01-20-2016, 11:07 AM | #45 |
Jedi Wannabe
7
Rep 34
Well, that sounds good to me! Thanks guys!
2009 E82 128i ZSP, Space Grey
2001 E46 330ci ZSP, Topaz Blue (Gone but not forgotten) 1995 FZJ80 Toyota LandCruiser, White |
02-08-2016, 02:01 PM | #46 |
Rep 3
Would anyone be able to recommend a battery that would fit the brace in our cars? I'm looking at getting a optima yellowtop and it seems a lot smaller then our factory supplied battery.
02-08-2016, 03:41 PM | #47 |
123
Rep 505
I believe any H6, H7, and H8 battery will fit in our trunk. I recently changed out my battery for an H8 agm from advanced auto parts. I don't believe there's an OEM fitment with the optimas so you would have to make some kind of modified hold down.
02-13-2016, 07:38 PM | #48 |
Rep 3
I highly recommend the Autozone Duralast H8-AGM. I just replaced my original (2010) battery in my 128i with that model from Autozone. Fits perfectly, including the vent tube which plugs into the same end with the existing elbow, and comes with a cap to cap off the other end. It is slightly longer than the OEM battery, but still fits perfectly because the bracket has two screw holes to mount the battery, and this battery simply requires you to use the 2nd mounting hole instead of the shorter original one. It is an improvement over the OEM battery in CCA, also glass-mat which is an upgrade. My cost (on sale) was $179, and along with purchasing Carly-BMW (Android) at $50 to register it still came in at less than half what the dealer quoted. They told me battery replacement was $470 including labor. Very easy job to do yourself, if you get the registration software, and you will save a lot of $$$.
02-14-2016, 04:55 AM | #49 |
35
Rep 528
DO you have the model or part number?
khekking
6MT/CDV Delete/Injen Intake/berk race exhaust/ Cyba Scoops/ECS cryo rotors/Axxis ultimate pads/H&R coils/BBS LM-esque lol/BMW PE front/whiteline sway/and did i mention 2200 at 1 ohm ...eyeing the auto diff currently
02-14-2016, 03:03 PM | #50 |
Rep 3
It is H8-AGM, that's the part number. Here is a link...
http://www.autozone.com/batteries-st...?checkfit=true |
02-25-2016, 05:35 PM | #51 | |
28
Rep 381
I used an optima on mine and had to modify the bracket
2013 BMW X1 * 1973 Clubman GT * 2016 Mazda MX5 * 2000 Honda S2000 2004 BMW 325i Touring * 2009 BMW X5 3.0xdrive |
02-25-2016, 10:24 PM | #52 |
bimmerphile, technogeek
1000
Rep 3,786
Drives: 2012 E82 6MT Sport
Is that just a piece of cardboard?
02-26-2016, 11:20 AM | #53 | |
71
Rep 675
Drives: 2010 128i, manual, sport pkg
2010 128i manual, sport package, performance exhaust, Vorshlag camber plates, Bilstein B6 struts/shocks, 245/40/17 ZIII square on et 40 with rolled rear fenders.
02-26-2016, 02:24 PM | #54 |
123
Rep 505
CCA does not matter as long as you have the same (or close enough) AH. getbmwparts doesn't show the AH, but if you look up the 720 vs the 640 they have different AH ratings.
03-15-2016, 11:43 PM | #55 |
28
Rep 381
03-20-2016, 02:40 PM | #56 |
A driver
13
Rep 77
Whaaaaat?? $470 or $500 for battery replacement and registering?
That's shocking price! I need to change the battery soon, but Amazon doesn't show Carley BMW bluetooth adapters anymore. Anyone can help me with battery registeration? I'll buy a lunch or coffee. BTW, Is this a good battery? |
04-18-2016, 06:45 PM | #57 | |
28
Rep 381
05-07-2016, 03:31 AM | #58 |
127
Rep 609
Do you need a trickle charger? I am ok with resetting my radio stations and what not..
Or is there something else? I randomly check my JB4 for codes cause I am paranoid and I got the 387F code, which points to the battery I think, silly since its a 2011 with only 25k on it :*( Thinking about hitting up a auto parts store and getting carly app... |
12-03-2016, 01:56 PM | #59 |
37
Rep 499
Ok so the other day my car wouldn't start so I had to get it jumped and that worked. so I assumed it just needed to be charged. so I went out and bought a charger, had it charging over night. Went to start it again and nothing. So I guess I have to get a new battery and after reading everyone's comment about not taking it to the stealership I'm on board to do the same. my question is what is the smallest battery I could go with besides the H8-AMG
135i////Cobb Stage 2/VRSF 3" catless DP/BMS intake/BMS OCC/AMS FMIC/CP-e exhaust/19" 8.5 et40 9.5 et45 VMR VB3's BUILD THREAD http://www.1addicts.com/forums/showthread.php?t=832779
12-04-2016, 11:22 AM | #60 |
123
Rep 505
As I mentioned earlier, you can go with H6, H7, and H8. My original battery from BMW was a H6. From Guam135i's pictures, you can see it has 3 mounting points -- one for each size mentioned above.
12-04-2016, 01:34 PM | #61 |
37
Rep 499
12-05-2016, 11:01 PM | #62 |
37
Rep 499
Car is up and running again thanks everyone for sharing your info. big help and it was a very easy install
Evan@Tischer3530.00 |
12-16-2016, 04:07 PM | #63 |
Flatlander
36
Rep 67
Has anyone had success with buying and registering a new battery using the MHD app software adaptations reset?
135i Mods: MHD / cp-e FMIC + Mounted Oil Cooler / BMS Downpipes / aFe Stage 2 Intake / Berk Exhaust / BMS OCC / Dinan Camber Plates / Apex EC-7 Wheels / 1M Suspension Bits / Koni & TC Kline SA Struts / Quaife LSD
335xi Mods: MHD / JB4 / DocRace ST 6062 / PhoenixRace FMIC |
12-19-2016, 09:50 AM | #64 | |
427
Rep 957
I wrote this guide on how to register/code a battery: https://www.spool street.com/forums/threads/register-and-code-a-new-battery.1020/ It walks you through some of your other options. Last edited by bNks334; 12-28-2016 at 09:03 AM.. |
12-19-2016, 03:50 PM | #65 |
19
Rep 370
I just had the original battery of my 6.5 years 128i replaced by my local independent shop (specialized in BMW), he charged me $319 for the battery and registration...
128i manual, AW, Boston Terra Leather, Sport package, Premium Package, Cold Weather Package, HK sound
01-17-2017, 03:01 AM | #66 |
46
Rep 370
i think i have done something really bad
i did disconet my battery and closet the trunk:S u think i can ad power in the engine, to be available to open the trunk |
