01-05-2023, 09:41 PM | #67 |
Rep 6
Battery Replacement
OK solved my problem, had to code from backup, where I put the value back to "Unassigned Value" which is the default, and the value is back at 69AH in BimmerLink.
01-27-2023, 01:24 PM | #69 | |
BimmerPost Supporting Vendor
8312
Rep 18,880
Drives: BMW
Any questions about the different batteries, let me know.
02-06-2023, 02:18 PM | #70 | |
Rep 20
02-06-2023, 02:19 PM | #71 |
8312
Rep 18,880
Drives: BMW
Should go with the 80Ah for freezing temps. Peace of mind is worth it.
03-25-2023, 12:34 PM | #72 |
Rep 5
Drives: F82 M4
This Battery is a lifesaver
03-27-2023, 12:50 PM | #73 |
8312
Rep 18,880
Drives: BMW
Agree 100%. The ReStart feature is a lifesaver if needed.
04-08-2023, 04:17 PM | #75 |
8312
Rep 18,880
Drives: BMW
We have a shipping calculator on our website which provide shipping rates once your info is entered.
05-31-2023, 11:12 PM | #76 |
541
Rep 717
On a strict diet plan for my fully prepared track car, what would be the best battery option? I am in CA, so no cold weather and car is gutted (no accessories, no AC, etc)
06-01-2023, 01:03 PM | #77 |
8312
Rep 18,880
Drives: BMW
The weight difference is only ~3lb from the H6 40A and H6 60A, I would still run the 60A minimum for peace of mind.
06-01-2023, 06:16 PM | #78 |
541
Rep 717
3lbs is a lot of weight
2015 M3 - GT4 replica Ongoing build thread https://f80.bimmerpost.com/forums/sh....php?t=1802471 For Pics / Video's visit Instagram https://www.instagram.com/ninekrpm1/ |
06-02-2023, 03:34 PM | #79 |
8312
Rep 18,880
Drives: BMW
Can always just skip breakfast that day!
06-02-2023, 04:12 PM | #80 |
541
Rep 717
I need to take out about 100#'s...everything will matter from here on. Its pretty much bunts/singles now... I ordered the 40a, lets see how it goes. FK
06-02-2023, 05:28 PM | #81 | |
327
Rep 508
Drives: M4 GTS
07-03-2023, 11:26 AM | #82 |
1844
Rep 6,993
Drives: 15 F80 M3, 22 G01 X3 30i
Quick question: I'm about to swap out my OEM battery for the recommended AntiGravity battery in my 2015 F80 M3. Is it necessary to provide power through a power plug/socket or OBDII to keep from losing any custom codings and other settings while the battery is disconnected?
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
07-03-2023, 12:00 PM | #83 | |
8312
Rep 18,880
Drives: BMW
RoundelM31844.00 |
07-04-2023, 11:31 AM | #85 |
1844
Rep 6,993
Just finished the installation and registration - a bit of a struggle with one step, though. The "cleat" would not go back on - I tried repositioning the battery and a host of other things, and finally gave up after 2 hours. Just not enough room for my big hands, and even my wife's smaller hands still couldn't get the cleat bolt to thread in. I ended up just installing the bolt, and then when I reinstalled the battery hold-down, I put the cleat between the hold-down and the top of the battery before tightening the bolts. Worked perfectly - no battery movement possible.
No issues changing battery type in FEM and registering it with bimmercode/bimmerlink. Now all I have to do is figure out what to do with the old battery! PS - took the old battery to O'Reilly's Auto Parts and got a $10 reward for recycling!
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey Last edited by RoundelM3; 09-24-2023 at 06:34 AM.. |
tom @ eas8311.50 |
09-23-2023, 01:59 PM | #86 |
Rep 2
I'm having an issue on my install. Everything went fine except mine needed a 13mm socket for the Ground and hold down plate.
The problem I'm having is the battery doesn't appear to be charging. I used BimmerCode/Link but made an initial mistake. I coded for 80AH not 80 AH AGM (I got the 80AH version) then I registered the battery. I noticed the problem and then changed to 80 AH AGM . Voltage on the IBS is steady at 14V and the battery is putting out ~13.75-14V but Bimmerlink shows the percentage decreasing...currently at 1% Car starts fine, everything seems ok, no errors, misfires, etc. The only thing I can think if is to go try registering it again after switching to 80AH AGM. Any ideas? And for those wondering why you have to get the cable with IBS....the IBS module is built into the old battery and can't be removed. The EAS one has it attached. |
09-25-2023, 01:12 PM | #87 | |
8312
Rep 18,880
Drives: BMW
Tags |
antigravity, battery, eas, lifepo4, lithium |
