04-08-2022, 09:50 AM | #45 |
502
Rep 1,399
Bumping this up hoping someone can help out. Thanks!
Current: 2022 Donnington Grey M5 Competition, 2014 Anvil WW Jeep Wrangler
Previous: 2019 Donnington Grey M5 Competition, 2016 Silverstone M5 CP, 2013 Monte Carlo Blue M5 CP (ED on 9/1/12), 2009 Carbon Black M5, 2006 Silverstone M5, 2003 Sterling Grey M5, 2000 Anthracite 540i6, 1998 Jeep Grand Cherokee 5.9Ltd, 1990 Eagle Talon TSi AWD, 1978 Mazda RX-7 |
04-14-2022, 01:03 PM | #46 | |
162
Rep 254
Drives: M5 / X5
Anyone know exactly how long their shop took to install secondaries? |
04-14-2022, 04:39 PM | #47 | ||
224
Rep 211
04-14-2022, 05:13 PM | #48 | |||
162
Rep 254
Drives: M5 / X5
BMA89223.50 |
04-15-2022, 06:24 PM | #51 |
5293
Rep 10,686
Well, when you open the hood, can you see the downpipes or are they hudddn under components that have to be removed from the top of the engine to provide access?
04-15-2022, 07:12 PM | #53 | |
2037
Rep 5,097
Check number #9 (secondary). Number #1 (Primary's) would connect to the back of your turbos.
04-15-2022, 09:14 PM | #54 |
5293
Rep 10,686
Yes, primaries connect to the turbos and you can’t get to those without removing some stuff on top of the engine. I don’t need to look at the diagram because I have had the engine cover and heat shielding off and have seen what us required to get at the primaries. Secondaries, I don’t know that you can get them off from underneath the car. I have not yet done this job. Those who have done can respond. I will be doing it it a few weeks — high flow primaries and catless secondaries.
04-16-2022, 07:33 AM | #55 |
502
Rep 1,399
That is not correct. For the secondaries everything can be done from below.
04-16-2022, 08:09 AM | #56 |
82
Rep 136
just had the mad mid pipe installed this week. Took my installer about 3 hours. They did some stuff from the top also because i guess the v band was easier to tighten. They did have to have a second person down below pulling on the passenger side pipe because it was off by fractions and wouldnt secure like the drivers side. They got it done but i am glad i didnt do the work. I was going to do it in my garage just by jacking one side at a time and for sure it would have been a bad idea.
Sound wise it is fractionally raspier and i can live with that. The two cats that were replaced on minimal at best so don't expect the snarl you get from some of the better exhaust systems available but this is a fairly cheap mod to get some sound. |
04-16-2022, 09:33 AM | #57 |
162
Rep 254
Drives: M5 / X5
That's helpful, thanks guys.
04-16-2022, 10:55 AM | #58 |
371
Rep 915
Drives: ///M's
Installed the secondary downpipes on the CS couple weeks ago. You do need access on top to remove the screw clamps from the primary to the secondary dps. Not sure how you would remove those clamps since the screws can be only accessed on top. My installer even removed the coolant reservoir to gain space to reach the screw clamps on the drivers side. Removing the primary dps isn't necessary.
Paired the dps with my Akra and gave it a noticeable sound change with slightly higher pitch sound. As others said sound change isn't dramatic but it's noticeable. Here's a couple of IG videos. https://www.instagram.com/reel/Cb_aF...d=YmMyMTA2M2Y= https://www.instagram.com/reel/Ccan_...d=YmMyMTA2M2Y= |
04-18-2022, 11:53 PM | #59 |
4152
Rep 7,167
Drives: F90 M5 / F15 50i
I found it interesting that some say the exhaust note is deeper and others say higher. Gotta love perception.
'07 Yamaha R1 (sold)
05-06-2022, 12:37 PM | #61 | |
502
Rep 1,399
First, I'll provide my review. The sound level is mildly louder on cold-start and at idle, and to my ear has a deeper tone. It's not a significant change, so some may be disappointed, but since my neighbor already calls my car her second alarm clock I couldn't go too crazy. When revving it is a little louder and again, to me, a pleasingly deeper tone and seems to have a little more "bark" to it. All-in-all I'm happy and would do it again, but at about $1,100 all-in including the downpipes, install and eventual removal (leased car), on a "bang-for-your-buck" scale it could rate at the lower end of the range for some people looking for a much more aggressive sound. Now, I'll explain the confusion I ran into in the event it helps other members avoid the same. The first installer I went to brought the MAD downpipe out from the shop and was showing me that the OEM gasket didn't fit into the seat (see my first picture below where I'm measuring the width of the seat). Thinking it would be unsafe to proceed with the install without the gasket we decided to reinstall the OEM pipe until I could figure out what the issue was. Turns out, that notch I'm measuring is not the seat for the gasket, but is the female half of the male/female connection point between the primary and secondary downpipes. The OEM downpipes (see second picture below) have a gasket seat machined into the top side of the downpipe flange, the MAD downpipes do not - the gasket is just compressed against the flange when the top end clamp is installed and tightened. So, in summary, the MAD pipes are a direct replacement for the OEM downpipes. The upper and lower OEM clamps, along with the OEM gasket, are reused to install the MAD downpipes. The install should take 2.5 - 3.0 hours, and it seems most installers (like mine) need to remove some items from the top end of the engine to get better access to the top clamp on the driver's side pipes. (NOTE to MAD: a one-page instruction sheet included with the downpipes noting these things would likely help your customers avoid any confusion or longer than necessary installations).
BMA89223.50 |
05-06-2022, 01:35 PM | #62 | |
502
Rep 1,399
After my previous post, I had a break in my work schedule so I went out to the garage to package up the OEM downpipes for storage. I took them out of the box to wrap them in the bubble wrap that the MAD pipes came in and what do I see in the bottom of the box? One of the OEM gaskets. Huh?!? Turns out in my second photo in my previous post above of the OEM downpipe, the gasket is still in its channel. Below are pictures with and without the gasket. Given how thick the gasket is and how deep it sits in the channel, there's likely no way they'd fit if the installer tried to reuse them with the MAD downpipes. I'm guessing the lower flange on the OEM primary downpipe looks a lot like the upper flange on the MAD secondary downpipe. So it seems you DO NOT reuse the OEM gaskets. That would be consistent with the conversation I had with John Keller at Keller performance while doing my research. I called them because the flange on their secondary downpipes looks the same as the MAD flange (see third picture below). John said their product does not reuse the OEM gasket, just the two clamps. Sorry for post-bombing this thread, but the lack of a simple page of instructions for this product is becoming more and more frustrating, as the installation without reusing the OEM gaskets is in direct conflict with what I was told by MAD.
05-06-2022, 04:18 PM | #63 | |
3620
Rep 4,532
05-06-2022, 08:38 PM | #64 |
5293
Rep 10,686
V band flanges and clamps are typically metal to metal with no gasket, but you do need a set of matching V band flanges to weld onto the exhaust and a clamp made to fit them. I have no idea about the bmw version since I have not done the job yet (sometime in the next week), but the potential for a problem would be mating an aftermarket pipe and flange to the bmw pipe (such as factory upper to aftermarket lower). I assume any good maker of the aftermarket pipes has figured this out and the parts fit. Typically problems occur when cheap chinese copies of copies are sold without the makers ever having actually fitted them. Yes, it happens—many years ago I did some prototype test fitting for XS Power.
05-08-2022, 11:09 AM | #65 |
Rep 31
05-08-2022, 11:33 AM | #66 |
Rep 31
