03-30-2015, 02:09 PM | #67 | |
1943
Rep 1,552
2020 M2 CS, 2018 M3 CS, 2016 M4 GTS, 2013 M3 LRP, 2011 1M, 2011 M3 GTRS3, 2004 M3, 2002 M3, 2000 M Coupe, 2002 M5, 1997 M3, 1988 M3, 2022 STO, 2020 Urus, 2022 TRX, 2022 392, 2021 SVJ, 2018 Performante, 2013 Gallardo 550-2, 2012 Gallardo STS, 2018 R8 RWS, 2012 R8, 2017 G550 4X4^2, 2015 GT3, 2015 Continental GT3R, 1971 Bronco
03-30-2015, 05:21 PM | #68 |
1538
Rep 1,665
I didn't do the install for my KW HAS. Went to EAS as they had lots of experience and I've had zero issues. When I used to wrench on my own cars, I always made sure to pre-load the suspension before I torqued everything to final spec, i.e. I'd put a jack under the brake caliper assembly and lower the weight of the car allowing suspension to compress before torquing down all the various suspension joints, sway bar links, etc. to spec. Never had any issues with squeaking or popping noises with any of the coil over suspensions, springs or shock installs on any of my cars.
BTW, I'm not sure if springs seating properly on KW HAS is a big deal. When I adjusted the front and rear heights, the front coils rotated a lot and I don't think they ended up in exact same position as when I started. The rears moved a little bit. In both cases, no adverse effects at all. No noise or anything. Good luck to those of you dealing with this issue. Hope you figure it out. Regardless, thrust sheets are still a great idea as it would allow you to spin the height adjustment collar easily without the springs moving. |
03-30-2015, 07:04 PM | #70 |
1943
Rep 1,552
03-31-2015, 05:20 AM | #71 | |
Rep 2
04-01-2015, 05:17 PM | #72 |
423
Rep 4,499
Wednesday update?
Have BT Tool professional, will scan and clear codes on your BMW. And now I am able to code my 2011 335is and M4
Link to my M4 euro delivery! http://f80.bimmerpost.com/forums/sho....php?t=1006526 |
04-02-2015, 09:15 AM | #73 |
1943
Rep 1,552
well..............................................
I still have noise. the 70mm sheets are barely too small. on a limited time frame we were able to trim the plastic sheet and install, but not the metal one yet as trimming that is going to take a little more time....we are only talking like 2 mm's unfortunately. Regardless, we quadruple checked the installation and everything is how it should be. to confirm, we literally had every mechanic in the shop come over and check things over to make sure something wasn't overlooked. few observations though this time around. i had a TON of dirt and pebbles, etc in the suspension. it seems to be common for our cars as we are getting the brake issue also, but im really tempted to try to find an offroad 4x4 sleeve for at least the front. the other observation is the coil finish is worn off in areas on the second coil from the bottom, and we are thinking this contact is an issue obviously. we have a few ideas we are going to try tomorrow to see if we can come up with a remedy. rm
04-03-2015, 02:22 PM | #74 |
Gone Fishin’
7318
Rep 12,125
Hope you can get this fixed bud. Shouldnt see any rubbing with the rubber seats on the bottom though?? They did use the new rubber seats right?
I drove 400 miles in varying conditions since I had mine fixed. Not a noise. |
04-03-2015, 04:32 PM | #75 | |
1943
Rep 1,552
We used a nissan spring isolator part that does essentially this: http://www.e90post.com/forums/showthread.php?t=609774 The noise is 75% better now. I know it doesn't truly fix the bind, but makes tight turns and inclines sound much much better. |
04-08-2015, 08:05 AM | #76 |
71
Rep 122
Not sure if your issue is the same as mine, I needed to add a 3mm spacer as my inner wheel was rubbing on the front struts. It was murder making turns, metal on metal. After a lengthy review of the install, we added 3mm spacers and I no longer have any issues.
Alpine White F80 M3 /// Full Sakhir Leather Interior /// 19" Vorsteiner VSE-003 /// M Adaptive Suspension /// DCT /// Carbon Fiber Trim /// Executive Package /// HK Sound/// LED Lighting /// Moonroof /// Driver Assistance Plus
04-08-2015, 09:29 AM | #77 |
1943
Rep 1,552
That's interesting..glad you got yours figured out. Im running 15s all around and my issue really is the coils as the finish being worn has shown us whats going on..hopefully adding a coupla more isolators next week makes it more tolerable.
04-08-2015, 11:17 AM | #78 |
Gone Fishin’
7318
Rep 12,125
Can you post a picture of what you're talking about?
04-08-2015, 01:39 PM | #79 |
1943
Rep 1,552
Here's the only pic I could find..that plastic ring was the thrust sheet we tried
04-18-2015, 07:14 AM | #82 |
1943
Rep 1,552
Great to hear! I Really think my issues have been just bad luck, and maybe something to do with how the front at complete max height. Regardless, we added more isolators and the pinging while there, is much more tolerable
07-17-2015, 09:21 AM | #83 |
76
Rep 613
Drives: Melbourne e92 M3
Any video of this sound I have a clicking noise when ever there is a load on the car in the rear put on lift yesterday tightened everything sprayed sway bar bushings wall can't seem to get vid of it dropping car at bmw tomorrow
07-18-2015, 05:36 PM | #84 |
1943
Rep 1,552
I apologize but I don't have any video. My sound comes from popping when the front springs get in a bind, but my rear is quiet. The pop is still there, but it's just more subdued now in the front.
07-29-2015, 05:48 PM | #86 |
Gone Fishin’
7318
Rep 12,125
07-31-2015, 12:20 AM | #87 |
287
Rep 580
No noises with my recently installed HAS kit either. Only about 50 miles on it so far, but haven't heard a thing. I always thought the slow speed popping sounds were caused by sway bars.
2015 ///M4 - Alpine White - My ED
Executive Package / Lighting Package / Black 19's / Adaptive Suspension / Harmon Kardon / DCT |
07-31-2015, 10:24 AM | #88 |
1943
Rep 1,552
since the isolators have minimized the noise for me, I stopped looking for larger diameter thrust sheets. im still overall very happy with the setup and as mentioned, im at the most minimum drop up front, which could have something to do with the spring bind, as I don't know anyone else running the fronts all the way up.
