BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Coding / ConnectedDrive / Audio-Video / Electronics / Bluetooth / I-Drive & Nav
EXXEL Distributions
      10-27-2020, 01:20 AM   #45
unrulyteach
unrulyteach's Avatar
Drives: 2011 335i
2011 BMW 335i  [0.00]
Originally Posted by chuzo View Post
Sangria, thank you very much for your detailed write up for this retrofit.
I retrofitted the camera on my e92 m3 and all worked really good.
Based on the pictures I believe the e92 has more room in the trunk for the cable connector.
The parking aid lines came after the calibration with inpa and a short drive.
I used:
e70 TRSVC
cable harness from the ebay seller
chinese ebay backup camera for e90
f25 oem backup camera (modified to fit on the chinese camera handle)
x1 pdc
JBE "M" version
Where did u install trsvc module?
      10-27-2020, 01:21 AM   #46
unrulyteach
Drives: 2011 335i
Originally Posted by BFZ4M View Post
Originally Posted by unrulyteach View Post
Hav u started ur install yet?
No, not yet. Trying to learn more about coding modules before I get started.
I just ordered a the oem wiring harness since I'm
Getting k-can faults
      10-27-2020, 03:16 AM   #47
Dubstar
15
Drives: BMW E81
2015 F31 320d  [0.00]
Ok install jbe m today and I'm still having the same issue, Pdc is not communicating with car with i borrow power and can h/l from it to power tr module. Is it a possibility that Pdc can't supply power or can h/l for tr module?
Maybe the fuse is blown for PDC? While you grab power for TRSVC.
Before I installed all correctly, for testing I grab power from Combox and can from PDC.
When you disconnect the TRSVC, the PDC is working?
      10-27-2020, 04:02 AM   #48
unrulyteach
Drives: 2011 335i
Yes when i unplugged trsvc and return oem wires to pdc. Pdc works as it should. I just ordered oem wiring harness to see if that fixes the issue if it doesn't then I'll be stuck. This last time when. I connected the wires and scanned with ista p it showed up yellow and not red so i made progress. The code i got was a k can. Oh btw the doesn't recognize trsvc at all it doesn't show up in ista or inpaw
      10-27-2020, 08:22 PM   #49
SaNGRia
SaNGRia's Avatar
997
Drives: LCI E93 M3 + F85 X5M
Congrat buddy. Thats why i am here and thats why i share here! Made my day!
And you are right bout the space. E93 is tight. E90 was alot better. e92 is the best i guess
I used:
e70 TRSVC
x1 pdc
JBE "M" version
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post!
DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue,
, F85 ACC Retrofit
      10-27-2020, 08:24 PM   #50
SaNGRia
SaNGRia's Avatar
997
Did you properly VIN flash the JBE3 and default code for your car?
, F85 ACC Retrofit
      10-27-2020, 08:25 PM   #51
SaNGRia
SaNGRia's Avatar
997
i can remotely code everything u need!
, F85 ACC Retrofit
      10-27-2020, 08:55 PM   #52
unrulyteach
Drives: 2011 335i
I updated jbe with winkfp and default code jbe not the whole car
      10-27-2020, 10:19 PM   #53
SaNGRia
SaNGRia's Avatar
997
No not the whole car. Just the JBE. Well can you communicate all the other modules except the TRSVC?
If you can not communicate with the TRSVC check the Software No. If it starts with Numbers then it belongs to F series and i also had one and does not work for our cars! If it starts with Letter (A,B,D) that belongs to E series which is fine. LMK!
F series :
E series :
, F85 ACC Retrofit
      10-27-2020, 10:34 PM   #54
unrulyteach
Drives: 2011 335i
F series :
Attachment 2447960
E series :
Attachment 2447961
Mine starts with numbers
      10-27-2020, 10:39 PM   #55
SaNGRia
SaNGRia's Avatar
997
Wrong part. That belongs to F series and F series uses 500kb vs E series uses 100kb on KDCAN. Just like the F series CIC cant fit on E series! So i warned couple of Ebay sellers who put a title like X1 E9X on a F series TRSVC but cant correct everyone. You need to get E series!
+ I tried to Expert Flash the TRSVC with X1 files using the winkfp But since i couldnt communicate , i couldnt flash it.
, F85 ACC Retrofit
      10-27-2020, 10:41 PM   #56
unrulyteach
Drives: 2011 335i
Wrong part. That belongs to F series and F series uses 500mb vs E series uses 100mb on KDCAN. So i warned couple of Ebay sellers who put a title like X1 E9X on a F series TRSVC but cant correct everyone. You need to get E series!
Even if it came from a e series x6
      10-27-2020, 10:44 PM   #57
SaNGRia
SaNGRia's Avatar
997
Send me the VIN no. Let's see what E series X6 came from! All E70/E71 TRSVCs came with Side View or Top view options there is No single Fakra E70/E71 TRSVC in the states!
, F85 ACC Retrofit
      10-27-2020, 11:07 PM   #58
unrulyteach
Drives: 2011 335i
That sounds right. Got a link to any reasonable one
      10-27-2020, 11:17 PM   #59
SaNGRia
SaNGRia's Avatar
997
You can get this one. You will see top view camera error on ISTA but will work without an issue. Later on you can activate the top view , if you find the camera with harness!
, F85 ACC Retrofit
      10-27-2020, 11:22 PM   #60
BFZ4M
10
Drives: E92 M3 ZCP
I might just take you up on that offer!
      10-28-2020, 12:01 AM   #61
unrulyteach
Drives: 2011 335i
Ordered this should get here before oem harness so i will test it with the harness i currently hav i appreciate it
      10-28-2020, 10:33 AM   #62
SaNGRia
SaNGRia's Avatar
997
Whenever you are ready let me know 👍🏻
, F85 ACC Retrofit
BFZ4M9.50
      10-28-2020, 11:31 PM   #63
chuzo
Panama
15
Drives: 2016 M4
hey there, I installed the trsv below the combox/media bracket with a nut and secure it with a zip tie.
I don't have more pictures of the oem camera and the chinese handle, but I had to dremel a lot of the inside where the chinese camera was to make room for the bulky oem camera.
The end result looked very similar to Sangria's camera fitment.
Appreciate 2
SaNGRia996.50
      10-28-2020, 11:46 PM   #64
SaNGRia
SaNGRia's Avatar
997
That's about right. Great job!
, F85 ACC Retrofit
      10-30-2020, 04:49 PM   #65
unrulyteach
Drives: 2011 335i
Still getting the same results as i did with f series trsvc module
      10-31-2020, 12:53 PM   #66
Dubstar
15
Drives: BMW E81
Tried to change the CAN bus cable on TRSVC? Maybe it's wrong..
m3post
