The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > Tech Info: E90 330i N52 Three-Stage Intake Manifold
      02-19-2007, 06:19 PM   #67
esbezee92
esbezee92's Avatar
Drives: Montego 328i Coupe
are we taking bets on whether or not it will work right?
      02-19-2007, 08:26 PM   #68
FinnVette
FinnVette's Avatar
Finland
Drives: 325xit & Corvette C6
      02-19-2007, 08:47 PM   #69
Not Ur Avg 3
Not Ur Avg 3's Avatar
Drives: 06' 325i
2006 325i  [0.00]
omg thats such great news
if this works man
im gonna have a party lol
my friend with a 328i just whooped my ass, and he only has like 15 more hp than me.
if this works, and ill be getting like 50 more hp than before
ill race him again, and hell be like, hollly shitttt. lol
Perfection In The Making...
      02-19-2007, 08:51 PM   #70
ksfrogman
ksfrogman's Avatar
Drives: E90 330i 6MT
2006 330i  [0.00]
2006 330i  [0.00]
Originally Posted by FinnVette View Post
Folks, I have some good news for a change. James from Creative called me and said that I should have my programmed ECU back by Wednesday. Cross your fingers...!
This is terrific news. Are you planning on dyno testing your car if all goes well?
      02-19-2007, 09:08 PM   #71
esbezee92
esbezee92's Avatar
Great news indeed. A dyno would be great but with this large diff in hp i think a but dyno will sufice. If you dont mind my asking how much did Creative charge you and was it that much because your the first and its prototypeish, or is that just the going rate. Again good news and hope all goes well and you get it by Wed
      02-20-2007, 10:28 AM   #72
voltron1011
voltron1011's Avatar
119
Drives: 2011 135i, FJR-1300
Yes, we are all anxiously awaiting!!!!
      02-20-2007, 12:53 PM   #73
FinnVette
FinnVette's Avatar
Finland
They gave me the $595 "holiday special" that they where running earlier on.
Dyno would be nice, but lets see if that's going to happen. To do it right, you should do before & after in the same dyno. My car is also a 4wd and I don't know how many 4wd dyno's there are in Dallas.
Anyhow let's take one step at the time. First we need to get the ECU back and the car running. Then I can at least test with my but dyno...
      02-20-2007, 12:56 PM   #74
jonmacs22
Drives: 4-doors
Can you please provide a recap of exactly what they are doing, what parts have been swapped or replaced, and what the expectations are.
Many thanks.
      02-20-2007, 01:45 PM   #75
voltron1011
119
You should be able to pull the fuse on the X-drive and it will be only rear-wheel drive (for dynoing purposes)... Don't quote me on that, but that's how they used to dyno Skyline GTR's and they have the same type of AWD system. Since X-Drive uses computer controlled clutches, it defaults to RWD when there is no power to it.
      02-20-2007, 02:55 PM   #76
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Steptronics are the same in both cars. 325i also has a tad shorter gearing so you will accelerate faster than 330i with similar mods, at least in theory.
In the US, the A/T's in the 325 are built by GM France, the 330's are ZF.
      02-20-2007, 03:05 PM   #77
FinnVette
FinnVette's Avatar
Finland
Well, I'm not going to start argue about this. But what I have read, 325 and 330 share the same GM gearbox. 335 has ZF.
      02-20-2007, 03:08 PM   #78
FinnVette
FinnVette's Avatar
Finland
Many thanks.
Creative / Evotech is just programming the ECU. I have changed the intake manifold to 330i version my self.
      02-20-2007, 03:14 PM   #79
jonmacs22
Drives: 4-doors
intake manifold including the installation of DISA motors not previously installed on your car, correct?
      02-20-2007, 03:22 PM   #80
FinnVette
FinnVette's Avatar
Finland
Correct.
      02-20-2007, 03:32 PM   #81
voltron1011
119
Well, the DISA motors are already on the manifold in question.
      02-20-2007, 03:36 PM   #82
FinnVette
FinnVette's Avatar
Finland
Well, I don't know anything about Skyline's but I know some people have done that with Haldex based Audi Quattro's as well. However I'm not comfortable doing that with my own car, because the drive shaft from tranny to the "X-Drive clutch" would be spinning with very high speed where as front drive shafts are still...
      02-20-2007, 04:26 PM   #83
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
No arguement. I'm 100% correct. 325/328 use GM France Tranny's just like the E46 323/325. The 330/335 use a ZF built transmission (not same transmission, but same manufacturer). It's applicable to this discussion because people are ASSUMING the bump in power can be handled by the transmission of the 325 because it's the same transmission as the 330. That is an incorrect assumption.
      02-20-2007, 05:05 PM   #84
sevey
sevey's Avatar
Australia
Drives: E90 325i
oz is watching
Guys, there are a few of us in oz that are crossing our fingers on this one as well....good luck!
      02-20-2007, 05:38 PM   #85
FinnVette
FinnVette's Avatar
Finland
Hmmm...
I made a quick comparison in realOEM.com and it looks to me that 325i and 330i are sharing the same tranny. However the torque converter seems to be different, probably because 325i and 330i have different gear ratios in their differentials ?
Here's two links to realOEM.com
325i
http://************/27lutf
330i
http://************/yph8j2
Please see also JD's post #33 in this thread.
      02-20-2007, 07:08 PM   #86
FinnVette
FinnVette's Avatar
Finland
Thanks!
      02-20-2007, 09:20 PM   #87
Not Ur Avg 3
Drives: 06' 325i
2006 325i  [0.00]
isnt tomarrow the big day?
u gotta put that chip the second it arrives to ur house lol.
and have a labtop ready to post results
hell if it works man, im gonna go and find u tomarrow to see if its foreal lol
      02-20-2007, 09:38 PM   #88
evoi19
evoi19's Avatar
1559
Drives: 2022 G80C
We're all so anxious...just put a webcam on your computer and broadcast the whole thing. I'll be waiting with popcorn.
