View Poll Results: I own a... | |||
2008 model and the waterpump failed. | 176 | 14.05% | |
2008 model and the waterpump is ok. | 194 | 15.48% | |
2009 model and the waterpump failed. | 65 | 5.19% | |
2009 model and the waterpump is ok. | 195 | 15.56% | |
2010 model and the waterpump failed. | 18 | 1.44% | |
2010 model and the waterpump is ok. | 87 | 6.94% | |
2011 model and the waterpump failed. | 73 | 5.83% | |
2011 model and the waterpump is ok. | 172 | 13.73% | |
2012 model and the waterpump failed. | 52 | 4.15% | |
2012 model and the waterpump is ok. | 103 | 8.22% | |
2013 model and the waterpump failed. | 23 | 1.84% | |
2013 model and the waterpump is ok. | 95 | 7.58% | |
Voters: 1253. You may not vote on this poll |
02-26-2013, 10:56 AM | #67 | |
75
Rep 1,001
At my rate, 60k will be a LONG time... Hope they still make 'em by then!! |
02-27-2013, 04:28 AM | #68 | |
57
Rep 553
I haven't seen any DIY either... Not having any problems yet, but would like to know how it's done, and IF I can do it. |
02-27-2013, 06:07 AM | #69 | |
European Editor
10640
Rep 22,992
Here are two good DIY's... (on the e90post)... DIY – Water Pump & Thermostadt Replacement (2007, 335i w/Automatic Transmision) http://www.e90post.com/forums/showthread.php?t=784416 Pictures: Electric water pump + thermostat replace http://www.e90post.com/forums/showthread.php?t=347412
02-27-2013, 06:12 AM | #70 | |
European Editor
10640
Rep 22,992
And usually at around 90K the radiator and cooling hoses and coolant. Anti-Freeze (coolant) should be replaced every five years bc as it ages it gets more acidic. The PH level goes up(& up) and it eats the cooling system from the inside out as time goes by. Also one should use the proper BMW coolant as its different from say Prestone or what ever your local store sells.
02-27-2013, 10:18 AM | #71 |
Other car was a submarine
94
Rep 704
I'm officially freaked out and I'm going to be ordering both in the late Spring. I might as well give adjusting my front wastegate a shot while I'm in there. My mileage is at 113K.
Dack....if the PH is going up...wouldn't it be getting more basic not acidic |
02-27-2013, 10:27 AM | #72 | ||
European Editor
10640
Rep 22,992
Yea... your right. I did not mean that "up" figuratively. But the coolant does get more acidic was time goes on. Also the coolant loses its ability to stop corrosion.
02-27-2013, 08:57 PM | #73 | ||
57
Rep 553
03-11-2013, 11:29 PM | #74 | |
Feuertrunken
58
Rep 635
Crimson-Coral Red |Walnut | iDrive | Premium & M Sport | Heated seats | PDC |CA | Premium hi-fi | BMW SSK & PE | BSH OCC -
Deposit 7/15/2009 - Ordered 9/18 - Production 9/23-30 - Euro Delivery 10/17 - Shipped 11/13 - Oxnard 12/8, Oregon 12/24 & home on 12/30 |
03-13-2013, 12:35 PM | #75 |
TwinTurbo Top Hat
22
Rep 252
Water pump leaking, and oil filter housing leaking oil as well... Warranty just expired Jan :-/
46K Miles - 2008
AW 2008 135i - Auto, Prem, with Sat Radio
BMW CCA # 417107 |
03-14-2013, 08:21 PM | #77 |
119
Rep 1,668
I dont think this covers enough models that have the same engines / water pumps. I had an E85 Z4 that lost it mind when the water pump failed. I had to have it towed not doubt to the dealer to have it replaced. Same engine water pump.
Year 06 Model Z4 3.0i roadster N52 around 65K = fail
Enjoying an E89 Z4, F30 320i and Fiat Abarth //
E85 Z4 (sold), E82 128i (sold), Fiat Pop 500 (sold) |
03-28-2013, 04:42 PM | #79 |
Rep 26
I have an 09 135i that just hit 50k miles and I'm still on the original pump. But, about 1.5k miles ago the coolant light came on and that got me worried. I filled it back up that same day and the level is still good to date, but I'm wondering if that was a sign of issues to come, or if it was just low for some reason. I assume a dealership won't replace it just because it 'might' fail, before my warranty runs out, huh?
03-30-2013, 10:06 AM | #80 |
41
Rep 825
I wish I could change my vote. My water pump died a couple of weeks after I posted all was well!
Model Year/Production date__2008 / May 2008_____Miles__52K______Warranty/Good Will ? Extended warrranty______Engine Code__ N54
2019 X3 M40i - Black Sapphire Metallic - Mocha Lather - 21" 718M wheels - Every option except Sun Shade
04-03-2013, 05:06 PM | #81 |
Rep 12
MY 2008, built 03 2008 51700 Miles. N54, cost 1238 no warranty.
This turned out to be an interesting ordeal. 1. Water Pump Fails 2. Replaced by Wichita BMW 3. Driving home the Oil Temperature gage goes to 250 after 5 minuts of driving and the oil level indicator says inactive. The Oil Temperature gage dropped down to 200 in about 2 seconds as I was watching it, and then the Oil level gage showed the right amount of oil. No indication of anything wrong. 4. Got home parked the car came back out after an hour and had coolant all over the garage floor. 5. Tow truck came the next morning and the battery was dead. Had to push the car out of the garage. 6. BMW replaced the water pump the next day and said that apparently the first water pump replacement shorted internally as I was driving down the road causing the bizzare gauge malfunctions and drained the battery overnight. 7. Alls well that ends well, but just be aware that if the pump dies it can cause some strange things to happen. These cars will cause you to fret, and I was cursing it for a while but in the end they are too much fun to give up. |
04-05-2013, 04:23 PM | #82 |
European Editor
10640
Rep 22,992
26 waterpump failures out of 192. Not looking good. This just goes to show us that the waterpumps need to be replaced.
04-05-2013, 04:40 PM | #83 |
Spoolin' & droolin'
105
Rep 1,229
I'm almost at 40k....might just replace it soon before it happens
04-05-2013, 06:55 PM | #84 |
34
Rep 307
Also need to change my vote. The WP in my 2009 135i failed. Water Pump Kit replaced by dealer under warranty at 14K miles.
2009 N54 335i Sport
04-05-2013, 07:12 PM | #85 |
Unloved BMW Addict
86
Rep 1,185
Drives: Z3 Coupe, 3 318Ti
I wonder if there is a statistical difference between the 128 and the 135's
04-12-2013, 12:51 PM | #86 |
7
Rep 202
Spoke too soon . . .
No lie, I answered this poll two weeks ago and my water pump grenaded.
53,000 miles Covered under extended warranty. Since my warranty expired, I've had seat airbag issues $$$ and the water pump go out . . . Smart purchase decision! |
