Aussie E-Bay - Buy It Now - E9x Recomended
05-25-2016, 11:38 PM | #67 |
1496
Rep 3,148
This is what I use (EDIT: Kent beat me to it!):
http://www.ebay.com.au/itm/12V-240V-...gAAOSwFnFV~9UQ Any basic charger will shut off when the battery is charged. You charge from the terminals in the engine bay which goes through the car's charging system anyway. If you are doing MHD flashes, a 5A will be insufficient. This 20A charger is great, keeps the battery topped up with the fuel pump running and the headlights on. Just gotta make sure you have a good connection, don't clamp onto any of the dull galvanized bolts for a ground, that may give you a large voltage drop.
05-25-2016, 11:41 PM | #68 |
281
Rep 1,808
Although the eBay special probably can't revive a battery like the smart chargers like your Ctek one. I have owned Ctek products before and they're great. I currently have one of these Ctek bluetooth battery monitors thanks to EB89 recommended it after buying a cheaper product but had problems connecting to bluetooth all the time with the app. The Ctek one is faultless
05-26-2016, 01:54 AM | #69 | |
131
Rep 1,382
But may I ask if 5A really insufficient for MHD flash? Some say that it is sufficient? With the 20A charger, does it do the stage charging/maintenance of the battery like the ctek? I trust vtl since he is the expert in the electrical if you have read all the electrical mods that he has done. |
05-26-2016, 05:06 AM | #70 |
541
Rep 3,131
Drives: 2011 335i e92 DCT
Ill sell you my CTEK 5AMP if you want? I have two now
/ MHD Stage 2+ / AR CATLESS DP / PE MOD 4 INCH TIPS / BMR FMIC / K&N DROP IN / BMS CP / |
05-26-2016, 09:20 PM | #72 | ||
281
Rep 1,808
With the initial flash, it can take up to 38 mins. While the ignition is on, our cars electrics go like crazy especial the fuel pump. A common alternative is to unplug the fuse for the fuel pump, which is the biggest battery drainer. If your battery is healthy, it should be able to sustain enough voltage for a full write without being charged. Your battery will still start and run your car if the voltage is below 10A, but MHD stops working as it needs a minimum 10A reading from your OBD port to function. If you're in a flash cycle and it drops below 10A, you'll temporarily brick your DME. It's not a major problem as you just have to start the process all over again. But let's say you're flashing your only car. The voltage drops below 10A. You brick your DME. You can't go anywhere. I suppose you could still use the 5A charger and charge up the battery to full and try again |
05-26-2016, 10:05 PM | #73 | |
1496
Rep 3,148
Yeah the 5A isn't suitable, if you have a crap battery the flash can still drain it during a flash.
05-26-2016, 10:15 PM | #74 | |
131
Rep 1,382
Will get that $40 20A charger today. I am not too sure how good is the Ctek, it says that it can do something like recondition/maintain the health of the battery. What about the 20A charger? e.g. if I leave the car in my garage for an extended period (more than 2 weeks), can it be used to charge the battery without damaging it? It's ok if it doesn't, I will just use it solely for the MHD flash. |
05-26-2016, 11:02 PM | #75 | ||
281
Rep 1,808
05-26-2016, 11:07 PM | #76 |
281
Rep 1,808
My work electrician explained electricity to me really well last week. Compare it to plumbing. The voltage (volts) is like the water pressure, the resistance (ohms) is like the pipe size and the current (amps) is the flow rate
05-27-2016, 12:18 AM | #78 | |
1496
Rep 3,148
05-27-2016, 12:55 AM | #79 |
1496
Rep 3,148
Don't know who perpetuates these myths. Phones stop charging once they reach 100%. Anyway getting a bit off topic here...
05-27-2016, 01:54 AM | #80 |
4552
Rep 11,908
better change the name of this thread to "all you ever wanted to know about battery chargers and Aussie ebay buy-it-now"
05-27-2016, 02:45 AM | #81 |
97
Rep 577
SGM E92 335i FBO [COLOR="Indigo"]/ MHD Stage 2 Plus / CP-E FMIC / DCI / VRSF DP / VRSF CP / Turbosmart Raceport BOV / BMW PE / H
05-27-2016, 12:34 PM | #82 | |
281
Rep 1,808
05-27-2016, 12:35 PM | #83 | |
281
Rep 1,808
05-27-2016, 09:38 PM | #85 |
541
Rep 3,131
05-28-2016, 09:09 AM | #86 |
131
Rep 1,382
Just bought a set stock spark plug - Good for stock car or lightly tuned car?
$120 for 6 spark plug http://www.ebay.com.au/itm/BOSCH-SPA...gAAOSwZ8ZW5VFD Last edited by CYL; 05-28-2016 at 01:31 PM.. |
05-28-2016, 01:10 PM | #87 | |
281
Rep 1,808
05-28-2016, 06:56 PM | #88 | ||
97
Rep 577
That's what he was trying to post
