BMW M5 F90 (2018+) General Forums Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls    Low coolant warnings
      07-31-2022, 09:43 PM   #45
AHall
989
Drives: 1993 Nissan 240sx
Can someone confirm if the coolant tank sensor is replaceable? I noticed sensors for the coolant tank for sale separate from the tank, but I thought the sensor was molded into the tank which would make zero sense.
I have contacted a custom tank manufacturer whom indicated they can manufacture an aluminum tank but will need to determine how to integrate the sensor.
      10-04-2022, 12:47 AM   #46
erod550
Drives: 2019 M5 Competition
Just got my 2nd low coolant warning in 6 months/2k miles of ownership. First one was literally the day after I brought it home. Thanks to this thread I checked for that residue around the coolant cap and it’s pretty bad. I’ll be calling the dealer tomorrow to get this addressed before my warranty runs out next month.
View post on imgur.com
      11-09-2022, 04:00 PM   #47
AHall
989
What happened?
      12-08-2022, 08:55 AM   #48
Jimmy K
Drives: '19 M5C Donington Gray/Blk
My car is at the dealer getting Dinan X-pipes installed and I asked them to look at the coolant reservoir.
They are going to replace it under warranty. I hope the new reservoir is designed better.
      12-08-2022, 09:02 AM   #49
Maverik259
Maverik259's Avatar
Drives: F90 M5 / F15 50i
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
your dealer is cutting your oem exhaust and putting on an x-pipe? did you buy it from them?
'07 Yamaha R1 (sold)
'06 C55 AMG (sold)
‘?20 M5, MP Carbon Pro Spoiler, MP Carbon Diffuser, MP Black grille and gills, MP Carbon Mirrors, CF side sills, 789M w/ Ti studs, eventuri, Dinan X pipe
'14 X5 50i (wife’s now)
      12-08-2022, 09:09 AM   #50
Jimmy K
Yes. They’re one of the few Dinan/Carbahn friendly dealers.
      12-09-2022, 10:38 PM   #51
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Nice
'06 C55 AMG (sold)
      01-03-2023, 11:12 AM   #52
Alberta
Alberta's Avatar
2052
Drives: F90
My car is approaching 36.000 miles and I'm wondering if I should replace preventively the cooling tank...
What would be your advice, considering I have had a low cooling fluid message when the car had about 13.000 miles ?
I've added cooling fluid at the time and the warning went away.
It's been fine since then.
      01-03-2023, 02:06 PM   #53
AHall
989
How often or when was the last time you checked the area around the coolant tank for leaks? Do you open the tank and visually check the level? Have you seen any signs of a leak?
      01-04-2023, 05:53 AM   #54
Alberta
Alberta's Avatar
2052
Drives: F90
I've removed the cap and checked the level a few weeks ago, and it was fine.
No signs of coolant leaks in the area of the tank.
My car is soon going in for service and I'm debating if I should replace the tank preventively or not.
      01-05-2023, 07:24 PM   #55
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
I wouldn’t worry about it unles the dealer will ok good faith (dought it). They don’t catastrophically fail. And like you said, you check it periodically.
I just hit 15k miles on my 2020 and have found white crystal splattering around the engine bay a couple times now with some caked on around the cap. Took pics and cleaned it up. Sent them to my SA and asked him to order me the new part number version for my next oil change in February. Which he is.
'06 C55 AMG (sold)
Alberta2051.50
      02-11-2023, 07:52 AM   #56
Alberta
Alberta's Avatar
2052
Drives: F90
I finally had it changed yesterday while my car was in for maintenance.
BMW has certainly improved it and the new part number is this one : 17137889450 and new cap : 17117639021
      02-11-2023, 08:20 AM   #57
pbonsalb
5287
What are the visible signs of improvement?
      02-13-2023, 03:17 AM   #58
Alberta
Alberta's Avatar
2052
Drives: F90
I have no idea...
      02-13-2023, 06:42 AM   #59
pbonsalb
5287
How do we know BMW has certainly improved it? A part number change after 6 years of production is not uncommon and does not necessarily mean the part is improved.
Maverik2594150.50
      02-14-2023, 10:57 AM   #60
Alberta
Alberta's Avatar
2052
Drives: F90
You're right.
I assume that BMW has improved it, but I have no proof.
      02-14-2023, 12:20 PM   #61
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
I have no idea...
'06 C55 AMG (sold)
      02-14-2023, 03:16 PM   #62
pbonsalb
5287
Time will tell. Some never have had problems, some have problems after several years and some have problems in a matter of months. We need data from new cars with the new tank and old cars with the new tank as a replacement.
      02-14-2023, 03:23 PM   #63
ResIpsaLoquitur
ResIpsaLoquitur's Avatar
4159
Drives: 2022 M5C
I think I’m in the minority, but despite how often I see this issue on the forum, two M5s now where I have been fortunate enough to never encounter this problem. Because of what I’ve learned from the forum, I am constantly on the search for coolant residue and leaks; but thankfully, so far, so good.
Actually needing coolant more than normal, though? Definitely. Burning through it fast, but not due to a leak.
Not a BMW guy...but certainly an M5 guy.
      02-18-2023, 09:23 PM   #64
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Just got my annual service on my 2020. 17k miles.
Replaced coolant tank and cap
Replaced spark plugs (found this a bit early)
Replaced brake fluid
Replaced light switch due to flicker
'06 C55 AMG (sold)
      02-20-2023, 07:34 AM   #65
AHall
989
Why did they replace the tank?
      02-20-2023, 07:53 AM   #66
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
I asked them too after seeing dried coolant splattered through the engine bay and around the cap and top seal.
Had to take pictures for proof since I clean it up as quick as possible.
'06 C55 AMG (sold)
