09-15-2018, 04:52 AM | #67 |
Rep 3
Hi, I'm trying to retrofit used 6WB to my F30 316i. I've added 6WB in the VO, but I can only see BKOMBI, not DKOMBI.
Also my original cluster only have 1 connector, in 6WB it has 2. I'm missing the green/black connector. Will it work? What that connector for? I've been searching high and low, hopefully someone can point me to the right direction |
09-15-2018, 06:10 AM | #69 |
590
Rep 2,302
09-19-2018, 07:45 AM | #70 |
Rep 4
Hi, upgraded my 6WA to 6WB, all works fine a part of Navi on dasboard or any other options that used to be on 6WA also noticed that on my NBT settings i missing oprion - Instrumental cluster
09-19-2018, 09:46 AM | #71 |
Rep 4
09-19-2018, 10:02 AM | #72 |
10539
Rep 41,179
Drives: 2018 Alpina B6 650ix GC
Did you FDL Code KOMBI_CIC = kombi_high?
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
09-19-2018, 02:31 PM | #73 |
Rep 4
09-19-2018, 03:00 PM | #74 |
10539
Rep 41,179
Sorry, but I don't really understand exactly what it is your are missing. What is "Inst. Cluster in settings"?
09-19-2018, 04:52 PM | #75 | |
Rep 4
I worked out what was missed(not coded), now works all as it should. So what i mean by - Inst. Cluster(to choose what will show up on your KOMBI) - In setting on NBT where is options: Control display Time/Date Language/Units etc. And also should be Instr. Cluster Display - This was missing Now by Actived CAFD 3000 SETTINGS_INFO_DISPLAY - all works fine Wanted to share my learning :happyanim Would add some photos but not sure how to add lol |
09-19-2018, 05:05 PM | #76 |
10539
Rep 41,179
09-23-2018, 06:00 AM | #77 |
Rep 28
Hi friends. Please help me with 6wb on f34.
car manufacture year 2013.07 I successfully coded it but with one problem... I got error: Tow hitch !!! Please help me with this issue ) Regards |
09-23-2018, 06:05 AM | #78 |
590
Rep 2,302
09-23-2018, 06:18 AM | #80 |
Rep 28
Also tell me please about cars with bkombi and without most!! Dkombi cant be identified in esys, i read somewhere that to make it visible firs need to delete Bkombi from SVT and write to car again svt without bkombi and then dkombi will be visible for coding.. is it true ?
09-23-2018, 06:24 AM | #81 |
590
Rep 2,302
OK, then you should check if the "3AC" is still in the FA included.
If not, edit the FA and add the "3AC" and code again the Kombi. Or you can manually check whether these values are set correctly: KOMBI FPK_I12 > ERM_Konfiguration 3004 > DISP_CC_BYPA_02_ALIVE = aktiv KOMBI FPK_I12 > ERM_Konfiguration 3004 > DISP_CC_BYPA_02_CRC = aktiv KOMBI FPK_I12 > ERM_Konfiguration 3004 > DISP_CC_BYPA_02_TIMEOUT = aktiv KOMBI FPK_I12 > ERM_Konfiguration 3004 > STAT_ANHAENGER_TIMEOUT = aktiv |
dincic1.50 |
09-23-2018, 06:26 AM | #82 | |
590
Rep 2,302
Otherwise first code the HU_NBT and then the DKombi should be visible. After that code the DKombi. |
dincic1.50 |
