10-27-2015, 06:59 PM | #67 | |
1033
Rep 1,997
good tip guys!
Gone but not forgotten: '09 STi // '08 335i // '02 M3 // '11 335i // '15 M3 // '16 M3 // '16 Camaro SS // '16 Audi S3 // '18 Boxster 718S // '17 Camaro SS 1LE // '16 M6 GC CP
01-09-2016, 01:08 PM | #68 |
1400
Rep 761
Anti-squeal shims & paste?
I notice in this photo that the OEM pads have anti-squeal shims but the Pagids do not. When I did pad replacements as a kid back in the 80s, I'd normally transfer the shims to the new pads, and use some new paste.
Would you normally use shims/paste with a track pad? (I'm asking because I had some Endless MX72 pads fitted to my M4 and after multiple attempts to re-bed, they still squeal like a stuck pig when coming to a standstill with warm brakes - wondering whether it's worth taking them out and re-fitting with extra anti-squeal) |
01-09-2016, 02:11 PM | #69 | |
1033
Rep 1,997
01-10-2016, 04:56 AM | #70 | |
241
Rep 481
I use some anti-squeal paste on the pagids, just for the sake of it. When bedded in well they are hardly louder than stock on the street. |
01-10-2016, 08:16 AM | #71 |
1033
Rep 1,997
^ Lojs nailed it.
01-10-2016, 06:28 PM | #72 | |
533
Rep 1,415
Did have a minimal amount of anti squeal put on them. |
01-10-2016, 06:44 PM | #73 | |
203
Rep 468
01-10-2016, 06:54 PM | #74 |
533
Rep 1,415
Well first I'd like to state that this is the first car I've ever taken on track and the first time using the MX72. I have not used any other car/brakes on track.
With that said, and I have nothing to compare them to, they were perfect in the sense that I lost no braking performance during any of my track days. I used them in combination with the Endless RF650 brake fluid and never lost confidence in my stopping ability. My instructors both commented that the brakes on this car are amazing. If you've ever driven at Lime Rock, I was stopping at the 5 on the main straight all day with ease. After removing them and going back to stock pads, I noticed an immediate difference in bite. The stocks bite much sooner during daily driving I feel, and I like that, but I'm not sure why that difference exists. I should note that these things are extremely expensive and the only reason I bought them was because the Pagids RS29s were sold out everywhere last summer when I was looking, and I needed brakes immediately for a track day. I think I paid close to $850 for brakes and fluid. I will likely go to Pagids once these wear out, not because I dislike the MX72, but to get an idea of what the competition has to offer for less money. Again, I was extremely impressed by the MX72 and will buy again if the Pagids are not as good. |
01-10-2016, 08:07 PM | #75 | |
1033
Rep 1,997
01-23-2016, 07:37 PM | #76 |
Faster on 2wheels
132
Rep 381
Great post! Thanks to everyone that has contributed.
What's the best way to make sure you don't have air bubbles in your brake lines? If I just want to swap out my pads, not fluid, do I need to use the 29100 Quick Quad pad spreader? |
01-24-2016, 11:10 AM | #78 | |
533
Rep 1,415
i really don't know why anyone would ever need one of those. |
03-15-2016, 03:40 PM | #79 |
226
Rep 482
Necessary no. Helpful, absolutely. Unless you are one of those guys that likes to jimmy the old pad or a block of wood between the pistons and the rotor then expand it with a screwdriver or something. The tool makes it so you literally just pull the pads, stick it in, pump a couple of times, then slide the new pads in.
04-02-2016, 10:59 AM | #80 |
46
Rep 236
Hey guys... was hoping you can help with this weird issue. I followed the directions to the T, pressurized bleeder to 15lbs, and started bleeding my rear passenger brakes. I turned the valve slowly, and the fluid starting flowing to catch bottle, but only for a little bit. I turned the valve even more but no fluid was flowing. I thought I needed to turn more so I did that, and still nothing. I think I turned too much, because a little brake fluid was coming out from the valve so I just tightened it back up and called it a day.
Did I mess up a step? It's been driving me crazy that I couldn't finish it since no fluid came out. When I unscrewed the power bleeder cap from the brake reservoir in the hood, I noticed that the fluid was at the brim. Makes me think that the fluid was not flowing through to the system and was just "stuck" in the brake reservoir hence the fluid not flowing out of the rear caliper. What would cause this? |
mischiefbenz26.50 |
04-03-2016, 10:20 PM | #81 | ||
1164
Rep 2,561
What power bleeder are you using? How is it connected to the brake reservoir? Can you induce fluid to come out when it's not connected to the brake fluid reservoir? My power bleeder has a screw-clamp that allows you to interrupt the flow on demand (e.g.: bleed the brakes, then swap the pads). Does yours have something similar? Was it open or closed? Quote:
Somehow, your power bleeder setup was preventing gravity bleeding, never mind pressuring the fluid to expedite its exit. a
'19 TM3P (BK/BK)
'15 F80 M3 (SO/SS) ex-'17 I01 i3-BEV (PB/DD), ex-'15 I01 i3-REX, ex-E90, E46, E36's, E30's |
04-04-2016, 02:09 PM | #82 | |
46
Rep 236
I think you may be right about not flowing through. When gave up and unscrewed the brake reservoir cap, it was filled to the brim, making me think that the fluid from the bleeder that was pumped into the reservoir, did not flow through the system. Not sure why nothing flowed. When I turn off my car, I typically step on the brake all the way, then turn off ignition (with brake still pressed), and pull up my e-brake (habit from my manual days). Do you think pressing the brake then turning off the ignition has anything to do with the fluid not flowing from reservoir to the calipers? Thanks again! |
04-04-2016, 03:13 PM | #83 | |
241
Rep 481
I am pretty sure that is the reason your fluid did not flow. |
04-14-2016, 11:52 AM | #84 | |
1164
Rep 2,561
The pedal should come back into rest position after you release it, so it shouldn't matter. Unless it does, somehow ;-) It's been a few days - have you tried bleeding again without stomping on the brake pedal before turning ignition off ? a
'19 TM3P (BK/BK)
04-15-2016, 04:26 AM | #85 | |
241
Rep 481
BTW just bled my brake over the weekend. Everything flows like a river. |
05-18-2016, 10:26 AM | #86 |
386
Rep 2,989
I did my first brake bleed on my F80 last week. One suggestion that I would make is to use a knife to trim the four barbs on the spokes of the filter "basket" that sits in the reservoir opening. Those barbs make taking the basket out (to siphon the old fluid) a PITA.
Also, this was the first track event where the organizers tested my brake fluid. It turns out that you can buy a tester for $15 through amazon, so I imagine that track rats will be seeing this more and more. We were required to allow access to the reservoir (I overlooked that detail). This meant that I had to remove the black plastic cover over the brake fluid reservoir. Because of this, I'll likely cut an access hole and create a makeshift cover to simplify the bleeding and testing processes. |
05-31-2016, 10:05 PM | #87 |
1099
Rep 2,286
Has anyone ever come to any consensus as to how many times the retaining pins can be re-used? I've now done one swap from stock to Pagid RS29 and back to stock (which I assume is fine for the pins - but not sure if I should go ahead and order some replacements, and if so - are there any "wear" signs for when to replace the pins, or a rule of thumb as to how many times)? Thanks,
06-01-2016, 12:22 PM | #88 | |
241
Rep 481
