02-19-2024, 10:12 PM | #45 |
23
Rep 31
Well, not the first time the service department has misrepresented a situation.
2019 M5 CP
formerly - 2018 M4 and before that - 2013 M3 |
02-20-2024, 02:44 PM | #46 |
84
Rep 311
I had the low coolant light come in yesterday, it was the 2nd time in 6 months, but this time they found out that the expansion tank was leaking so they will be replacing it. I wonder if the replacement part is any better than what was originally on the car. My car is a 2020 with 35k on the odo
2020 BMW M5
Mad Secondary Downpipes / Mad Catback / BMC Filters / Eibach Pro-Kit / Titan T-S5 Wheels |
02-20-2024, 04:15 PM | #47 | |
989
Rep 1,807
02-20-2024, 04:26 PM | #48 |
49
Rep 125
I had the warning back in november. I kinda ignored it because it goes away after a while or if you restart your car again. When I finally checked it was pretty low. Like you cant even see the fluid with a flash light low. I topped it off and checked for leak with a blacklight and found nothing. Its been fine since. Coolant stayed at max level.
02-20-2024, 09:16 PM | #49 |
84
Rep 311
Oh damn, I asked my SA and he mentioned the replacement being better. And yeah, it was replaced under warranty
2020 BMW M5
03-12-2024, 06:19 PM | #50 |
24
Rep 39
I just had my coolant topped up for the second time in probably 6-8 months. This most recent time, my SA said the tech's supervisor looked for a leak and couldn't find one. How does the coolant level go down if there isn't a leak somewhere? Is that even possible?
03-12-2024, 09:39 PM | #51 | |
62
Rep 99
To be honest on other cars coolant does go down a bit due to evaporation from the expansion/vacuum cycle. So not far fetched. Just have to watch it. |
03-13-2024, 07:17 AM | #52 | |
340
Rep 414
Drives: 23 M5C, 19 X5
Oh in fairness to the dealer, ISTA says to overfill the tank when filling. Not sure how that squares with "don't get coolant on the injectors". Sigh. German engineering. |
03-13-2024, 10:23 AM | #54 | |
340
Rep 414
I had my level drop twice on temperature changes but I felt I had a leak too because there were white spots on the tank sides. |
