F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > B58 Log Review Thread
ARMA SPEED
      09-04-2019, 09:17 AM   #45
kern417
Cheapskate
4464
Drives: 2018 440i |2016 340i | 2010 X5
Originally Posted by enemigo13 View Post
logs should be done after some WOT pulls. as this ecu will target less right after writing or e.g. after 1-2 WOT pulls. It needs more to make adaptations. Usually stage 1 gives ~1.1 bar (16psi) at ~6200rpm, stage2 gives 1.3 bar (19psi) at the same rpms.
Can you post a stage 2 log that targets 19psi? We have multiple logs posted here and in the fb group that only targets 16.
I also don't see why that's a limitation of the stock downpipe. Why can't we run more boost on Stage 1?
Originally Posted by umizoomi View Post
As long as 3-pedals are an option, I will exercise my right to suffer the handicap and indignity of slower shifts and reaction times.
Youtube/Instagram/TikTok: @kern417
IMS-340C400.50
      09-04-2019, 09:28 AM   #46
jackstrath
Scotland
663
Drives: 16' F31 340i & 03' Focus RS
Here is my stage 2 93 log
http://www.bootmod3.net/log?id=5d6eccabc090c6521e903371
did do another 2 runs after it but it wont put them in to a chart for some reason, all i get is " generating chart for bootmod3 datalog please wait "
kern4174464.00
      09-04-2019, 09:32 AM   #47
enemigo13
249
Drives: F32 LCI 440xi citrineblack
here you go :
https://datazap.me/u/enemigo/f30-340...olo=1-3-4-8-10
0x4A2D is intake manifold pressure if you want before throttle it's stat_ladedruck_wert, it's 4 and 5th gears, stock downpipe. 0x4651 is WGDC %.
      09-04-2019, 09:55 AM   #48
IMS-340C
IMS-340C's Avatar
Egypt
401
Drives: Self Tuned 340i 8AT RWD
I don't understand increasing boost in stage 2 with the same fuel octane, What about knock ? Usually boost is related to Octane.
      09-04-2019, 10:00 AM   #49
enemigo13
249
and I don’t understand why not to use stock turbo to it’s limits (near 90% wgdc)
kern4174464.00
      09-04-2019, 10:08 AM   #50
IMS-340C
IMS-340C's Avatar
Egypt
401
You can use stock turbo near it's limits, you just have to inject more fuel and use higher octane to match.
      09-04-2019, 10:18 AM   #51
enemigo13
249
You can use stock turbo near it's limits, you just have to use higher octane to match.
higher octane - the better of course. do you know how modern ecus (ok e.g. stock tunes) compensate lower ignition timing because of worse quality fuel to get the same torque/power? yes, boosting more. modern ecus target not to boost or load, they target to torque. if IAT is low (winter) fuel quality very good- targets to less boost, if ambient temperatures are high, fuel is not perfect - targeting to higher boost, that customer would not complain that car is slow comparing to one it was in winter. stock tunes usually have pretty lots of headroom for this, when you maxx out turbo you know that your winter dragy times will be better than summer ones for sure..
      09-04-2019, 10:25 AM   #52
IMS-340C
IMS-340C's Avatar
Egypt
401
yes but there's a limit on how much compensation the ECU makes, if fuel is really bad and weather very hot it will not be able to achieve the required power otherwise it will blow the engine.
      09-04-2019, 10:29 AM   #53
enemigo13
249
most of the times it surely can compensate with stock tune. lot’s of headroom
      09-04-2019, 11:02 AM   #54
IMS-340C
IMS-340C's Avatar
Egypt
401
Not as you think, if the engine starts knocking there's not much the ECU can do.
      09-04-2019, 12:26 PM   #55
kern417
Cheapskate
4464
here you go :
what tune are you running?
octane isn't as big of an issue as fueling for boost. you just need to keep afrs in control. you can run a lot of boost and less timing to make similar power.
boost limitation is based on fuel cap
timing limitation is based on octane
both have an efficiency range where going past the peak point will not make more power or could lose power.
      09-04-2019, 12:38 PM   #56
Solid67
Drives: 2019 M240i xDrive MP Edition
So one of the reasons I made this thread is being shown. I'm having trouble seeing the difference between Stage 1 and Stage 2. Are there any other stage 2 logs out there? I thought it had a higher boost target. And I don't really see how it's taking advantage of a downpipe or why it's needed.
I have to agree with you on not really knowing the difference between Stg 1 and Stg 2 whether its 91, 93 or E30. Looking at different logs, its really hard to tell what the difference between the two are since boost and timing almost look the same.
kern4174464.00
      09-04-2019, 03:30 PM   #57
enemigo13
249
tune is my made, but you can check mission performance logs, they run ~1.3 bar also. imho nothing more can be done with stock turbo, it’s about the limit.
kern4174464.00
      09-04-2019, 04:01 PM   #58
Solid67
Stock turbo should be good for over 500awhp so I dont think you are at the limit unless you have dynoed your car. Go check out Pure Turbos IG story from today and you will see they posted the dyno from Tom Wrigley's M240i which has BM3, catless dp, drop in filter, wagner heat exchange. They used a combination of E40/Meth to hit 505awhp and 700nm (not sure how much torque that is). Seen guys running as high as 23psi on the stock turbo (I believe one forum member even took it up to 25psi).
If we factor in the B58TU turbo, those can come close to putting down 525-550hp and same for tq (maybe even higher tq). I know the turbo is different, but not really sure what the difference is in terms of the compressor and turbine.
I'm coming close to pulling the trigger on the BMS meth kit or the Fuel-It! CPI kit so I can max out the stock turbo.
kern4174464.00
      09-04-2019, 04:55 PM   #59
GT500R
800
Drives: BMW X3M
Correct, in addition the load is a bit higher compared to other logs (from what I can see), since I assume this is the only apples to apples you can do to understand how logs with different tuners stack up, right?
LOAD: Load can be thought of as the amount of air entering your engine at a certain engine speed. Load is an approximation of your motor’s torque output calculated using the the amount of airflow entering the motor, engine RPM, and a scaling constant. The amount of airflow entering the motor (measured in grams/second or pounds/minute) is measured either directly using a Mass Airflow Sensor (MAF) or calculated using a Manifold Absolute Pressure Sensor (MAP)
X3M Alpine White - SOLD
Fastest Tune Only Record - Mission Performance
10.84@127.43 / +1912 DA NH Dragway |
10.6@130 Dragy / +820 DA The Streets |
NOW: Tesla Model Y Performance
      09-04-2019, 07:08 PM   #60
kern417
Cheapskate
4464
That's my plan, though it probably won't happen any time soon. All I want is a stock turbo e85 tune. And I'm not too enthusiastic about paying another $500-$600 for one of BM3's tuners to street tune it. Much easier to get a dyno tune and then do the street tune myself. Depending on how much I learn from threads like this and what the hpfp options look like this fall, we'll see.
      09-04-2019, 08:02 PM   #61
B58 parts
B58 parts's Avatar
Drives: '17 340ix 6MT
What operating temp do you guys typically see? Mine has always been right at 230F .. which seems kinda high but it's about 40% up on the gauge so I figure that's where it wants to be. Oil / coolant temp both sit right around there. Still though I'm used to 210 being high on most other cars. I'd like to upgrade some of the cooling / make it kick on earlier.
The rest of my numbers at stage 1 are right there with the rest of yours. After wasting almost 3k on brakes .. I plan to go downpipe to stage 2.
      09-04-2019, 09:24 PM   #62
GT500R
800
Drives: BMW X3M
3rd gear 2k rpm = 226F
3rd gear 6.6k rpm = 233F
4th gear 6.3k rpm = 219F
5th gear 6.2k rpm = 226F
So essentially it rises in 3rd gear, drops massively in 4th and slowly rises in 5th.
IAT goes from 27*C (80*F) to 38*C (100*F) from start of 3rd to 5th 6300 rpm in the same run... which to be honest is amazing IMO
This is MP Tune.
      09-04-2019, 10:43 PM   #63
SC_B5X
Built Motor F30 340i
SC_B5X's Avatar
407
Drives: Built Motor 2016 BMW 340i
Here's mine. Running a custom tune by Wedge Performance on MHD. It's not fully dialed in yet.
3rd Gear Log: https://datazap.me/u/richmichael97/w...31-32-33-34-35
Fuel: E30 + Meth (50/50)
Mods:
- VRSF 4.5" Catless DP
- Remus Axleback
- Dual Resonator Delete (I don't recommend, it gets a little raspy. I plan on getting a resonator put on)
- AEM V2 Meth Kit (Throttle Body Injected, 2x ProMeth 504cc Nozzles)
Also here is what it runs in the 1/8th mile on this tune:
kern4174464.00
      09-05-2019, 01:11 AM   #64
enemigo13
249
load in my log is stat_lastwert_relativ_wert, in bootmod3 logs it is Load target (Rel.) [%].
      09-05-2019, 01:17 AM   #65
enemigo13
249
looking very powerful 187.5% load at 6000rpm with 15deg of timing, ~500hp?
Mods:
- Remus Axleback
      09-05-2019, 01:20 AM   #66
enemigo13
249
23psi with stock turbo WHERE? yes, at 3000rpm it is possible, if you wont crash hpfp, and it is possible without crashing with additional fueling. not possible at 6000+ rpm for sure, so who needs 23psi at 3000rpm?
f30post
