BMW M5 F90 (2018+) General Forums iDrive, Nav, Stereo, Bluetooth, Electronics    Coding Success via ESYS on F90
      01-13-2022, 05:12 PM   #45
M5CLAW
Drives: f10 m5
Originally Posted by Almaretto View Post
S15A Connection Target
  • Close Windows & Fold Mirrors with CA & keyFob
  • Adjust Initiation Delay
  • Disable Window Safety
  • Adjust Passenger mirror Vertical Tilt when in reverse
  • Adjust Specialty KeyFOB settings
  • Close trunk KeyFOB/ Rockerswitch & remove beeps
  • Disable Horn Honk when closing vehicle with Engine ‘ON’
  • Set Default Driving Mode
  • Pressing HVAC ‘AUTO’ button does not activate A/C
  • Setting Heat/Cooling/Massage Memory for Seats/Steering wheel
  • Auto-Activate Hazard Warning System
  • EU Brake Force Display
  • Disable Welcome BMW Sound (3 Gongs)
  • Remove Seatbelt Auditory Chime / Cluster status
  • Disable OBD Alarm
  • Enables Rear Camera Zoom
  • Disables 1st fuel warning at 50 miles
  • Disable Interior Alarm Sensor (Good if travel with active pets)
  • Enable Fog lights with Parking Lights or High Beams
  • Adjust Rain / Headlight Sensor Sensitivity
  • Variable Light Distribution (VLD) & NGHB
  • Adjust Angel Eye Brightness
  • Disable Amber sidemarker lights
  • Bluetooth Pairing display at any speed
  • Disable Office Function Speedlock
  • Enable Call Log Timestamp
  • Enable Personal Ringtone over vehicle speakers
  • Video playback from USB
  • Video in Motion
  • Disable Volume Popup Display Slider
  • Volume Retained at desired % (Default 25%)
  • Album Cover Scale to Full-Size
  • Disable Startup and Camera Legal Disclaimers
  • Change IDrive startup animation
  • Change BMW Sounds / Gongs
  • GPS Clock Sync
  • Cameras at All Speeds
  • Lane Departure Roadside Edge
  • EU SLI sign
  • Enable HUD ‘Do Not Pass/ Pass with care’
  • Blind Spot Detection at 20km/h
  • Default ACC distance
  • ↑ Traffic Jam Assistant (TJA) Max Speed
  • TJA on ALL ROADS
Hey do you mind messaging me I would love some
Help using Esys on a f90.
      01-14-2022, 03:40 AM   #46
Almaretto
Almaretto's Avatar
2376
Drives: Test Vehicles
Sent message
      01-15-2022, 11:56 AM   #47
TimmyBHGM5
41
Drives: BMW M5
Is it possible to remove the code for GPF?
      02-03-2022, 12:40 AM   #48
Almaretto
Almaretto's Avatar
2376
https://www.baanvelgen.com/en/leib-opf-deleter-bmw-m
https://www.manhart-performance.de/s...-/-cs-with-opf
      02-10-2022, 03:35 PM   #49
dhayek
dhayek's Avatar
Greece
Drives: 2018 M2, 2015 i8, 2010 M3
Originally Posted by GAMA View Post
How are you bud. Trying to get ahold of you. Can you pm me please. Thanks
Emailed
Anyone knows if it's possible to code the head up display to be in M layout on start up in efficiency mode ? On each start i have to go to settings to change it
      03-02-2022, 04:58 AM   #50
Almaretto
Almaretto's Avatar
2376
Not as far as I have seen, but have no looked specifically for this coding. Maybe someone else can chime in if they have found otherwise.
      07-04-2022, 03:22 PM   #51
hinckley
hinckley's Avatar
3493
Drives: '24 M4C Conv
Is it possible to code the start-up M Mode to default to the Sport program rather than the Road program?
CURRENT: '24 M4C Conv
RETIRED : '23 M8C Conv | '20 X4 M40i | '18 M4 6MT | '13 M5 6MT | '08 550i 6MT | '04 545i 6MT | '98 540i 6MT | '94 530i 5MT | '84 528e 5MT
Other retirees from Chevrolet, Buick, Subaru, Honda, Acura, Merkur(!), Volvo, Saab, Audi and Porsche
      08-27-2022, 09:19 AM   #52
Krisf90
Drives: BMW M5
I know you can code for full screen CarPlay... but is it possible to just upgrade the entire system from 7 to the newest version of iDrive?
      09-30-2022, 06:53 PM   #53
Mrrcman
Mrrcman's Avatar
85
Drives: X5
Light sensor for center screen Brightness
Does anyone know how to code out the automatic brightness sensor so it doesn’t work
if you have your windows tinted?
      10-01-2022, 12:47 AM   #54
Almaretto
Almaretto's Avatar
2376
https://g20.bimmerpost.com/forums/sh....php?t=1899487
      10-09-2022, 12:53 PM   #55
rabbutler
United Kingdom
37
Drives: M5 Competition 2019
2012 BMW M5  [0.00]
https://g20.bimmerpost.com/forums/showthread.php?t=1899487
Great thanks Almareto, got this work on my 2019 M5 using Bimmercode, with a slight difference on the actual coding but was simple to work out.
      10-10-2022, 11:47 AM   #56
Almaretto
Almaretto's Avatar
2376
      05-17-2023, 04:22 AM   #57
Erolk94
Germany
Drives: F30 320d
Does anyone know if it is possible to display the M5 competition in an normal M5 in the Kombi? Thanks in advance!
      03-12-2024, 03:27 PM   #58
mknlyfe
Drives: F82 Alpine White M4
F90 coding help please.
Hi do you know how to code the section in the middle of the Speedo from KM/H to MPH? The outside changes when I change the settings under idrive menu but too center or Speedo always stays KM/H.. Thank you in advance. I am trying to code using binmercode expert mode.
      03-12-2024, 03:28 PM   #59
mknlyfe
