the next update tonight or tomorrow, I have the following update on the viability of building an S65 Flat Plane project of your own.
As Bert thought, converting the valve train to mechanical lifters was easy, and relatively inexpensive. Bert put together a kit that will convert the hydraulic cam followers to mechanical. The mechanical cam follows are required to run the cams for this flat plane project. Two other builders are working with Bert to build a flat plane engine of their own. Schrick has agreed to make the cams for Bert. If more people are interested, then the cost of the cams will go down. Roughly speaking, building a flat plane S65 engine will cost about $5000 more than a normal stroker engine. That's a lot better than we thought. For each person who orders the cams, the cost comes down a few hundred dollars. Anybody considering building a stroker motor and wants to build a flat plane engine instead, contact me or Bert soon. Bert plans to order the cams around the beginning to mid of June. |
redpriest2147.00 deansbimmer3784.00 |
05-13-2019, 11:48 PM | #70 |
1430
Rep 3,008
The S65 looks so good... thanks for the updates, exciting!
INSTAGRAM: GORDON.M3
North American Mr12Volt Carplay/Android Auto Distributor DINAN | EVOSPORT | VAC | ARP | RD SPORT | NEEZ | EIBACH | CSF | IND | BILSTEIN | KLASSEN | BREMBO | ENDLESS | BBS | BPM SPORT | PROJECT MU | EVENTURI |
05-14-2019, 08:59 AM | #71 |
///M Powered for Life
11511
Rep 10,342
So much win in a single thread!
M3E90sedan108.50 |
05-14-2019, 09:09 PM | #73 |
1446
Rep 1,614
05-14-2019, 09:57 PM | #74 |
1446
Rep 1,614
Here's another update:
Click on any of the photos to see full-sized images. The photo blog URL's contain dozens of extra pictures. Installing the pistons. Piston Preparation Photo Blog URL: http://www.rcollins-home.org/photobu....php?album=287 Installing Pistons Photo Blog URL: http://www.rcollins-home.org/photobu....php?album=286 Torquing rod bolts using 'stretch' gauge Photo Blog URL: http://www.rcollins-home.org/photobu....php?album=288 Measuring rod side play Photo Blog URL: http://www.rcollins-home.org/photobu....php?album=289 Notes About Rod Bearings When Bert bought the flat plane crank and cams from Dinan, the crankshaft did not use the standard BMW S65 rod journal. Instead, it used a very well known racing sized journal. Bert's not disclosing which racing journal is used. This particular rod journal has many bearings available: STD, +/-0.001, +/-0.002, +/-0.010, etc. The bearings are available from Clevite with and without a TriArmor coating. These bearings are also available in different widths to suit different width rod journals. The availability of these bearings and sizes and widths make them ideal for a project like this. The different sizes allow the builder to dial in the clearance to any desired specification. The different widths allow them to fit into the width of an S65-sized connecting rod (albeit with a different diameter). Bert gave Van Dyne free reign over the project, including the new crankshaft Bert was going to order. Van Dyne Engineering could have decided to keep the BMW journal and bearings, or swap them to something else. Many years ago when the S65 rod bearing issue was discovered by Van Dyne, they were pushing Bert to adopt this same racing journal on the S65. But doing so would require a crank-out regrind and rebuild -- and that wasn't going to be feasible for 90% of the people. So it's no surprise that Van Dyne chose to adopt this same racing journal for the new crankshaft. Years later, Dinan would adopt the same approach and same journal diameter for all of their stroker engine builds. The whole idea worked like a charm. As has been the standard practice at Van Dyne for all of their S65 builds, the main journals were sized slightly undersized to give extra clearance. The rod journals used combinations of STD and +/-0.001 bearings shells to dial in the clearance exactly to 0.0021 inch, as was ideal for this size journal. The journal is smaller than standard S65, thus making the rotating assembly lighter. It's a win-win-win for the entire project. Last edited by Green-Eggs; 05-14-2019 at 10:07 PM.. |
05-15-2019, 10:35 AM | #76 |
1020
Rep 1,136
Drives: G30 M550i
05-15-2019, 03:45 PM | #79 |
1134
Rep 1,366
This has been incredible to follow, thank you for the updates!
#ladydriven Heavy-spec M3 // KW Clubsports // AA x-pipe // Gintani muffler // Macht-Schnell intake // Gintani tune // OMP Seats // Too Many Apex Wheels // Stoptech ST-60 // Cobalt Friction brake pads |
05-15-2019, 08:27 PM | #80 | |
1446
Rep 1,614
~ 3 pounds lighter. But that's just a guestimate. I talked to Bert...and he was so excited when they put the crank in...that he forgot to weigh it. Bert says he'll weigh the crank on one of the other flat plane projects in the works. |
gerikivan53.50 |
05-16-2019, 06:38 AM | #81 |
276
Rep 298
Gentlement, you had my curiosity, but now you have my attention.
M3E90sedan108.50 |
05-16-2019, 11:29 AM | #82 |
93
Rep 248
Subscribed! This is epic OP, just when I was planning on selling my car for something different your build has given me pause haha.
SYT_Shadow11511.00 |
05-16-2019, 07:05 PM | #83 |
1446
Rep 1,614
automotiveaperture92.50 |
06-14-2019, 10:41 PM | #84 |
Beach Bum
95
Rep 210
Wow!
Only wish BMW had done this from the start!
2018 340i - lease returned
2008 335i - sold 2006 SL55 - Sold 2004 SL600 - Sold 1999 540i - Sold |
06-18-2019, 02:38 PM | #85 |
372
Rep 615
Drives: E92 M3 6MT Space/Black
Love this thread !! Do you expect the engine to feel as "smooth" in this configuration as stock when at higher RPMs ?
GM |
06-19-2019, 10:07 PM | #87 |
1446
Rep 1,614
06-20-2019, 05:45 PM | #88 |
337
Rep 1,489
And that may add to its rawness, it already pretty smooth.
