04-18-2013, 10:08 AM | #45 |
8
Rep 45
if you turn like a pensioner, yes inner tire wear will increase, but if you ever hit onramps with moderate force, it will be more even. most spirited drivers develop more outer tire wear because there isnt enough negative camber in the first place.
123i25.00 |
04-20-2013, 12:19 PM | #46 |
California-bound
385
Rep 1,480
Only if VERY aggressive camber settings (i.e. aftermarket camber plates, control arms completely maxed out) are used. Toe is what kills tires on most if not all street cars. To put it in perspective, with the camber pin removed on stock front suspension, you are going to get maybe -1* of front camber. In order to have true camber wear on the tires, you would need -3* or more. Also, any sort of aggressive driving will ride the outside edges of the tire, so some amount of negative camber is actually beneficial for tire wear. I can personally attest to running -2.5* front camber w/ 1/8th" total toe out on my previous car for daily driving/autoX/track days, and I always had excellent tire wear.
Streets of Willow: 1:27.7 CW 11/15/15; 1:29.5 CCW 8/15/15 |||| Autoclub Speedway ROVAL (CCW): 1.52.6 - 12/2/17
Willow Springs - Big Willow (CW): 1:35.8 - 3/31/18 |||| Buttonwillow #13 (CW): 1:59.3 1/27/18 https://www.facebook.com/JakeStumphRacing |||| http://www.youtube.com/user/RaceMeMZ3 |
123i25.00 |
04-26-2013, 02:25 PM | #47 |
8
Rep 92
Thanks for this thread!!! just did it...I had the latter version that had to be drilled out - very easy soft aluminum! literally 10 minutes for the whole job.
once it was drilled out: after I jacked up the car, loosened the 3 nuts, and pushed the strut towards the center of the car: I gained a bit more on the passenger side...but about ~1/4" movement. going for an alignment today. considering if I should slot the holes a bit more to get more camber. |
03-10-2014, 06:02 AM | #48 |
234
Rep 2,643
I did the mod on my E90 (2009 model). The pin was drilled out with a 6.5mm drill bit. After a bit of drilling, the pins detached themselves and came off cleanly.
04-02-2014, 12:10 PM | #49 |
326
Rep 914
Just came across this thread and I have a question (probably pretty dumb) but I have coilovers with camber plates already on them, and I will be adding more camber soon. Can I remove this pin and gain more camber along with the adjustments allowed by the camber plates?
04-02-2014, 12:27 PM | #50 | |
461
Rep 4,531
The pin was simply there for initial installation of the suspension at factory. Camber plates do not have a pin slot. |
04-02-2014, 03:10 PM | #51 |
326
Rep 914
I didn't think so, and I don't believe they are. My camber is set at around -0.9* at the moment so I doubt they're maxed
04-02-2014, 04:00 PM | #52 | |
461
Rep 4,531
04-04-2014, 06:19 PM | #53 |
Rep 47
My car is a 6/2013 build. Last night I gave the pins a few good whacks with a 2-3 pound hammer via a 3" long 1/2" extension. Nothing happened. What am I doing wrong?
05-03-2014, 03:27 PM | #54 |
Flatlander
36
Rep 67
After removing the pin and taking the three bolts off, I can not get the strut to move at all. Everything I do to shove it over won't work? I don't want to get real violent with it and damage something.
Is there spring pressure pushing the strut up against the top hat preventing it from moving easily? Its doesn't seem like this has been an issue for anyone here?
135i Mods: MHD / cp-e FMIC + Mounted Oil Cooler / BMS Downpipes / aFe Stage 2 Intake / Berk Exhaust / BMS OCC / Dinan Camber Plates / Apex EC-7 Wheels / 1M Suspension Bits / Koni & TC Kline SA Struts / Quaife LSD
335xi Mods: MHD / JB4 / DocRace ST 6062 / PhoenixRace FMIC |
05-03-2014, 05:34 PM | #55 |
234
Rep 2,643
If you only jack up one side of the car, the sway bar is fully compressed. The solution is to put the front of the car on jack stands so both wheels are unloaded. The rubber bushings on the arms will still provide some upward force, but not too much. Its better Not to take the front wheels off the car because the weight of them is a help balancing the forces. Also there's no need to remove the 3 nuts on the strut hat completely.
01-18-2016, 10:26 PM | #56 | |
10
Rep 66
Thanks. Last edited by YarkoDrives; 01-18-2016 at 10:33 PM.. Reason: sent pm to Xaeryan, summary here |
01-28-2016, 10:07 AM | #57 |
162
Rep 1,523
After coming across this DIY, I took a look at my alignment pins. The passenger side pin is punched/sheared off but the drivers side is still intact. I bought my car used about 2 years ago and have had an alignment done in the past. Any reason only one would be punched and not the other? Adjustment only was needed on that side?
02-25-2016, 05:43 PM | #58 |
28
Rep 381
Did you do this already and any write up?
2013 BMW X1 * 1973 Clubman GT * 2016 Mazda MX5 * 2000 Honda S2000 2004 BMW 325i Touring * 2009 BMW X5 3.0xdrive |
02-25-2016, 08:03 PM | #59 | |
828
Rep 2,232
http://workshop-manuals.com/bmw/3_se...t_support_bea/ and http://workshop-manuals.com/bmw/3_se...xle/page_1064/ Paper Copies may say the same thing? |
02-25-2016, 09:36 PM | #60 | |
68
Rep 627
Drives: '09 E88 135i M-Sport/6MT/SGM
I got an alignment done after installed M3 controls and they only punched one side out as well. I was told its just how it is and it is fine. It makes sense since during assembly every car can't be exactly the same.
| Dinan S2=>MHD | e46 M3 trans mounts | Dinan CF CAI | ER CP | HKS SSQV4 BOV | RB PCV Valve | VRSF DP | N55 MP | BMW PE | OC | VRSF 7" FMIC | UUC Evo3 SSK | EBC GD Sport Rotors | EBC Redstuff | TRW F+R | | Whiteline KDT918 | H&R Front Sway | BMWP 313 | MPSS 225/255 | Scopione CF Rear Diffuser | iCarbon CF Rear Spoiler | P3 v2.1 Gauge | Interior LED Retrofit |
08-07-2016, 11:36 PM | #62 |
19
Rep 91
Is there any reason that only one of the two alignment pins would be removed? My car has a pull to the right (the side with the missing pin) but all alignment specs are good. Just trying to track the issue down.
08-18-2016, 07:10 PM | #63 |
<(O0=[][]=0O)>
764
Rep 1,199
Specs are good - but are they the same L/R?
2012 E88 M-Sport 135i DSB Metallic
COBB CP, ZHP Knob, E60 SSK Lever, E92 M3 FSB, RSFB inserts, Koni Sport, Eibach Pro, UCP, MPSS, AP axle-back, MHD Stage1+ 91 <(O0=[][]=0O)> |
08-18-2016, 09:32 PM | #64 |
19
Rep 91
08-19-2016, 09:14 AM | #65 |
130
Rep 351
Which direction does it pull?
Ohlins Road & Track Coilovers / Apex ARC 8's 245/255-35 MPSS / Wagner Downpipes / Wagner EVOII Intercooler / ER Charge Pipe / Forge DV / PowerFlex RSFB / PowerFlex Differential Bushings / MFactory 3.46 Torsion LSD / MHD Flasher
