10-12-2021, 08:40 PM | #45 |
Rep 26
10-13-2021, 12:59 PM | #46 |
1913
Rep 2,526
I could live without the Bowers & Wilkens stereo, but I must have the heads-up display. Is it true that some 2022 M5's won't have it?
2022 F90 M5 Competition & 2019 M2 Competition
2019 F90 M5 Competition 2017 F80 M3 Competition 2014 F10 M5 Competition 2003 E39 M5 |
10-13-2021, 01:35 PM | #47 |
42
Rep 186
10-13-2021, 08:18 PM | #48 |
1481
Rep 3,955
10-14-2021, 02:42 PM | #49 | |
4067
Rep 4,988
https://www.bimmerpost.com/forums/sh...php?p=28139310
<b>2023 M5C SRG|Aragon || 2018 Macan GTS</b>
2019 F90 Comp MBB|Black (sold) 2018 F80 ZCP TB|SS (sold) 2015 F30 335 AW|CR (sold) 2015 F31 MG|CR (sold) 2011 E90 JB|Oyster (sold) |
10-14-2021, 05:04 PM | #50 | |
80
Rep 87
My experience has been that the mid/high clarity is good. The bass kinda sucks, and the overall setup is above average for a factory car system, but far from stellar. If there are magic settings please share by line item! Again, not directed at you personally — but this comes across as “if you don’t like it you’re wrong and it’s your fault” when never followed by the settings. |
10-14-2021, 06:27 PM | #51 | ||
4067
Rep 4,988
https://www.bimmerpost.com/forums/sh...php?p=26895486
Jamesmick131.00 |
10-24-2021, 11:35 PM | #52 | |
796
Rep 564
Maybe the next M5 they will get it right |
10-25-2021, 03:28 AM | #53 | |
2052
Rep 1,856
I have a lot of bass with the B&W sound system. |
10-25-2021, 05:32 AM | #54 |
138
Rep 102
Im not an audiophile by any means, but I’ve had aftermarket sound systems in all my cars except the M5. I seem to have plenty of bass, but a lot of other stuff is lacking. Granted I haven’t done any sort of calibration at all since I usually drive with the music off.
10-26-2021, 04:50 PM | #55 | |
101
Rep 186
Can I ask what source material you’re using? We’ve a big discussion on X7 board and seem consensus is that while internal DAC of B&W won’t allow 1495kps that Tidal Master tracks stream in, as well as a 48Khz limitation for Apple Car Play (CD quality) that the use of high quality source material (streamed or storage device) that the system sounds very good. The H&K in my F10 M5 doesn’t even come close to the B&W system in wife’s new 2022 M50i X7 using same source material and tuned EQ settings. I was very satisfied with the 3400.00 option charge and results with EQ and DSP settings as well as high quality source material. This of course all has to take into consideration that this is a car stereo and not an audiophile home set up w exoctic DAC’s, amps and speakers. |
10-27-2021, 01:18 AM | #56 | |
113
Rep 67
Current Garage:
2021 Nardo Grey M5 Competition - MPerformance Diffuser, Lip and HAS 2016 McLaren Mexico Blue 675LT with Roof Scoop 2018 Porsche Graphite Blue Metallic GT3 Touring Manthey Racing and Akrapovic 2018 BMW Yas Marina Blue M4 Competition Convertible |
10-27-2021, 07:19 AM | #57 | |
101
Rep 186
Personally I like Tidal. Over 70MM tracks in their library, ability to download so you can listen in off line mode etc. Best Buy has a program that will allow you to get a 12 mos subscription of their HiFi service (high bit rate) for 120.00. 10.00/mo is pretty reasonable. Check out the X7 forum on this same platform and look for a thread called Bowers and Wilkins debate. Lots of good info |
neoprufrok112.50 |
10-27-2021, 08:18 AM | #58 | ||
580
Rep 650
I have not attempted anything higher than that yet. I suppose you could run a different music app like Onkyo which plays DSD or 24/192 files, but I doubt the MOST network can process anything above 16/44.1 so anything that gets fed to it will be dithered and resampled to a rate it can use. |
10-27-2021, 01:26 PM | #59 | |
101
Rep 186
Thanks for the info. |
10-27-2021, 01:48 PM | #60 | |
113
Rep 67
Current Garage:
