01-11-2023, 06:40 AM | #683 | |
Rep 13
01-11-2023, 08:51 AM | #684 |
1662
Rep 1,536
01-11-2023, 10:06 AM | #687 |
Rep 13
Yes. I’ll reach out to Vik. I’m a bit nervous because this only happened after I loaded BM3. Tails worked flawlessly for about 6 months.
01-11-2023, 12:53 PM | #688 |
4151
Rep 7,165
Drives: F90 M5 / F15 50i
There’s also a hardware issue that was causing issues with the outer sections. It may be that. Had my driver side replaced under warranty.
'07 Yamaha R1 (sold)
01-11-2023, 01:12 PM | #689 | |
Rep 13
*purchases mega millions ticket. |
01-11-2023, 09:13 PM | #690 |
4151
Rep 7,165
At least the outer ones are pretty easy to remove and replace.
01-13-2023, 08:10 AM | #691 |
Rep 13
01-13-2023, 12:58 PM | #692 | |
Rep 27
The problem would drive me crazy so I figured on the chance I had defective lights and I could buy new ones at a decent price- and I did. So far the issue hasn't come back. Again thanks to fellow board members. |
Joe-BMW337498.00 |
01-13-2023, 05:32 PM | #693 | |
Rep 13
01-17-2023, 08:27 PM | #694 |
Rep 25
Hey all,
So I got a set of tails from Abdul and they are genuine bmw. I’ve now had 2 excellent coders check this and neither can sort this with coding. Here’s the background. 2017 540i Tested 5 sets of inner taillights same result. The issue is on the inners. I have the euro spec lci tails, with fog lights. Outer lights work perfect, jumped the signal to inners, that works perfect. Inner tails will light when off the brake and under brake with fog lights off. The issue is when I have the rear fog lights on, the inner tail lights won’t bright up under braking. Mohsin and Vick have both attempted to sort this out with coding to no avail, I have 5 sets of inner tails from Abdul to attempt to sort the issue. (Amazing service by those guys for that btw). So that rules out hardware It seems everything technically works, just not at the same time, since the brake lights work without the fog lights on. Anybody got ideas? My last ditch effort is to jump the brake light from outer to inner, but I would really like to avoid that if possible.
2006 - 330ci ZHP Vert (For sale)
2017 - 540i (Bm3/Xhp) 2015 - Lexus Is250 F Sport |
01-18-2023, 02:33 AM | #695 | |
7498
Rep 6,865
Drives: '18 M550i|'21 X5|'03 540i
Garage List 2013 VW Tiguan [0.00]
2015 Infiniti QX60 [0.00] 2021 BMW X5 [0.00] 2003 BMW 540i [0.00] 2018 BMW M550 [10.00] |
So just to make sure we are on the same page. When my rear fog is activated, only the drivers side inner tail fog light illuminates, not both. Supposedly this is by design and a requirement in a lot of countries as to not appear you are hitting the brakes. When my fog is activated, the inner tails do not brake or light up on braking. Vic was my coder. I can’t remember if I even asked him to look into the inners not lighting up when fog is on, but I did ask him to look into having both fogs light up and he couldn’t do it. I do know someone who has a 2017 540 that was able to code it himself successfully. I tried to copy his coding and found I did not have the same parameters. At the end of the day, the fog light thing was more of an experiment and I honestly have zero practical application in real world Boston weather. Maybe Chicagoland is foggy. I had the fog wire sitting there so I bought the switch and had Vic code it. I can’t even remember the last time I even thought of using it. Everything works fine with it off and honestly I am not quite sure that the inners not braking with fog on isn’t by design. Long answer short, yes, mine do the same thing and it’s not the lights.
2018 M550ix|Carbon Black|Dinan Modifications|2003 540i|Jet Black|M-Sport|2021 X5 Mineral White
Prior BMW's: 1987 325e|1993 740i|1998 740il|2001 530i|2002 745li|2007 750li|2006 750li|2001 530i|2012 535xi| Last edited by Joe-BMW33; 01-18-2023 at 08:13 AM.. |
01-18-2023, 10:04 AM | #696 | |
Rep 25
These are the types of things we are looking for instead of beating my head against a wall. Vick recommended me to jump the fog light over to get both on, works great, no errors. And yes to confirm, my car is coded so right rear fog goes on, however when the rear fog is on, jumped or not, none of the inner tails light up under braking. I would imagine the car would be coded for the fog light laws and not the taillight though (BDC). But its def a route to look into. I have seen cars that have both fogs coded and all brake lights engaging under brake with fogs on. So it is possible.
Joe-BMW337498.00 |
01-21-2023, 10:11 AM | #697 |
Rep 25
Ok so to confirm. I took the tails out to do a full reinstall. Here’s where we are so far.
I completel severed the brake wire going to the inner. Tapped the half going to the light to the outer brake light (2nd wire). Same results as before. Which tells me the inner tail light under braking is not getting its signal from the brake line while fogs are on. Which means, the fog light itself is essentially telling the tail light to cut all optional power to that tail light or voltage change to light up. Next test is messing with the fog light coding to see if there is something in there that’s telling the inner tails to disable while it’s activated
Joe-BMW337498.00 |
01-23-2023, 05:45 AM | #698 | |
7498
Rep 6,865
Prior BMW's: 1987 325e|1993 740i|1998 740il|2001 530i|2002 745li|2007 750li|2006 750li|2001 530i|2012 535xi| |
01-23-2023, 05:50 AM | #699 |
7498
Rep 6,865
Found it:
LIC_LOG_LAMP_2_OUTPUT_CHANNEL_INDEX Current: G30_ECE_code | Factory: G30_US_code LIC_LOG_LAMP_2_OUTPUT_CHANNEL_DATA Current: G30_ECE_code | Factory: G30_US_code LIC_NIVEAU_OVERRIDE_INDEX Current: G30_ECE_code8 | Factory: G30_US_code2 LIC_NIVEAU_OVERRIDE_DATA_0 Current: G30_ECE_code6 | Factory: G30_US_code2 LIC_VERSION_DATA Current: G30_ECE_code | Factory: G30_US_code iF ABOVE DOESNT HELP THEN TRY BELOW AS WELL AS ABOVE. LIC_NIVEAU_OVERRIDE_INDEX Current: G30_ECE_code8 | Factory: G30_US_code2 LIC_NIVEAU_OVERRIDE_DATA_0 Current: G30_ECE_code6 | Factory: G30_US_code2
Maverik2594150.50 Abdul1046.50 |
01-29-2023, 11:29 AM | #700 |
Rep 1
Hello guys,
I`m new to this forum, I bought 520i g30 (2019) in Europe and I want to upgrade the tail lights to LCI (EU spec). I`m not very technical person, so I would appreciate if you can answer some of my questions. 1) Regarding the repining process, do I just need to repin the wires in accordance to the instruction that was posted before? Do I need add any additional wires? I see that instructions are for the US or Canadian cars, however I have a European car. Can you please share repining instructions for the European car? I`m asking this, because I found a youtube video where to guy is adding additional wires, so I`m a bit confused. Can you please share the repining instruction for the 2) Do I need to contact Vick after I have installed the new tail lights? Thank you in advance, Richard Last edited by rx23; 01-29-2023 at 12:58 PM.. |
01-29-2023, 03:51 PM | #701 | |
7498
Rep 6,865
I am pretty certain you need to follow the same instructions as US people putting Euro lights in US cars, but coding may be different, but you will still need coding. The only sure thing is that you will have a rear fog wire. The purpose of the jumper wire or extra wire from the BDC is to allow the inner tails to light up when braking or blinking, I can’t remember, but probably to allow the inner to blink for turn signal. Pre LCI tails on light up or blink on the outer when braking or for the turn signal, so I think you are going to need a jump wire detailed in this thread or you need to run an extra wire from the BCD for each side, this is what I did, but jump is easier. Reach out to Vic via What’s app to confirm what I’m telling you. He will be happy to help and he will definitely confirm the answer. Then if he confirms, Follow these install instructions and then have Vic code. He is very famailir with the install of Euro lights on non US cars. Good luck!
01-30-2023, 07:06 AM | #703 |
7498
Rep 6,865
Thanks Jake! I like helping people out. There may be something in this thread that has become a novel about the wiring for Euro lights in Euro cars, but nothing is popping into my head and I am not willing to re-read a thousand + posts. I did that when I jumped in on the LCI lights. I hope people take the time to try and skim or read through this thread before asking though.
02-14-2023, 12:11 PM | #704 | |
Rep 2
