Aquamist HFS-4 Install DIY (Lots of Pictures)
10-14-2013, 03:08 AM | #67 |
34
Rep 715
Checked my mail finally , here are some pictures that will help you guys out in regards to final install of the wiring.
Just connect the purple wire to pin 38 The effect of this connection enables the dim trimmer on the circuit board, when you switch on the low beam, the "dim" trimmer will work. If you don't switch in the low beam, the gauge will be in full brightness.
Vargas S2 turbos|VAC S3 Cylinder head|RR DPs|RR MPs|Supersprint X pipe|Remus Quad Sport mufflers|aFe Stage 2 Si with scoops|Forge DVs|ER CP|BMS meth elbow|Aquamist HFS-4|Walbro 450 E85 LPFP|AA FMIC|BMS OCC|MHD|P3 Boost Gauge|Ohlins Road & Track + camberplates|M3 sways F/R+ Ground control endlinks|Vorsteiner v303 19"|Michelin PS2 sport|Quaife LSD|Vorsteiner V35 CF hood|CF CLS trunk|Duke Dynamics quad diffusor
