08-18-2020, 09:41 AM | #838 |
10547
Rep 41,232
Drives: 2018 Alpina B6 650ix GC
PM sent.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
08-20-2020, 11:48 AM | #840 |
Rep 59
can i get link to most recent files for f10/550i and f83/m4?. i purchased a usb obd2 cable from amazon - but it looks like from the above i may need an ethernet cable (please advise). my laptop does not have ethernet - so would need usb to ethernet adapter. thank you in advance for your help!!.
08-20-2020, 12:06 PM | #841 | |
10547
Rep 41,232
08-25-2020, 08:51 AM | #842 |
247
Rep 282
Question... I just made a DIY video for coding the anti-dazzle to help people condense the pages and pages of information. In the video I made the statement that this could be done for the LED Adaptive Lights as well as the Xenon Adaptive Headlights because I read that during my research. I show how to do it for the LED, but now I'm being asked how to do the Xenon since there are no LHM[43] or LHM[44] modules. Anyone happen to know?
08-27-2020, 06:48 PM | #843 |
Rep 59
Shawn - thank you for sending the file links. trying to install and run but getting an error when running the launcher.
PSdZ API Module Failed...error...tokenmaster\e-sys launcher...cant find dependent libraries. any ideas to fix appreciated. |
08-27-2020, 08:31 PM | #844 | |
10547
Rep 41,232
Visual C++ Redistributable Packages for Visual Studio 2013 https://mega.nz/file/MoZEXQyZ#456-g1...mb7_RLIGdzYCNc
08-30-2020, 11:18 AM | #846 |
Rep 59
Shawn - thanks again for your help. yesterday got e-sys running and connected to car (f83). tried again today after doing some reading on how to use the tool (i don't want to screw things up - so proceeding cautiously). Now i think i have an issue with the token from launcher. i have attempted to attach the message. hopefully you can rescue me..
08-30-2020, 11:19 AM | #847 | |
10547
Rep 41,232
08-30-2020, 03:49 PM | #849 |
10547
Rep 41,232
08-31-2020, 10:44 AM | #850 |
Rep 59
I am having some fun with coding and the tool seems to be working well. Thank you Shawn!!
I have been coding a few things on 2015 f83. Question - are the cheat codes for f30 same for f8x? (I did not see a cheat code sheet for f8x in the downloads. I have been running e-Sys on a surface pro and connecting through a usb-enet adapter. Works great. Only problem is that the screen is somewhat small with high resolution and some of the fonts eg vo list are not legible. I tried reducing the screen resolution which helped but vo list is still very difficult to read. Is there a workaround on this? Next I will move to 2012 f10. Looks like there is a great cheat sheet on this. Question- I recall something about not being able to switch cars on the tool for a few days after use. Can you comment. Thanks again. These tools and Shawn's help are really great. |
09-17-2020, 09:12 AM | #851 |
247
Rep 282
Hey Shawn! Where's the best place to get ISTA+ these days? Do you have that as well? (I know you're the man for eSys) Really I just need ISTA/D I guess since I use eSys for the coding part.
I actually already have version 4.12.12 installed on my laptop, but I'm trying to help a buddy get it installed for himself and I did this 2 years ago and don't remember what I did haha. |
09-17-2020, 10:29 AM | #852 | |
10547
Rep 41,232
For Resolution issue, right-click -->properties on java.exe and javaw.exe; in the "Compatibility" tab, and tick "Override high DPI scaling behavior. Scaling performed by: System" Car Switching limitation is old Launcher PREMIUM Tool, not Launcher PRO.
09-17-2020, 10:31 AM | #853 | |
10547
Rep 41,232
TTGator247.00 |
09-21-2020, 11:24 AM | #855 |
10547
Rep 41,232
PM sent.
09-22-2020, 07:51 AM | #856 |
300
Rep 543
wanted to double check...is there a newer version of the "E-Sys - Getting Started Coding v.2.pdf" linked to in the first thread? Want to make sure I don't F anything up when coding Euro MDM* on my F10 M5.
*and probably TPMS to show temp/pressure and a few other smaller things.
Sakhir Orange F10 M5 | KW V3s | Dinan Swaybars | Turner Monoballs | Soul Exhaust | Mishimoto Oil Cooler
09-22-2020, 08:08 AM | #857 | |
10547
Rep 41,232
09-22-2020, 09:02 AM | #858 |
300
Rep 543
OK, thanks. So after setting up the software, to do my Euro MDM coding I'd want to:
1. connect to the car using the "...VehicleInfo=F010" (non-direct) Target & Connection Via VIN 2. Click Read (and, to be safe, save a backup?) 3. Click Read SVT 4. Select the CAFD under DSC and select "Read coding data" 5. Right-click the new CAFD file under said CAFD and select "Edit FDL" 6. Update the 7 entries listed here 7. Click "Save", hit green back arrow, right-click FA, and select "Activate FA" 8. Re-select the same CAFD file I did the updates in and select "CODE FDL" 9. Wait for that to be Done, then disconnect and I'm done?
Tags |
bmw coding, f80 coding |
