04-22-2014, 08:17 PM | #67 | |
that's what SHE said!
75
Rep 1,163
04-22-2014, 08:20 PM | #68 |
336
Rep 817
Drives: E30 M3 Darth Vader Trackcar
The reason the power is flat up top is because the torque falls off at the same rate the RPMs are increasing. Remember that HP is derived from TQ and RPM. Tuners that get some larger turbos or more efficient wheels in the future will have it pulling all the way to redline.
T |
04-22-2014, 08:29 PM | #69 | |
1099
Rep 2,286
With the F8x - we will achieve a higher level of fun at the lower rpm range and lower speeds. (Again, however, I still cannot stress how much I love my S65 and how much fun I still think it is after 6 years and 75k miles)!! |
04-22-2014, 08:36 PM | #70 |
10258
Rep 8,679
If anyone here has any experience or background w a tuned N54 you will quickly recall that this engine does not need to rev any higher than 5800. lol
An N54 protuned on e85 making 430 whp (aka the car in my sig) would scare almost everyone here. Sadly, I do not believe the s55 turbos have that much headroom.
2 x N54 -> 1 x N55 -> 1 x S55-> 1 x B58
04-22-2014, 08:40 PM | #71 | |
894
Rep 9,034
IMO, having an engine suddenly surge forward and wake up a 5,000 RPM when most engines start to run out of breath (and just keep pulling until 8,000 RPM), combined with the scream of a V8 at 8,200 RPM... that's INTOXICATING. We'll see how the S55 pulls up top. A 7,600 RPM is pretty good for a turbo motor, but does it really pull up top?? .
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
04-22-2014, 08:49 PM | #72 |
63
Rep 189
Thanks for offering your perspective. Now, I miss my M3 E90 more than ever! Weep! Weep!
2011 M3 E92 Alpine White/Fox Red DCT
04-22-2014, 09:11 PM | #73 | |
166
Rep 444
Personally I found the nature of the S65 extremely aggravating in day-to-day driving. It is an engine meant for a lightweight track car, not a heavy luxury sedan. |
04-22-2014, 09:26 PM | #75 |
Commander-In-Chief
2206
Rep 8,949
I use my E92 80% as a DD and love it. Depends on your driving conditions and preferences I guess.
04-22-2014, 09:37 PM | #76 | |
99
Rep 1,575
I agree a 335i is more comfortable in street driving without redlining, however, I didn't buy an M3 for this reason.
04-22-2014, 10:06 PM | #78 |
Rep 3
Hi All,
Trying to learn something here. Engine wise, seems S55 is better every way than S65 - power, fuel economy. Why then did it take so long for BMW, Merc, Audi, VW and many others to jump on the Turbo technology only now? Is it turbo engines cost more to build, shorter life span, higher maintenance.. don't seem to be from my past Evo X experience. Thanks for sharing. |
04-22-2014, 10:13 PM | #79 |
///M Uber Alles
333
Rep 1,601
I'm intrigued by the power curve climbing steeply to a plateau at about 5500 rpm and then plaining out until about 7300. The power curve of the N54 took a dive at about 6000 rpm producing a noticeable "party's over" feeling when driving. Am I right in thinking that the S55 will still be in a fun zone at that high of rpm because that's where it is making its peak power?
04-22-2014, 10:16 PM | #80 | |
21133
Rep 20,742
Drives: 2021 911 turbo
04-22-2014, 10:37 PM | #81 |
31
Rep 496
Gearing :
E92 dct Final-3.154 1-4.78 2-2.933 3-2.153 4-1.678 5-1.39 6-1.2 7-1.0 F80- Final-3.46--9% shorter 1-4.8 --same-----9% shorter overall 2-2.593 14% taller------6% overall tall 3-1.7. 21% taller_------12% overall tall 4-1.27----25% taller---16% tall overall 5. 1.0-----29%_--------21% tall overall 6. .84-----30% taller----21% overall 7. 0.67...---32% taller----24% overall So check my math but 1st bear choice is crazy. I can't use 1st in my e92 due to traction limitations so talk about hard to launch. F80 will be really tough to put power down in first. 2nd gear is going to be downright freight train. But e92 is quite a bit shorter gearing from 2nd on. So you can't only compare dyno plot as gears are the other half. If someone wants to create a plot with gear ratio differences taken in to account, the f80 will be way faster but not quite as much as it has seemed thus far. Keep in mind at WOT you don't see below 6500 ROMs in e92 dct so you can't draw a line straight up as they do as you need to account for e92 power band . So love to see area under curve of each cars WOT power band with gearing taken into account |
04-22-2014, 10:41 PM | #82 |
62
Rep 499
I think it definitely will pull hard up top if it is anything like the N55 + MPPK + MPE... Now I only have experience w the 6mt in that config
In antithesis to the N54(T) the N55 (6mt) example doesn't have the same bottom end the taller gears used for gas savings means you really have to wring it out... Yes it is decent until you get up top So I'm sure the bottom end will be ok... Even more so than the N55 but who knows how the gearing and turbo tech really affect the output given in a claim range Now even though I suggest the 6mt for driver involvement and fun factor, the DCT may be the way to go for seamless power output Hopefully the active noise can indicate rpm and power well but I still think the S65 is the right blend |
04-22-2014, 10:44 PM | #83 |
500
Rep 2,400
Tuned FBO S65 produces 400+ bhp (crank) from 6900-8600 rpm. If there isn't a big weight difference, think there won't be a huge difference in a track situation. Recall someone at BMW saying 10 secs faster than stock S65 M3 on the N-ring.
04-22-2014, 10:53 PM | #84 |
62
Rep 499
I was only saying S55 based on N55 as a starting block
Certain designs elements look as if the best bits are pulled from S54, N54T and S65 ... A little bit if this, add a dash of that The one area I don't like is that air induction I feel that the engineers could have designed better intake snorkels |
04-22-2014, 11:20 PM | #85 | ||
209
Rep 7,298
my wife has a 135i and yes it is torquey but i am always in the right gear at the right time regardless of what car i am drivig. kash, low end torque and shifting gears at 4k rpm to get to a given speed vs a screaming v8 in higher revs to get to the same said speed in city driving, add in heel toe shifting 100% of the time and it is still tons of fun. new engine is no doubt better. i just dont understand the "potential in city" due to low end torque. shift if needed. thats what its there for!! |
04-22-2014, 11:41 PM | #86 |
500
Rep 2,400
If raise rev limit on an MT in FBO application, S65 upshift also occurs at 6500+ rpm at which point you're producing ~370 crank bhp, which is also pretty high..by 6900 you are at 400+. Pretty amazing in its own right as an N/A engine and multiply with shorter gearing and still a very fast car. TQ at wheels though still be higher in S55
04-22-2014, 11:45 PM | #87 | |
992
Rep 1,370
turbo cars are more efficient in that you get more hp/liter displaced.. especially when just cruising at relatively low rpm (e.g. 1.8k) turbo's really aren't in use and you are getting the fuel efficiency of a smaller displacement motor (3L vs 4L) S65 was a marvelous engine.. i think it was just robbed of it's glory by the porky weight of the E92.. high rev motors shine in cars that are light on their feet (think rx8 and s2k).. both ridiculously fun cars to drive.. now imagine putting those motors in a car like a challenger... i think you get my point |
04-23-2014, 12:05 AM | #88 |
62
Rep 499
Ok maybe second, but I'm not used to
Downshifting into 1 The dct/dsg in my other cars may have ruined this for me I am more used to third gear as the go To gear Imagine downshifting and flooring like crazy in first w S55 |
